When still employed a few years back we had all the proper instruments for measuring components and such, so getting timely decent measurement results wasn't difficult since someone else did the measurements
Now retired and having to do everything myself, but still "working" on a project, I need to make these measurements.
This ongoing project requires some components that are tightly matched and with tight ratios. Getting accurate matched components before COVID was difficult, now next to impossible without very deep pockets, so the decision was made to select matched components from a large batch of lesser accurate components, which provided the perfect "excuse" to sacrifice some project funds for a proper LRC meter
After considerable research we selected the Tonghui TH2830 LRC meter, TH26011CS Kelvin leads & TH26009B precision tweezers which has all the features for accurately measuring & binning components, but still working the learning curve on this new instrument. Out of curiosity we decided to check the capacitance measurement capability of the KS34465A & SDM3065X using some leaded film type capacitors covering the range of 1nF to 1uF, the DMMs compared well to the LRC meter. As expected electrolytic, and higher capacitance ceramic capacitors (X5R and X7R types) didn't agree well due to the different measurement techniques (for another discussion).
Then we turned to the lower value capacitors with the COG dielectrics which are SMD and require tweezers. We didn't have any proper tweezers for the KS and SDM DMMs except for the cheap two lead tweezers shown here.
https://www.aliexpress.com/item/1005002619578037.html?spm=a2g0s.9042311.0.0.523e4c4dUHGAQcThese tweezers don't shield the leads to the probe tips like the 4 wire TH26009B and thus subject to external influences and have almost 50pF distributed capacitance, so how is one supposed to get decent measurements at lower capacitances
Turns out the KS34465A has a few "features" that can help, first is the handy "null" feature to null out resistance in the test leads, this also works on capacitance!! Second is the MX+B "scaling" function to add extra resolution, also works on capacitance!!
We were able to get reasonable readings in the 10s of pF utilizing these cheap tweezers employing the features above and some careful technique. If the tweezers are gripped like you intend to use them and the tips carefully positioned opened about the same opening as the intended SMD chip, then the null invoked, the residual probe (and hand) capacitance can be effectively removed from the measurement.
This technique can work in a pinch when you don't have a proper LRC meter & fixture handy, but need to get a reasonable estimate of a small value chip capacitor, or match chips caps.
We've ordered another set of cheap tweezers, that may prove a little better. These have BNC type connectors which will need to be replaced with banana connectors for the DMM use.
https://www.aliexpress.com/item/1005001722184966.html?spm=a2g0s.9042311.0.0.10554c4dVoFphYAnyway, hope this helps when in a measurement pinch.
Best,
