Author Topic: New ANENG Q1 9999 Counts ?  (Read 65035 times)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: New ANENG Q1 9999 Counts ?
« Reply #100 on: July 17, 2018, 01:05:08 am »
inspect for any broken traces, or start more detailed diagnostic and probing to see where is the problem
Offline badboygolf16v
« Reply #101 on: July 19, 2018, 08:16:06 pm »
Do these pics show anything? It all looks OK to me on visual inspection.
But I'm a complete newbie!
https://photos.app.goo.gl/R2y83iuwXzdf7zgJA
Online malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #102 on: July 19, 2018, 10:12:17 pm »
Hi
The resistor R38 is not populated and looks like it took some solder on the left pad:
https://photos.app.goo.gl/A2muwb8eSS4Ycx1x6
Is this correct on the new video?
If one can make knowledge flow than it will go from negative to positve , for real
« Reply #103 on: July 20, 2018, 08:00:42 pm »
Thanks for reply. R38 and R36 are not populated in the video.
I noticed that R30 is jumpered on my meter but is populated with a MELF resistor in the video....
Offline HKJ
    • Tests
« Reply #104 on: July 26, 2018, 05:40:27 pm »
I have written a review of this meter: https://lygte-info.dk/review/DMMAnengQ1%20UK.html
The following users thanked this post: rsjsouza, edavid, MacMeter
Offline nagkiller
  • Country: br
« Reply #105 on: September 23, 2018, 02:57:00 pm »
Greetings!
Recently I bought one of these because I found the reviews interesting.
Everything arrived okay, however, there is a mistake in reading capacitors.
Ex: 18uFx250V => The capacitance is 32uF ...
820uF x 2V5 => The capacitance is 1380uF ...
In another multimeter (Minipa ET-2075B) or some Nano values, capacitance is OK!!!
Does anyone else have this problem ???
« Last Edit: September 23, 2018, 03:01:28 pm by nagkiller »
Offline MiroS
« Reply #106 on: September 24, 2018, 10:00:25 am »
'Does anyone else have this problem'
Not me,  no more Aneng , simply no more :)
Offline all_repair
« Reply #107 on: September 26, 2018, 01:17:38 am »
I bought a few, so far all very good.  Now I don't have run around looking for the Fluke.
A lot of drop shipper selling online in English are not selling the best quality units.  You never know are they reselling rejects by buying at rock bottom price ( I think mostly they are).  I bought my first China-meter from drop shipper online and the meter failed almost immediately.  And that scare me off China branded product for a very long time.  After I took the pain to buy direct, I am hooked.  Sometime they might just replace item if they are shorted, but mostly the quantity and quality have no issue.  If there are some issue, it does not take long for the seller to issue refund with not much proof from my side, some just by taking my words at face-value.
Offline snoopy
    • Analog Precision
« Reply #108 on: September 26, 2018, 02:35:50 am »
I bought a Aneng 870 recently. What a great deal with 19999 count. It was better calibrated than my fluke 87 and measured favourable to my Agilent 34401. I would recommend this over the smaller meters with only 9999 counts ;)
cheers
Offline Fungus
« Reply #109 on: September 26, 2018, 09:14:19 am »
I always buy from the ANENG official store on Aliexpress.
https://www.aliexpress.com/store/group/Measurement-Analysis-Instruments/919484_511101598.html
(at least, I believe that's an official ANENG store)
Offline MiroS
« Reply #110 on: September 26, 2018, 11:39:46 am »
cheers
Nice joke mate :scared:, but please bear in mind that someone can take this  seriousely.
Offline Fungus
« Reply #111 on: September 26, 2018, 01:14:41 pm »
Why wouldn't it be accurate?
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #112 on: September 26, 2018, 02:59:55 pm »
Exactly; absolute accuracy has nothing to do with other aspects of the meter, including long-term accuracy, which is what I think you were thinking about when posted this. (but I may be wrong)
Offline MiroS
« Reply #113 on: September 26, 2018, 03:30:15 pm »
It cannot be very occurate by design and it is not, no question. Not only not occurate and pure design,  it has also bugs and is not safe. It is very expensive piece of plastic.
Offline ebastler
« Reply #114 on: September 26, 2018, 04:08:04 pm »
Yes, the Aneng meter is a total waste of time, and anyone even thinking of it is best avoided...
Err, remind me again why you are frequenting this thread?  :P
Offline Fungus
« Reply #115 on: September 26, 2018, 05:24:02 pm »
Dave seemed to think they were accurate enough:
Offline 001
  • Country: aq
« Reply #116 on: September 26, 2018, 06:06:01 pm »
what about new model?
Offline floobydust
« Reply #117 on: September 26, 2018, 06:08:13 pm »
A problem with everyone doing cheap chinese multimeter reviews is that nobody really tests the functions, as you do with software white-box testing.
Going through the ranges from bottom to top, I found cheezy my AN8008 in fine shape can't read 2mA AC, it's got a flat spot reading zero then jumps up. The 4-count window at zero also can get in your way. The capacitance calibration value is blindly copied from Uni-T, and needs to be different for the particular TVS used in the DMM.
Point is we trust these DMM's to work and the firmware is never great on the first rollout.
The following users thanked this post: 001
Offline HKJ
    • Tests
« Reply #118 on: September 26, 2018, 06:17:00 pm »
Of course the meter is tested, with 0.01% resistors and precision voltmeters.
Try using the mV range, the you problems is down to a few uV, anyway I would not complain about the meter zeroes a few count around zero especially not a few uV.
Offline Fungus
« Reply #119 on: September 26, 2018, 06:23:10 pm »
Dave mentioned several times in his video that the AN8008 lacks a proper mA range (and yes, it's a problem!)
Offline Fungus
« Reply #120 on: September 26, 2018, 06:24:34 pm »
It lacks functions. Spend a couple of $$ more and get an 860B+ instead.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #121 on: September 26, 2018, 08:59:53 pm »
You can put one in the pocket ... the aneng 302:
https://ebay.us/D3AieM
Offline Fungus
« Reply #122 on: September 26, 2018, 09:03:56 pm »
I've seen one of those, they're horrible. Ew!  :--
Proof that you can go too cheap.
(the case is the perfect size for an AN8008+probes though - nice snug fit!)
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #123 on: September 26, 2018, 09:32:06 pm »
well here is a tiny one with a lot of functions ...
BSIDE ZT302
https://ebay.us/A3r85e via @eBay
Or the one that does not hide them at all :P
Offline floobydust
« Reply #124 on: September 27, 2018, 01:54:26 am »
Precision spot checks do not cover oddball bugs. They get 9,999 counts out of the Hycon DMM chipset using a cute algorithm for oversampling and decimation, and noise blanking for the uV range. Autoranging screws up on ACV if there is a DC component, and you have to reboot it.
Try measure 1-2mA AC at 50-60Hz, I've never seen it tested in any reviews.
