Author Topic: New EEVblog BM786 Multimeter  (Read 242564 times)
Offline sonpul
  • Country: ua
Re: New EEVblog BM786 Multimeter
« Reply #675 on: January 29, 2025, 08:56:19 am »
But I want to say that I constantly and often forget to turn off the multimeter. And if the iAPO function suddenly started working, I would most likely be upset by this fact. Sometimes the probes are affected by interference, sometimes the probes are not disconnected from the measuring stand. But if it is strongly required, APO is disabled manually.
Offline EEVblogTopic starter
« Reply #676 on: January 29, 2025, 11:46:34 pm »
Here is what the BM235 manual says about intelligent APO:
IntelligentAuto-Power-Off (APO)
The Auto-Power-off (APO) mode turns the meter off automatically to extend battery life after approximately 32minutes of no specified activities, where applicable:
1)Rotary switch or push button operations
2)Significant measuring readings of above 8.5% of ranges
3)Non-OL readings for Resistance, Continuity or Diode function
4)Non-zero readings for Hz function
5)Electric field signal present for EF function
6)Significant movement indication as in Phase Rotation functions
In other  words,  the  meter  will  intelligently  avoid  entering  the  APO  mode  when  it  is under  normal  measurements
Other models have a somewhat different detail, but all have the general conclusion that APO won't kick in if the meter is being used - beyond just looking for button presses and switch movement.
Definitely not for the BM786, it will turn off after 30min of doing measurements. I think it resets if you change the range switch though.
« Reply #677 on: April 08, 2025, 02:39:53 am »
Brymen have decided to open the Bluetooth protocol  :-+
Here it is.
www.eevblog.com/files/BM780-Wireless-Communication-Protocol-r2.pdf
The following users thanked this post: Kean, Eltax1693, mwb1100
Offline slutsteg
« Reply #678 on: October 20, 2025, 12:24:32 pm »
Maybe a beginner question, but my Brymen BM786 doesn’t show the negative sign when I measure with the black lead on + and red on - (for example on a battery). It works in mV mode  the minus sign shows there but not in V mode. The segment test on startup shows the minus symbol, so the display seems fine.
I’ve tried switching from auto to manual range, same result.
Firmware version: 78608.
Anyone know why this happens?
Offline 2N3055
  • Country: hr
« Reply #679 on: October 20, 2025, 01:37:14 pm »
You have it in combined AC+DC mode. Switch to DC mode.
Dr. Richard W. Hamming
Offline slutsteg
« Reply #680 on: October 20, 2025, 07:51:33 pm »
Thanks than was it!!
The following users thanked this post: EEVblog, 2N3055
