Only thing is that the 7A22 is missing the pull tab.SOME of the old analog scopes definitely have nice to have features but how many analog scopes out there you can find with 10uV/div sensitivity?
This side of the pond ie. tek 7000 is nearly impossible to find, I have yet to see mainframe scope in their natural habitat. Your situation in US might be better.
Back then I had to use external preamp with my analog tek 475 and still have to use external preamp with my current DSO.
unless you find one locally it would be too expensive to ship.
Well I did move the 7A13 to my 7603 because the screen is bigger than the 7613.
And I fed it a 26MHz 4Vpp signal, because at 1KHz you have all the time to sample that. Also because the only FG I have (Tek FG504) gave up it's magic smoke and my attempts to fix it have not succeeded yet. (Back plane transistor failed taking out who knows what on the module, fixed the backplane and replaced a on board fuse and more smoke came from somewhere else)
I know, they do make mainframes and modules that can go to a higher time base but the 7A13 is limited to 100MHz and the 7A22 which is nice that it can do 10uV per division, but is limited to 1MHz.
But then again at 10uV, 1 us per division should be plenty.
Btw I'll receive a 7A22 sometime this coming week since I did purchase it a few days ago along with a couple of dual trace amplifiers. Got all three for $12 a pop including shippingOnly thing is that the 7A22 is missing the pull tab.
Vertical amplifiers would be small enough for transport if there is a reasonably easy hack to use them on the dreaded DSO's
But one thing is for sure, my DSO is lying to me on the BW limiting to 100MHz because it seems it's only filtering part of the signal.
I do like both analog and digital scopes but I have no need for just an analog one because most of the things I do require time precision and memory to see all those fast bits going by on current protocols. No Ethernet nor USB yet and for that maybe an analog scope will be better than an expensive DSO that can do a good eye diagram, I know mine is slow as molasses for that task.
So here are some pictures merging both technologies and that shows my DSO is not filtering the signal:
Sorry they are not 100% squared because I didn't want to take time correcting for the angle of the 7603 picture, but it's close enough, and the truth is not in between those signals
BW ?
Not much beyond audio.
Check for shorted dipped tantalum capacitors in that FG504. Tek gear from that era was notorious for using short prone tantalum capacitors (those blue blobs that short can get hot and surprise).
About 100Mhz is pretty what the 7600 series will do The attraction of the 7603 is CRT display size. Using a wider BW plug-in will not increase the effective overall system BW. A 7603 or 7633 or 7623 makes a nice host for the 7A13, 7A22, 7A18 with the 7B53A dual time base. These also work well with the sampling, TDR, logic analyzer, digitizing vertical and spectrum analyzer plug ins. It's limitations is BW. IMO the ideal 7000 series is the 7904A and 7104 or if dual beam is needed 7844.
Careful if the pull tab is missing, that is the locking latch. If it is missing and the plug in is installed into a MF, it can get stuck and not fun to remove. Replace the pull tab, make a similar pull tab in place of the original or remove the locking latch parts and spring on the bottom of the plug-in.
If the dual trace verticals have what appears to be intermittent attenuators, I have the cure. The cure is not cleaning the switches alone. Let me know.
Bernice
7A22, 1Mhz, 10uV not just for audio.
The full BW image with notes. The near identical match of sweep linearity between the analog Tek and Digital Rigol says much about how good the sweep generator is in the 7B53A as they are near identical in length and overall linearity.
Great stuff Bernice. Thank you!
No longer will I think of that guy from Pirates of the Caribbean when I hear "Mr Gibbs"
I got a 7613 for under $50 and extra modules for about $12 a pop shipped and I already had a 7603. Nobody seems to want them because they are heavy and bulky and unless you find one locally it would be too expensive to ship.
The thing is that I don't know how usefull 10uV/div is at just 1MHz, but I guess I'll find out since I have a 7A22 heading my way.
Btw, my plan for the 7613 (rackmount) is to get it all nice and calibrated and giving it away to the local hackerspace. (That is if they want it, if they don't I'll see what I do with it). But I'm keeping the 7603 and of course the best modules.
There is a test request.
Would it be possible to connect one of the 7A13's input to the input of the Rigol's input to look for A/D switching and related digital switching noise coming out of the DSO's input?
Bernice
That worked a treat, so as long as my UNI-T is calibrated right I have the 7A13 agreeing with it, the HP E3615A is out of cal according to the Rigol and the UNI-T so I should calibrate it one of these days.There is a test request.
Bernice
Do I have to terminate them both? at the moment I can only find a single 50 Ohm terminator.
But if not I see nothing if I connect both inputs together with a 4ft coax, what am I expected to see? and do I have to do anything else other than just hooking both up together?
How much "stuff" was found on that power supply under test and how good was it's regulation?
