Author Topic: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)  (Read 205457 times)
Offline tunkTopic starter
  • Country: no
Offline vk6zgo
Re: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)
« Reply #51 on: June 08, 2023, 02:59:27 am »
This is exactly what you will see with digital phosphor with any brand. Vertical line should NOT show up. That is what you would see in the good old analog days.
So they implemented their digital phosphor correctly.
Nope! the vertical line does show up----it is less visible because the beam spends much less time tracing out that transition.
Wind up the intensity on an analog 'scope & you will see it.
Offline NoMoreMagicSmoke
« Reply #52 on: June 08, 2023, 04:04:12 am »
The specifications don't make sense on this. It states rise time of 2.5ns and a bandwidth of 180MHz. BUT a 2.5ns rise time indicates a bandwidth of only 140MHz. Vertical sensitivity looks better than most at 5mV, but then horizontal timebase only goes down to 5nS which is less than half the resolution of similar scopes.
Overall, the number of features looks impressive. Being a Fnirsi, I suspect there were some liberties taken with the specifications.
Offline RAPo
« Reply #53 on: June 13, 2023, 03:16:32 pm »
I asked for a description of the .wav file (the file that contains the data if you press SAVEP.
Answer: "Sorry, we don't have a .wav file, the technician didn't share it with us".
(I'll know that there are some github repo's doing this, but they are not for the DPOX.
So I asked: "Why does your technician not want that the users use the data that (S)He provides?"
Online Aldo22
« Reply #54 on: June 13, 2023, 03:28:19 pm »
I would assume it is the general WAV (Waveform Audio File Format) format.
Isn't it?
Offline RAPo
« Reply #55 on: June 13, 2023, 03:34:10 pm »
No!!
Offline trmntr
  • Country: by
  • nice vibe
« Reply #56 on: June 13, 2023, 04:15:23 pm »
Complain about the absence (not display) of the vertical lines of the waveforms.  Is this a bug?
Offline RAPo
« Reply #57 on: June 13, 2023, 04:49:37 pm »
See https://github.com/roberttidey/FNISR1013DScope for a description of. Wav file as generated by a 1013d scope.
Offline RAPo
« Reply #58 on: June 13, 2023, 06:11:32 pm »
Well, you have to crank up the intensity in the old days. With the dpoxh you have to crank up the zoom.
The following users thanked this post: trmntr
Offline trmntr
  • Country: by
  • nice vibe
« Reply #59 on: June 13, 2023, 07:43:22 pm »
Are there really no other settings so that the waveform in normal mode is completely visible on the same meander without magnification?
Offline RAPo
« Reply #60 on: June 14, 2023, 06:07:42 pm »
well they respond quickly, but for now its is a no:
I understand how you feel;
Some documents are technical secrets; About the particularity of the product;
We are temporarily unable to obtain the document;
Thank you for your patience and tolerance with us;
Offline plazma
    • Homepage
« Reply #61 on: June 20, 2023, 02:57:08 pm »
Does anyone else have an offset problem with the signal generator output?
My unit got a 300-400mV offset.
Offline RAPo
« Reply #62 on: June 20, 2023, 03:38:27 pm »
My values are as indicated in the picture.
The following users thanked this post: plazma
Online radiolistener
  • Country: Earth
« Reply #63 on: June 20, 2023, 09:21:22 pm »
Some people complain that you don't see vertical lines with square waves.
What do you think?
Bug or feature?
it depends on horizontal resolution setting. If you're using slow horizontal resolution, the rise edge is too fast, so it will not be noticed. But it will appears when you switch to a fast horizontal resolution, for example 5 ns/div.
WAV file is a standard container to store waveform data as a data chunks, it also allows to store additional information in a custom defined data chunks. Here is WAV format description: http://soundfile.sapp.org/doc/WaveFormat/
If it supports save to a WAV file it's nice feature, because standard WAV file can be opened and analyzed with variety of software tools.
Just wonder, how much samples it can capture to a WAV file at once?
« Last Edit: June 20, 2023, 09:27:54 pm by radiolistener »
  • Country: Earth
« Reply #64 on: June 21, 2023, 12:17:39 am »
it seems that you have that FNIRSI DPOX180H device. Could you please share results for some tests? It will allow us to find the actual sample rate, bandwidth, ADC resolution and noise floor for this device.
Please give me WAV file taken on your FNIRSI DPOX180H for the following conditions:
1) open input at max horizontal resolution (just disconnect probe from BNC and take WAV snapshot at 5 ns/div)
2) 1-10 MHz clean sine taken with max horizontal resolution (5 ns/div) with amplitude about 80% from full display.
3) use the same sine and settings as on step 2, but increase sine amplitude 3x times, so that it cannot fit on the screen.
« Last Edit: June 21, 2023, 12:59:16 am by radiolistener »
The following users thanked this post: svetlov, Serg65536
Offline svetlov
  • Country: ru
« Reply #65 on: June 21, 2023, 06:48:49 am »
Dear RAPo ! you wrote that you will have a TinySA Ultra - could you use it to check the FNIRSI DPOX180H by applying a rectangular signal at high frequencies from 10 megahertz and above to its inputs, which is available on TinySA Ultra ?
Offline svetlov
  • Country: ru
« Reply #66 on: June 21, 2023, 07:10:07 am »
this screenshot shows that Rigol shows large surges on the leading and trailing fronts on a square wave in amplitude almost in the entire cell - but Fnirshi does not see him
Offline RAPo
« Reply #67 on: June 21, 2023, 11:22:38 am »
will do that tomorrow.
Offline RAPo
« Reply #68 on: June 21, 2023, 11:24:03 am »
Will do that tomorrow. Today is a busy day at work :(
Offline svetlov
  • Country: ru
« Reply #69 on: June 21, 2023, 09:31:47 pm »
here in real life  :palm:
Offline IconicPCB
« Reply #70 on: June 22, 2023, 02:04:52 am »
Sample rate of 500MHz is less than three times the specified band width.
BAD SPECMANSHIP
For a bandwidth of 180MHz the sample rte should ideally be much closer to 10 x the bandwidth
  • Country: Earth
« Reply #71 on: June 22, 2023, 03:00:26 am »
Can someone take WAV snapshots on Fnirsi DPOX180H with open BNC port and with some sine on input at 5 or 10 ns/div? Please share it here for analysis.
Offline mebel
« Reply #72 on: June 22, 2023, 04:59:07 am »
Mine seems do not have this problem.
The following users thanked this post: plazma, artik
Offline plazma
    • Homepage
« Reply #73 on: June 22, 2023, 05:26:03 am »
Has anyone found a way to change the signal generator amplitude and offset?
Or is it supposed to be centered around 0V as in the above post and users manual?
Offline plazma
    • Homepage
« Reply #74 on: June 22, 2023, 06:21:48 am »
Can you try again in DC input mode? Your unit is in AC mode.
