Author Topic: New oscilloscope from Fnirsi DPOS350P  (Read 110035 times)
NikNik and 8 Guests are viewing this topic.
Offline picburner
Re: Low signal level problem Fnirsi DPOS350P
« Reply #700 on: November 28, 2025, 12:55:01 pm »
Need to 3D print desktop stand for it.
Unless you want a special one, it already has its own.
Offline Ivont
  • Country: bg
Re: New oscilloscope from Fnirsi DPOS350P
« Reply #701 on: November 29, 2025, 05:01:37 pm »
The board looks good.  Here it is. I wanted to show something but it won't upload.  Apparently they can't upload more than two photos.
« Last Edit: November 29, 2025, 05:36:35 pm by Ivont »
Fnirsi DPOS350P, DPOX180H.
Offline BillyO
« Reply #702 on: November 29, 2025, 05:07:19 pm »
The following users thanked this post: Ivont
Offline Ivont
  • Country: bg
« Reply #703 on: November 29, 2025, 10:10:05 pm »
If you can tell me what to do to get this miracle back.  Analysis of filters is useless.  He doesn't stop changing and shows what he wants.  I decided they should refund some of my money.  I bought it from their official AliExpress seller.
The following users thanked this post: mishail71
Offline mishail71
  • Country: ru
« Reply #704 on: November 30, 2025, 09:59:06 am »
I returned mine and crossed myself!!! While this is the attitude of the manufacturer (tech support), all their products are a waste of money for me. And a waste of nerves.
Offline PA2ER
    • Ham Radio PA2ER - Info about Ham radio
« Reply #705 on: November 30, 2025, 03:12:51 pm »
I'm curious, has anyone connected the oscilloscope's generator to a frequency counter?
In my case, and that of two friends, we have the following deviations:
@10 kHz +1.919 Hz
@50 kHz +9.603 Hz
@10 MHz +1.919 kHz
@50 MHz +9.603 kHz
This was measured with a Racal-Dana 1998, with external reference.
I've already sent an email to FNIRSI to ask if this is normal, but haven't received a response yet.
Offline BillyO
« Reply #706 on: November 30, 2025, 03:16:33 pm »
Return it.
Offline BillyO
« Reply #707 on: November 30, 2025, 03:33:12 pm »
@10 kHz +1.919 Hz
@50 kHz +9.603 Hz
@10 MHz +1.919 kHz
@50 MHz +9.603 kHz
Mine's the same:
10kHz = 10.002kHz
50kHz = 50.010kHz
1MHz = 1.0002MHz
5MHz = 5.0010MHz
10MHz = 10.002MHz
50MHz = 50.010MHz
HP 5302A with GPSDO ref.
So that's 0.02 % off.  They don't provide a specification, but 0.02% seems to be fine for this unit.
Online Aldo22
« Reply #708 on: November 30, 2025, 03:58:31 pm »
Why fine?
The AWG of the $150 Hantek can do better.
External measurement with the FY3224s.
Offline Grandchuck
« Reply #709 on: November 30, 2025, 04:35:50 pm »
Mine is about the same.  Opportunity for a tweak :P
Offline BillyO
« Reply #710 on: November 30, 2025, 04:39:15 pm »
Why fine?
My statement is based on my use cases.  If I need a precise frequency, I have much better devices for that.  With the little FNIRSI scope, all I use the generator for is to inject a signal for tracing or to see what is happening to the signal as it goes through a circuit (clipping, gross distortion, attenuation, amplification, loss, etc...).  Extreme frequency accuracy is immaterial in those cases.  I last used it to fix an audio amplifier.
Do you often need better that 0.02% yourself?
Online Aldo22
« Reply #711 on: November 30, 2025, 04:52:58 pm »
That doesn't matter.
An accurate device is preferable to an inaccurate one, especially if it is cheaper.
Above all, however, it shows that it is possible to deliver something better in this price range.
Offline BillyO
« Reply #712 on: November 30, 2025, 05:28:36 pm »
I wholeheartedly disagree.  If accuracy is not a concern, then accuracy is not as concern.  Plain and simple.  The rest is just bench racing and bragging rights.
