Author Topic: ngscopeclient - Ultimate acquisition software / protocol decoder / debug tool ?  (Read 31960 times)
Offline Antonio90
Hi Antonio90 ,
The console says something about the scope answering "welcome to SDS824X HD" after asking for an ID.
I think SDS800X HD support as not yet been merged to ngscopeclient (it is in scopehal git repo, but the ngscopeclient sub-module does not point to the latest commit).
You need to either wait for Andrew to update the dependency or to manually checkout master branch of scopehal repo.
This might be the case. Unfortunately I don't really know what I'm doing, just following documentation step by step, so I'll wait.
Offline azonenberg
    • Antikernel Labs
Then the terminal just returns "ERROR: Unknown scope type"
Try again with the latest version on git, should have the 800 series support merged?
Offline Antonio90
Thanks! Compiling now.
EDIT: Compiled and working (on Windows still). Thank you very much Andrew and @fredo_! Will test more tomorrow, it's already 1:45 AM here, and I need sleep. The "filter" section with the block programming interface is just genius BTW, really impressive piece of software.
« Last Edit: September 14, 2024, 11:46:47 pm by Antonio90 »
The following users thanked this post: egonotto, Protegimus, fredo_
Offline fredo_Topic starter
it's already 1:45 AM here, and I need sleep..
Same here, time to go to bed!
Offline Furna
  • I still don't know
Try
cd build
cmake --build . -j4
Hello,
Thanks it compiles now, but it's taking quite a while.
The "-j4" tells the compiler (ninja) to use 4 cores on your PC.
It is more than probable that your PC has more than 4 cores.
ninja by default uses all your available cores.
In short run "cmake --build ." without the "j" switch.
Please note that cmake in turn runs ninja => just run "ninja" as fredo_ suggested and advised in the yet unpublished doc mentioned by azonenberg
Best regards
egonotto
PS: Now it's ready. But my SDS3000X HD is not recognized correctly via LAN.
Yup it is merged and seems to work.
I just cloned and compiled from scratch and  Siglent SDS824X HD is recognized ... I didn't try yet to really take a capture.
Wil let you know when I had it tested better.
The sky above the port was the color of television, tuned to a dead channel.
Offline skander36
Windows version has some sudden closes. Still a lot of work. Maybe the Linux version is more stable.
Anyway a notable and unique approach!
Offline azonenberg
    • Antikernel Labs
We're very interested in crash reports as people try on different setups. If you can attach a debugger and get a stack trace of where it died, we can see if that sheds any light on the situation.
Offline Furna
azonenberg, do you have a preferred debugger and/or na example for a debugger command?
I guess something available with MSYS2 (gdb?) can work?
Offline skander36
Maybe I will find some time to setup a debugger, as I don't had to deal until now with MSYS (I'm not a programmer). Usually the message that remains in console are errors of communication with the scopes as in pics attached.
Sometime R&S scope (RTB2002) get stuck while the others works.
Update with link to ngscopeclient Windows Installer
And on popular demand, here is a link to the ngscopeclient Windows installer (zip password is 'ngscopeclient').
/!\ Please be aware that you need a Vulkan compatible GPU/video card to run ngoscopeclient. /!\
09/17/2024 Update (d2a1a2f)
  • Siglent SDS: Support for SDS800X HD, SDS1000X HD, SDS2000X Plus, SDS2000X HD, SDS3000X HD, SDS5000X, SDS6000A/L/Pro, SDS7000A models
  • Rigol DHO: Support for DHO800/900, DHO1000 and DHO4000.
  • Other hardware: see ngscopeclient site for a complete list of supported hardware.
Best,
Fredo.
Offline skander36
Hi @fredo_
For Windows installer ngscopeclient msi package, I get this error on launch. An invalid path to fonts. It is repairable by users but you may want to correct this in source installer.
Oops, that's bad !
Thanks for the heads up, let me check that.
[Edit]
Well I was not able to reproduce the problem unless I have a <userdir>\AppData\Roaming\ngscopeclient\preferences.yml from a previous install that points to wrong font paths.
@skander36 can check if the error message was not due to a preferences.yml file existing before your installation (which would be the case if you previously tried your own build) ?
