Well, you have to crank up the intensity in the old days. With the dpoxh you have to crank up the zoom.
it seems that you have that FNIRSI DPOX180H device. Could you please share results for some tests? It will allow us to find the actual sample rate, bandwidth, ADC resolution and noise floor for this device.
Please give me WAV file taken on your FNIRSI DPOX180H for the following conditions:
1) open input at max horizontal resolution (just disconnect probe from BNC and take WAV snapshot at 5 ns/div)
2) 1-10 MHz clean sine taken with max horizontal resolution (5 ns/div) with amplitude about 80% from full display.
3) use the same sine and settings as on step 2, but increase sine amplitude 3x times, so that it cannot fit on the screen.
