Author Topic: Micsig Tablet Oscilloscope tBook mini TO1000  (Read 113643 times)
Offline nctnico
Re: Micsig Tablet Oscilloscope tBook mini TO1000
« Reply #275 on: June 27, 2018, 12:42:35 pm »
Did you try pressing power button several times? I don't have scope at hand, but I remember there was some confusing behavior. Like, one press was just to show batery charge, and the second press was to actually boot the device.
I have a different issue: it randomly power ups when I plug/unplug charger from mains :(. This is annoying as it turns on when I switch off my lab (I have a central power switch).
I have the same behaviour on mine. A recent firmware version has improved things a bit but there is some 'getting used to' involved.
Offline targit
« Reply #276 on: June 27, 2018, 01:35:46 pm »
 thanks for the suggestions, but every time I try it out at the workshop, power button works first press. Whenever I get it out in front of a customer it starts playing silly buggers, which is annoying because its such a good tool otherwise.
« Last Edit: June 27, 2018, 01:52:25 pm by targit »
Offline exe
  • self-educated hobbyist
« Reply #277 on: June 27, 2018, 02:47:14 pm »
That's because power button behaves differently when it's on mains.
Offline targit
« Reply #278 on: June 29, 2018, 12:22:39 pm »
I do not plug it in to the mains when I get back to the workshop to test it, as there would be no point. I am trying to find the fault which is present on battery power.
Offline PartialDischarge
« Reply #279 on: July 19, 2018, 03:09:04 pm »
Well, problem solved. The charger board was bad, after changing it scope works fine. The spare went through Batronix first and thats why it took a little more time, but overall very good service Micsig, thanks.
Offline targit
« Reply #280 on: August 17, 2018, 04:44:10 am »
Seems like mine may have a problem with the power socket, last time it played up out in the field I plugged/unplugged the power lead without any power connected and it has been working fine ever since, still cant get it to act up in the workshop, but pretty sure the socket or something nearby on the pcb is responsible.
Offline jacklee
  • Country: kr
  • Don't touch my Barbie!
« Reply #281 on: August 22, 2018, 08:31:05 am »
https://youtu.be/qW1hpmDjG_M
I found this Russian tech guy made a review, seems not bad. He even have the English subtitle. >:D
To be or not to be, who care this question?
The following users thanked this post: Synthtech
Offline tsman
« Reply #282 on: November 30, 2018, 12:40:59 am »
A new model has appeared on the Micsig site. STO1000 which looks to be a TO1000 but with extra knobs and buttons. No price listed.
New firmware (v343) has appeared as well if you set the TO1000 to Chinese. It adds the automotive features listed for the ATO1000 version of the scope. You'll need a license key to unlock it.
« Last Edit: November 30, 2018, 12:44:50 am by tsman »
Offline hgjdwx
« Reply #283 on: November 30, 2018, 05:52:10 am »
It looks pretty
Offline kirill_ka
  • Country: ru
« Reply #284 on: November 30, 2018, 08:58:14 am »
Recent revisions seem to be missing the standby (suspend?) mode.
Now it can display a protocol of decoded messages (i2c, UART, etc.). Unfortunately you can't use the message list and waveform display at the same time.
The following users thanked this post: nctnico
Offline tsman
« Reply #285 on: November 30, 2018, 02:45:18 pm »
Ahh. I was wondering why that popup looked different but couldn't work out why. I never use the standby mode normally so didn't notice.
Offline tsman
« Reply #286 on: November 30, 2018, 03:51:34 pm »
Poking around in the v343 firmware shows additional model codes like ADS-4574T. Micsig are making scopes for somebody called AKTAKOM now. They've got the handheld and mini tablet Micsig scopes under their own name + model codes.
Offline hammy
« Reply #287 on: November 30, 2018, 04:21:00 pm »
My TO1102 is loosing date & time if it is powered off for more than a few days.
It this behavior normal or is there a (empty?) coin cell for RTC?
« Last Edit: November 30, 2018, 05:36:37 pm by hammy »
Offline tsman
« Reply #288 on: November 30, 2018, 08:39:30 pm »
Mine did that yesterday as well. Just saw that there is some kind of cell on Mike's teardown video in the bottom right corner near the barcode. It is soldered in so presumably it is rechargeable? Not cracking mine open to check though...
« Last Edit: November 30, 2018, 08:43:21 pm by tsman »
The following users thanked this post: hammy
Offline exe
« Reply #289 on: December 01, 2018, 09:31:49 am »
Ah, that's very typical in Russia. There are some legal requirements for equipment to have some national certificates and to be listed in local lists of "approved equipment". Because of this one can't just buy a Siglent/Rigol/whatever for any "serious" work (esp. if doing development for government). So, companies rebadge equipment, certify it, and sell as their own. Another company trying to sell same equipment probably would need to have a separate certificate.
Sometimes rebadged equipment comes with local calibration certificates (foreign certificates are not valid, if I'm not mistaken, as they are not certified by the state).
The following users thanked this post: tsman
Offline casinada
« Reply #290 on: December 01, 2018, 09:44:53 pm »
http://www.tmatlantic.com/  has been selling AktaKom rebranded equipment for years. They're based in Miami Florida USA.
Offline exe
« Reply #291 on: December 02, 2018, 04:27:54 pm »
Uhm, interesting. I thought it's a local Russian brand (based on search in google, but turned out results highly depends on location). Still, aktakom.com and tmatlantic.com are on the same server. This makes me thinking the whole purpose of tmatlantic.com is to promote aktakom.
$ host aktakom.com
aktakom.com has address 205.178.136.10
$ host tmatlantic.com
tmatlantic.com has address 205.178.136.10
Offline edsjac
  • Country: br
« Reply #292 on: January 05, 2019, 04:09:02 pm »
Micsig support could inform when a new firmware is released. In addition, it could also explain the improvements implemented in each firmware. It would be good to decide to upgrade or not.
Offline hgjdwx
« Reply #293 on: January 07, 2019, 01:19:55 am »
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
« Last Edit: January 07, 2019, 07:26:27 am by Simon »
Offline tsman
« Reply #294 on: January 07, 2019, 01:39:00 am »
[quoted link to review removed since the original post was removed - tsman]
Hmm. Interesting. I wonder how well the Android firmware will work and whether they'll backport it to the older TO1000s.
« Last Edit: January 07, 2019, 12:18:09 pm by tsman »
Offline exe
« Reply #295 on: January 07, 2019, 11:10:32 am »
The original message was deleted,but if the question is "does it support to1104", then I can say I tried it about a year ago and it worked. But I don't trust software that is not on google play.
Offline tsman
« Reply #296 on: January 07, 2019, 12:16:52 pm »
Nah. I'm not talking about the remote control app. hgjdwx wrote a review of a STO1000 on a Chinese forum and mentioned that it ran Linux but it was going to get Android based firmware instead at some point.
hgjdwx's link was to a review of a Micsig STO1000 they wrote  :-//
Offline exe
« Reply #297 on: January 07, 2019, 12:52:43 pm »
Ah, STO1000 ... TO1000 series has only 256Mb RAM for applications (not to be confused with  separate 1Gb or so for acquisition or something). I'd say it's not enough :(.
Offline TK
« Reply #298 on: January 07, 2019, 12:54:06 pm »
The link was to a chinese website selling accessories or apps for smartphones
Offline tsman
« Reply #299 on: January 07, 2019, 12:58:50 pm »
It was definitely a review of a STO1104C when I looked at it  :-//
« Last Edit: January 07, 2019, 01:09:07 pm by tsman »