« Last Edit: September 19, 2024, 05:07:32 pm by fredo_ »
The following users thanked this post: skander36
Offline skander36
Hi, I don't have drive D in my computer. Also /Home/fborry is not from me.
Attached is preferences.yml.
What else can I check?
My build is launching without problems.
Yeah that's the path of the source file (see "imgui__draw.cpp, line 2583" in your screenshot) on my build environnement (this is a debug build), not to be confused with the path to look the fonts for.
Maybe try and remove or rename your preferences.yml file and launch the installed ngscopeclient, it should fix the problem.
Offline skander36
Ok, that was. Removing preferences.yml has allowed the installed version to launch. Now both instances can be launched.
Thank you!
The following users thanked this post: egonotto, fredo_
Updated ngscopeclient Windows Installer
Here is an updated version of ngscopeclient Windows installer (zip password is 'ngscopeclient') including LA support for Siglent SDS HD scopes.
09/21/2024 Update (dc26783)
Siglent SDS: Added support for Logic Analyzer.
« Last Edit: September 21, 2024, 07:53:04 am by fredo_ »
The following users thanked this post: egonotto, lapot2
Offline Furna
Works for SDS824X HD analog channels; unfortunately I have no LA to play with.
« Last Edit: September 21, 2024, 12:21:08 pm by Furna »
The following users thanked this post: fredo_
Offline voltsandjolts
The Rigol DHO1000 series have quite a rudimentary FFT implementation, which is a great shame as the frontend is quite good. It would be fantastic if ngscopeclient could implement FFT using raw data from scope and provide normal/peak/average spectrum - the features I miss the most on DHO1K.
Offline azonenberg
    • Antikernel Labs
We can do FFTs on input from any supported scope.
The FFT filter outputs only the FFT of the current input, but there are separate filters for peak holding and exponential moving average that can be applied to the output spectrum which in combination should give the behavior you want, I think.
The following users thanked this post: egonotto, voltsandjolts, fredo_
Offline azonenberg
    • Antikernel Labs
Thank you!
Yep you got hit by https://github.com/ngscopeclient/scopehal-apps/issues/707. We don't have a root cause but there's a fairly straightforward workaround we can do to at least avoid a crash when it happens. But there's a million other things I'm juggling and this one hasn't got to the top of the stack.
The following users thanked this post: egonotto, skander36, fredo_
Offline Bidi533
  • Country: li
Wow! Thank you very much for sharing this here and providing the pre-complied versions. I tried it quickly with my own DHO804 and it worked! Definitely keeping an eye out for future development of this project.
Offline MD1071
hey, software looks amazing. thanks for thr windows installer. I used the windows installed and got it running, however get issues when trying to add my rigol DS1054 scope over LAN. I'm able to ping thr scopes IP and it's good, I can get IDN? using python pyvisa too so seems like connection with my PC is good. However when I try to add it using ngscopeclient, I get three bad IDN warnings and then it terminates
I used the windows installer and it's the ngscopeclient 0.1-dev+dc26783 [DEBUG BUILD]
amI using the wrong version or something?
the path I used is scope IP : 5555
manual says rigol port is 5555
Edit: I tried with my Teledyne LeCroy scope via vicp and its successful. So could this be a Rigol or LAN issues?
« Last Edit: October 02, 2024, 05:54:46 pm by MD1071 »
Hi MD1071,
Thank you for testing and for the feedback :-)
Yes for Rigol you should be good with lan transport and ip:5555 for Path.
But the log message seems to indicate that there is no network connection with the scope :-/
Can you try and launch ngscopeclient with the following command line ?:
ngscopeclient.exe --debug --trace SCPISocketTransport --trace RigolOscilloscope
Offline MD1071
yeah sure I can try that and let you know
Offline eTobey
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
Wow, that looks awesome. I just found out, that my graphics card is just below the minimum requirement.  |O
If this tool would implement some features of the DSView software, id be amazed, and would even pay money for it. Especially multistage triggering and the measurement features (And of course, the triggerposition aligned with the time scale).
I have build some projects in the past, but since that is quite a task, i would not consider doing it again, unless it had the properties said above ;-).
« Last Edit: November 06, 2024, 10:19:38 am by eTobey »
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
Siglent SDS800X HD bugs/issues/workarounds (Partially updated 19. Nov 2026)
