I was able to compile ngscopeclient on a Raspberry Pi P500 with the latest Raspberry Pi OS (Debian 13, Trixie, Wayland/labwc).
After modifying 'RohdeSchwarzOscilloscope.cpp', I was able to read data from my RTB2004. However, many functions are missing from the file.
However, there are display problems, see the attached screenshots with the demo oscilloscope. When I set the environment variable and use software rendering, the display is fine: '$ SCOPEHAL_VULKAN_DEVICE_OVERRIDE=1 ./ngscopeclient'.
Can you pass options during compilation to fix the problem, or is it simply due to the Raspberry Pi?
Peter