My main generators and counters are all run off a $140 GPSDO which is accurate to a few parts per trillion (10-10 or better).  I win.
Online Aldo22
« Reply #713 on: November 30, 2025, 06:06:12 pm »
Non? Si! Oh!  :-DD
Do you understand French?
Offline BillyO
« Reply #714 on: November 30, 2025, 06:16:26 pm »
Non? Si! Oh!  :-DD
Une petit peu.
Très drôle !  :-DD
Offline PA2ER
« Reply #715 on: November 30, 2025, 06:20:28 pm »
Of course, it can't be compared to high-precision equipment, but let's be honest, 2 kHz off at 10 MHz isn't even useful for quick field diagnosis.
Offline BillyO
« Reply #716 on: November 30, 2025, 06:34:33 pm »
Can you give me an example of where it would be useless?
Besides, if you know it's off by a consistent amount, you can allow for that.  And it does seem to be very consistent across at least our 2 machines and possibly Grandchuck's too.
A simple 0.02% correction and now you have better than 10ppm.
« Last Edit: November 30, 2025, 06:56:39 pm by BillyO »
Offline Sorama
« Reply #717 on: November 30, 2025, 08:10:39 pm »
Offline PA2ER
« Reply #718 on: November 30, 2025, 08:25:39 pm »
The purpose of purchasing this scope was to be able to quickly diagnose SSB HF transceivers. But that's not possible with this deviation. I'd accept a deviation of +/- 100 Hz, but not this. It's a simple software adjustment.
Online Atlan
  • Country: sk
« Reply #719 on: November 30, 2025, 08:47:20 pm »
Programmers don't like this sentence. It may seem like a small change, but it can have far-reaching consequences :D
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
Offline PA2ER
« Reply #720 on: November 30, 2025, 10:21:39 pm »
It's not that difficult, and with no consequences, to subtract 0.01916% from the frequency, in the routine where you enter the frequency. After warming up, it's stable within 0.5 Hz. So it could be a good stable generator.
I'm looking forward to the firmware where this has been fixed.
« Last Edit: November 30, 2025, 10:24:58 pm by PA2ER »
Online PlainName
« Reply #721 on: November 30, 2025, 10:38:36 pm »
I think you bought the wrong tool for your requirements. Kind of like buying a bicycle to go shopping.
Offline BillyO
« Reply #722 on: November 30, 2025, 11:32:59 pm »
It's not that difficult, and with no consequences, to subtract 0.01916% from the frequency...
It's also not difficult to enter it manually either.  Took me about 10 seconds to enter a 0.02% correction that brought the error down to 420Hz.  That should be fine for HF SSB work.  Take another 5 seconds and you'd down to 20Hz.
I wouldn't hold my breath for that.
I'm I'm of wondering where most of the people on this site got their education.  Where I went, the University of Toronto, at least half of the 1st and 2nd years physics labs concerned them selves with the detection of, calculation of, and ways to deal with error.  There is always error, and it's not always easy to detect and deal with.  Simple systematic error like this is easy to detect and deal with.  For most purposes the 0.02% error is fine.  For others, like HF radio, it's easy to take the error out.  It's not like it's all over the map.  It's consistent and repeatable.  0.02084% for me and 0.01916% for you.  Enter the correction and enjoy accurate measurements.
Offline BillyO
« Reply #723 on: November 30, 2025, 11:37:14 pm »
Une un petit peu!
I make that mistake all the time.
Offline Ivont
  • Country: bg
« Reply #724 on: December 01, 2025, 11:24:50 am »
2708467-0The generator stops working when the battery is below the middle.  Battery drains fast.  Noisy fan.  Lots of noise when measuring filters, constantly changing readings.  When measuring frequency, play after the decimal point.  Shuts down for no reason.  it does not know when the battery is fully charged and when it is discharged.
« Last Edit: December 01, 2025, 11:49:20 am by Ivont »
