1: Immediately erases the screen and starts from left side again with changed vertical position.
or
2: Immediately stops the horizontal trace scan and lets you move what was on the screen up and down. Once you stop, it resets and starts from the left.
or
3: It lets you move trace up and down while simultaneously keep scanning to the right like nothing is happening (except vertical movement, of course)
Thank you.
If you sweep at from 0.5 sec/div and slower my 80's LeCroy 7200 will erase the screen while adjusting, then start to fill the screen from the right to the left (roll mode). At 0.2 and faster, the screen will display the last data set and return sweeping (left to right) once you stop adjusting. With the LeCroy 64Xi, no matter if you use the roll mode or not, the screen will show the last data set. If you display more than one trace, all traces will show the last data collected while adjusting and resume when you stop fiddling.
I assume my Wavemaster behaves the same as the 64Xi, as they both use the same basic software.
Of course, as you crank these scopes up, the time that they restart is much quicker. So fast that you may not think they stopped but they have.
Has any of this ever been a concern for me, nope. It's obviously different than the old analog days. Back then for digital storage, I designed and built a circuit that allowed me to capture the waveforms then play them back to the analog scope. As shown, channel 1 (yellow) is the waveform and channel 2 is the trigger. The circuit just keeps dumping the waveform and they trigger keeps it in sync. You can scroll through the waveform using the delayed trigger output. Because you may want to capture say a 10 second transient, and the analog scope is not going to have the persistence to show squat, the box allows you to change the data rate to the scope. So maybe you capture at 1Hz but you play back at 100kHz. You can also change the gain and what not. There was also a printer port but this only supports what ever dot matrix graphic printer I owned at that time. There was however an RS232 port and I wrote some software for the PC to download and graph the data. No doubt in assembler back then.
The fun part with it is that it can output a fairly high voltage with a bit of current. Enough to drive say a small motor or a transformer. So, you could create some custom transient and dump it like an Arb but with a bit more power behind it. Funny is the thing still turns on. Its all wire wrapped.
... Oh right, there was a point to this. Because it was driving an analog scope, I always output the waveform (to keep the display refreshed, again no persistence) no matter what you did with the interface. I suppose back then, I was thinking things should work like the scopes of the time.
tried to clear up some of my mess...