This why the LeCroy-Teledyne_Premable diff amplifier add on is made today, for test like this. To think having this identical test capability for $20 USD? not too bad eh..
There are a LOT more test that can be done with the 7A13. Do make up a set of matched probes for it. The probes will need to be attenuation matched and frequency response matched and probe length matched. The goal is to preserve as much of the common mode performance at the 7A13's input connectors? Once the matched set of probes are found (shorter probe cable length is better if possible), make up a equal length of sizable copper braid for a ground strap with a banana plug on one end and a nice stout copper clip on the other end. Tie wrap all three together as a single bundle with the smallest grouping that fits at the 7A13 input connectors and the smallest reasonable grouping (about 6" probe spread or less if possible) at the probe end. This is done to help reduce field pick up and help preserve CMMR. Clip the ground strap to the DUT chassis ground and/or tie the probe ground leads together or keep them separate depending on what is needed for a specific test set up. Compensate each probe individually, then tie the probes together and drive them common mode. Tweak one of the probes to balance out CMMR as much as reasonable, It will never be ideal, but can be quite good.
No 50 ohm termination initially for that test. If switch noise or etc is found, then try adding the 50 ohm termination to see if there is any difference. Run the volts/div to 1mV at full BW if needed or possible.
Use a short a BNC cable as possible. Low capacitance matters here. Ideally, a much wider BW analog scope would be used with a FET probe to the DSO's input. Roll the input attenuator controls up/down and repeat with the other panel control to see if all that makes any difference.
Bernice
My purpose for the 7613 is to donate it to the local hackerspace, I still need to calibrate it and decide what modules to give with it.
Blimey, a bloke asks about buying an old Ford Cortina, which will do the job ok providing he can wield an oil can and a set of spanners and we get pages of discussion about the various merits of a Ford RS200 vs a Toyota GT86
I want to use the oscilloscope to measure the ripple at the output of a linear power supply.
The regulation was good, but the power supply displayed output was and has been off. I did rely on my DMM for accuracy.
I kind of didn't follow the instructions to the letter.
I did trim the voltage gain in the 7A13 to match what the DMM was reading, but once I did that, it tracked the power from 4 V to 0.01V just fine.
The Comparison Voltage higher digit rolls back on the higher digit but I just ensured that both knobs were at their full counterclockwise position.There are a LOT more test that can be done with the 7A13. Do make up a set of matched probes for it. The probes will need to be attenuation matched and frequency response matched and probe length matched. The goal is to preserve as much of the common mode performance at the 7A13's input connectors? Once the matched set of probes are found (shorter probe cable length is better if possible), make up a equal length of sizable copper braid for a ground strap with a banana plug on one end and a nice stout copper clip on the other end. Tie wrap all three together as a single bundle with the smallest grouping that fits at the 7A13 input connectors and the smallest reasonable grouping (about 6" probe spread or less if possible) at the probe end. This is done to help reduce field pick up and help preserve CMMR. Clip the ground strap to the DUT chassis ground and/or tie the probe ground leads together or keep them separate depending on what is needed for a specific test set up. Compensate each probe individually, then tie the probes together and drive them common mode. Tweak one of the probes to balance out CMMR as much as reasonable, It will never be ideal, but can be quite good.
I do have extra probes around and I always get them in pairs. I also have some old tek probes but not sure if I'll find two alike in my bag. As for copper braid I do have desoldering braid but I'm running short of it, maybe I should pick up more. But one thing what is CMRR used for in practicality? I guess I can look it up but it's late now so by the time you reply I might have read about it.No 50 ohm termination initially for that test. If switch noise or etc is found, then try adding the 50 ohm termination to see if there is any difference. Run the volts/div to 1mV at full BW if needed or possible.
Bernice
I do have a FET probe (7A11 but unsured of it's calibration, even if it has a green round sticker over a Rejected sticker with reason: Balance DC Noise Problem, dated 11/12/93), it's the middle module on the cleaned up 7613 scope. But it's late so it must wait.
Tomorrow back to work so I'm not sure how much time I'll have to check this.
*Electro-mechanical systems.
*HUGE array of sensors from microphones, hydrophones, optical sensors, vibration sensors and...
*Thermocouple effects including their time constants.
*Current sensing resistor testing.
*Dielectric testing of materials.
*Biological-electical phenomena.
*Chemical-elecrical phenomena.
*Power supply noise and regulation testing.
*Low noise amplifier design.
*Charge pump design.
*Frequency discriminator design.
And a whole lot more limited by imagination, creativity and a deep understanding of how to apply an instrument with these capabilities. Beyond all that, the specific measurement needs and how to gain accurate and useful information about the DUT becomes what matters.
Bernice
BW ?
