Purchased a handful of items from Fnirsi over the last decade..
* SG003A (Process signal meter)
* FNB58-BT (PD3.1 USB meter)
* HRM-10 (Resistance meter)
* LCR ST1 (LCR tweezer)
* DPS150 (PSU)
* DSO188 (Tiny Scope)
The only scope I purchased from Fnirsi is the DSO188, which is an older fellow from like 2015 (Daniu/Fnirsi) and likely intended as a "proof of tiny-concept" at just 40 grams (Was around 20 bucks back then)
https://lygte-info.dk/review/Equipment%20Oscilloscope%20DANIU%20DSO188%20UK.html
The other handful of Fnirsi products, I purchased over the years, are also relatively cheap products under 50US. but in general a positive experience, not least with their price in mind.
The Fnirsi product I have used the most is SG003A, as when working with Analog laser drivers (V) and PWM/TTL laser drivers. having that in a small programmable form factor, is quite convenient.
Been impressed how many features they packed into these process/signal meters.
SG-003A can also be handy if I wanna check single digits of mA and how well a given BNC clamp meter can decipher it.
(*9mA with a CC-65 current probe)
