Brymen had asked about using WireShark to see what was going on at the time the phone stops logging. This was the first time I have ever attempted to run WireShark with that NORDIC radio for an extended time. WireShark allows you to run in a mode where the display is not updated to ease the burden but because it can be a bit hit and miss getting it to track the meter, I keep the display active to monitor the traffic.
Surprisingly, it actually collected the entire set of data, from advertising, to logging on and sending the password, till the phone stopped updating. Luckly, it didn't take long. About 15 hours of data. At 5Hz, that's not too bad. 260,000 samples. But consider that BLE is actually sending data much faster. We end up with 3,616,815 packets. Most of them empty. That's a lot of data for WireShark to crunch but it worked!
I have sent everything to Brymen. Hopefully they are able to solve why Dave's phone along with my UNNECTO will no longer connect, along with this one last problem. I think once those two are solved, the rest is just fluff.
