Hello again!!!
Device issues... ((I have the latest firmware version installed.
Hopefully it will be fixed, and the appearance will match its capabilities.))))
1. Incorrect frequency readings when decreasing the grid resolution ((when the "peaks" merge into a band.
1a. Bandwidth is also limited at higher bit depths... Increasing the time per grid step (set the frequency in the generator to 1 MHz, I recommend 10 MHz or higher and 16 bits)) will be more noticeable.))) And increase the grid step after autotuning. I think you'll see everything.)
2. Only MAX and Min show stable and relatively reliable voltage readings. The others (AVG, VP, VPP) show them only when they are centered on the screen after autotuning, and pressing the "Center waveform diagrams" button brings them closer together...
_ The others show incorrectly; the data changes when moving the waveform diagrams up and down.
- AVG is the least accurate parameter. You can see these issues for yourself: I've attached screenshots below.
We'll wait for the manufacturer to resolve these issues. ))))
Despite all these issues, this is a pretty good device... it urgently needs these issues fixed!!!
