Author Topic: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)  (Read 547955 times)
Offline Spirex
  • Country: ru
Re: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)
« Reply #675 on: September 29, 2024, 06:28:40 pm »
What is the capacity of the battery, who measured?
Offline matefon
  • Country: hu
« Reply #676 on: September 29, 2024, 09:45:28 pm »
Didn't measure, but this is the label:
The following users thanked this post: Spirex
Offline Spirex
  • Country: ru
« Reply #677 on: September 30, 2024, 10:49:02 am »
Measured the actual battery capacity, 2750 mA/h, resistance 79 mΩ.
The following users thanked this post: MHTSOS
Offline Astur_TorQue
« Reply #678 on: October 01, 2024, 01:45:17 am »
How do you measure?
Offline wedgehog
« Reply #679 on: October 01, 2024, 03:29:08 pm »
I just loaded Firmware 1.4.2 and now it completely ignores the Auto Off setting and just turns off after a few minutes  |O
Offline apollo11fan
« Reply #680 on: October 01, 2024, 04:54:10 pm »
Have companies forgotten about regression testing? Seems ZOYI, or the contractors they have programming the device fix or enhance one thing, and break something else with regularity. Some of you should offer up your services as regression testers. I wrote this before: this product could be really great, but some entity needs to take control of their SW development, test and validation processes. :palm:
The following users thanked this post: 4thDoctorWhoFan, wedgehog, Aldo22, maxmatteo
Offline Spirex
  • Country: ru
« Reply #681 on: October 01, 2024, 05:22:44 pm »
It definitely turns off, maybe the backlight turns off after 120 seconds? which is turned on in the menu in oscilloscope mode.
The following users thanked this post: wedgehog
Offline wedgehog
« Reply #682 on: October 01, 2024, 05:32:38 pm »
I know it's doing my head in, every few minutes I have to turn the damn thing back on, I mentioned it to a chap who I think works at Zoyi, on one of his Youtube vids, I dodn't know if he will take any notice of me.
The following users thanked this post: apollo11fan
Offline csuhi17
  • Country: hu
« Reply #683 on: October 01, 2024, 05:55:18 pm »
reset the device.  set the black screen setting to 0.  or off I don't remember.  and automatic shutdown.  turn it off.  two separate settings.
Fnirsi oscilloscope = waste&regret
or maybe I was wrong
Offline indman
  • Country: by
« Reply #684 on: October 01, 2024, 05:56:15 pm »
I also have firmware 1.4.2 loaded and I don't see any problems with the unit auto shutting off.
There are 2 settings in the menu:
AutoOff and BLtime
Set AutoOff - OFF and BLTime - OFF and check if the unit turns off with these settings?
If I set AutoOff - 1min, then exactly after 1 minute the device signals "AutomaticShutdown" on the display and turns off.
« Last Edit: October 01, 2024, 06:03:55 pm by indman »
Offline wedgehog
« Reply #685 on: October 01, 2024, 05:57:02 pm »
Black screen setting? where's that, I will gladly try it mate
Offline csuhi17
  • Country: hu
« Reply #686 on: October 01, 2024, 06:01:46 pm »
BLTime  ;D
 suddenly I couldn't remember what it was called.  I write with Google Translate from my phone at work.:palm:
Offline wedgehog
« Reply #687 on: October 01, 2024, 06:11:40 pm »
No problem mate, but where is it? all I can see is Backlight in percentages and it just turns the brightness up and down, are we talking Multi-meter menu's or scope menu's?
Offline wedgehog
« Reply #688 on: October 01, 2024, 06:14:51 pm »
Ok, I found it, in the scope meu's, I have set them both to off and have it beside me will wait and see, thanks guys
Offline wedgehog
« Reply #689 on: October 01, 2024, 06:24:22 pm »
Looks like that's got it, Thanks  Guys, this is why I love forums  :-+
Offline xfint34
« Reply #690 on: October 01, 2024, 09:12:08 pm »
It would make more sense if the setting for backlight time was next to backlight brightness.
Offline apollo11fan
« Reply #691 on: October 01, 2024, 11:41:53 pm »
OK, good it's not broken. Just a usability design issue. Yeah, that is the sort of thing that can also benefit from some expertise in user interface design to make our interactions with the device more obvious and natural.
Offline m72
  • Country: ru
« Reply #692 on: October 03, 2024, 10:42:50 am »
Trigger in version 1.4.2 does not work with time scale 250ns/div and less. So I can't observe 100-200-400ns pulses in good resolution.
It worked fine before... Amazing device...
« Last Edit: October 03, 2024, 10:54:54 am by m72 »
Offline indman
  • Country: by
« Reply #693 on: October 03, 2024, 11:39:07 am »
I can't confirm your conclusions. On my device with version 1.4.2, the trigger works normally over the entire duration range.
Show your video of the malfunction?
Offline koks1960
  • Country: ru
« Reply #694 on: October 03, 2024, 12:00:09 pm »
Yes, the trigger does not work correctly in these modes. The pulse is displayed, but outside the screen. You have to search with the MOVE button.
The following users thanked this post: m72
Offline koks1960
  • Country: ru
« Reply #695 on: October 03, 2024, 01:23:14 pm »
I checked all firmware versions, the trigger works correctly only version 1.3.8
Offline koks1960
  • Country: ru
« Reply #696 on: October 03, 2024, 01:31:12 pm »
Give one pulse 1-10 uS. And you won't see him. He will be behind the screen.
Offline indman
  • Country: by
« Reply #697 on: October 03, 2024, 02:17:45 pm »
Yes, now I see the poor performance of the trigger. On version 1.3.8, the trigger operation is more reliable, so for now we will remain on this version. :)
Offline Edmiri
  • Country: al
« Reply #698 on: October 05, 2024, 12:32:14 am »
Where do you get old versions?
Offline koks1960
  • Country: ru
« Reply #699 on: October 05, 2024, 02:17:30 am »
Look at page 20.
