Hi, im looking to purchase a new bench power supply. Look for something with a minimum of 3 channels and a programmable output curve that can be configured on a windows PC.
So far ive narrowed it down to UNI-T UDP3305S-E or Siglent SPD3303X-E but im open to other suggestions.
From these two it seems to be the Siglent SPD3303X-E thats the best choice due to fulle isolated outputs.
But before i make my choice i need to know whats the minimum time for changing the output voltage, i need to be able to go from 24v down to around 5v then up to 24v again after 200ms. The manual says nothing about a minimum time just a max of 99999s on the timers, has anybody tried too see what the minimum is on either of these two models?
The specification you are looking for is settling time. Technically, what is needed to have a specified fall time is an active load circuit which discharges the output capacitors to lower the voltage towards the new (lower) setpoint. The Uni-T UDP3305S-E has a specified settling time in the datasheet. The Siglent SPD3303X-E does not.
While that specification in UNI-T might look like they have better specified datasheet, it is just a poster number.
Useless in practice, unless you are measuring PSU loaded with active load at max current or unloaded PSU.
Also they don't specify what they mean, we can presume that they meant from 0 to Vmax to 1% accurate set voltage.
From their specification you can see exactly why I said that DUT is important. If DUT is pulling small current, UNI-T UDP3305S-E is clearly too slow for OP with 400ms down programming.
If DUT has it's own capacity on power input those numbers fall apart. These numbers are all about charging output capacitor in PSU. They do not mention how that changes with current limit as it will..I don't understand why it takes different time to charge up unloaded (max current available) than to discharge (where nominal current to load and down programmer together should discharge faster), here it is reverse.
Dynamically, those both have 50 µs load change regulation. They should both behave similarly in that regard.
Only thing that I see is that UNI-T UDP3305S-E has command processing time specified (at quite slow 100ms) and SPD3303X-E does not. But I think it won't be more than 100 ms.
So for the OP neither of these two can be recommended on the basis of the datasheet alone and without specifying DUT and protocol better. That is my opinion.
Many do not understand that most of these modern PSU, despite all the screens, software and such, are still 1-quadrant devices and they will have limited dynamic programming behaviour that will vary significantly depending on circumstances.
Only guaranteed spec will be load regulation response time.
Everything else needs to be characterised with actual DUT or realistic analog.
