Author Topic: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)  (Read 828377 times)
Offline xorbe
Re: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)
« Reply #550 on: April 06, 2022, 04:50:15 pm »
UNI-T UT533 column Accuracy, should that be 09 instead of 90?
https://www.tester.co.uk/uni-t-ut533-insulation-resistance-multimeter
DC Voltage (v) 60mV/600mV/6V/60V/600V/1000V ±(0.09%+6)
Offline marklein
« Reply #551 on: May 01, 2022, 09:34:18 pm »
Ok who's the genius that password protected the spreadsheet so I can't actually use Excel to analyze the data??
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #552 on: May 01, 2022, 11:43:34 pm »
The author did that. Since it is a free resource, be more respectful of someone else's time and effort - especially if you don't know the reasons.
The following users thanked this post: Markus2801A
Offline trebejo
« Reply #553 on: May 04, 2022, 09:58:49 pm »
Thank you for this wonderful reference, I have used it quite a bit.
I think the Keithley 196 DC current accuracy is incorrect. According to the datasheet, it is 0.09%, but on the spreadsheet it is listed as 0.9%.
That  would change its color from amber to white, as with the 193A.
Offline miegapele
  • Country: lt
« Reply #554 on: June 11, 2022, 11:41:33 am »
Few mistakes from meters I have:
AV4 should have 1uV resolution, not 10.
AN870 should have 0.05% DC accuracy and 10nA should be green, nA acc also should be green(?).
RM303 could be added (20000 count, 0.05%) and all 6000 count Chinese specials probably do not deserve to be in the list, there is too many of them these days.
Offline wfaulk
« Reply #555 on: September 20, 2022, 10:13:01 pm »
The handheld multimeter spreadsheet I downloaded says "Edition: 12-Jul 2017" in the upper right corner. Am I looking at the right thing?
Offline joel96
« Reply #556 on: November 26, 2022, 05:47:00 pm »
I'm trying to use the spreadsheet to pick a multimeter out for automobile usage. I noticed the list doesn't include clamp meters, although I know it's possible to spend another $100-200 USD on a hall effect attachment. I also noticed that the maximum voltage and amperage isn't listed, as far as I could tell; for most gasoline or diesel cars, the maximum voltage you're going to run into is 24V (12V for my specific car) and 120A for the alternator fuse (other fuses are 20-30A). As far as I could tell, the maximum for most of the products on the list was 10A, which is too low for my use case. Is there another resource I can use similar to this one that includes maximum A/V figures, especially for meters with built-in clamps? Thank you for making this spreadsheet and for any advice.
I took an attempt at filling out the fields for one meter, but I don't understand how a lot of the fields are meant to be completed.
https://docs.google.com/spreadsheets/d/1WSny1ZfRFrUGQkNDMVRiZ-_DMdDsrKqmf2h4BnY0hTA/edit?usp=sharing
« Last Edit: November 27, 2022, 04:29:24 am by joel96 »
Offline n4u
« Reply #557 on: April 09, 2023, 07:45:06 am »
Nice chart. IMO voltage ratings would be helpfull (i almost bought pc7000 but there is only 10V on duty etc)
Offline Bzzz
  • shoving atoms
    • Wan Hung Lo Electronics Blog :)
« Reply #558 on: July 15, 2023, 07:42:08 pm »
Sorry for the unnecessary reply, but the forum is broken and I cannot subscribe to this topic any other way...  :-\
Offline omar9K
« Reply #559 on: September 21, 2023, 09:23:25 pm »
Does anyone know how to download the current files? The first post says the last update was in March of 2021. When I download the handheld meter file, tho, the heading says "Edition: 12-Jul 2017", more than five years ago. Lots of interesting meters are missing, and many obsolete (discontinued) meters are still present.
Offline ballsystemlord
« Reply #560 on: October 13, 2023, 11:20:42 pm »
I understand how this wouldn't be obvious, but the "last edit" is for the post being edited. *Not* for the list being updated.
That being said, it does look to be in bad need of an update, I probably wouldn't have the time to do such an update myself, though I am drawn to the idea... I think I'd post it on gitlab or something so that it could be updated by the community instead of depending on one person.
« Reply #561 on: October 13, 2023, 11:22:57 pm »
Does anyone know where the pricing info for the DMM list came from? Was it new or used? I ask because pricing I'm finding is significantly higher, like 300% or more for some of these meters -- and I'm talking about the ones that are still in production.
EDIT: It occurred to me after the fact that my comment might be misinterpreted as asking for an update in the pricing category of the table. Though certainly accuracy in pricing is important, the data as is has some historical value if it's the MSRP.
« Last Edit: October 19, 2023, 07:24:35 pm by ballsystemlord »
Offline homfencing
    • https://homfencing.com/
« Reply #562 on: December 06, 2023, 07:36:42 am »
Wow!   That took a lot of work!  With reference to my other post...what column denotes the sampling rate?
Offline 3PinFanHeader
  • Country: is
« Reply #563 on: April 07, 2024, 08:50:08 pm »
Owon's XDM 1041 is painfully missing from the list :) They advertise it as a "True RMS DMM" and at least for what I've been using it, it has been my bang for the buck. I'm not knowledgable enough to have all the info needed - but if there's some standard test I can do to add it to the list I'd be happy to oblige.
