I just bought one from Amazon. It was shipped from China, but arrived in one week, instead of the usual 2+ weeks. It even cleared customs quickly.
I did open it. It looks just like the pictures posted here, but mine says V1.4. As the other post shows, it has two 4V batteries.
https://www.eevblog.com/forum/metrology/v-i-curve-tracer-component-tester/msg5802807/#msg5802807I mostly bought this for two reasons: it allows probing two devices for comparision; and the built-in screen, so it doesn't require a scope. For just one channel, I've already cobbled together a scope and siggen with a couple of resistors for a functional curve tracer.
On my scope, the sinewave output reads 8.8 Vpp. There is a very slight offset bump at the zero crossing point. The voltage level stays consistent at different output frequencies. The frequencies look to be decently accurate.
For curiosity, I wanted to see the smallest value cap that it would work with. Of course, I had to use the highest frequency. When set this high, the capacitance of the probes show the flat line as a very thin ellipse. With a 10-20 pf cap, you can just see the ellipse get a bit fatter.
I knew it wouldn't test most zeners, but I tried a variety that I had on hand. You just start to get a zener knee with a 4.7 V zener. For some reason, it displays better with the highest resistance setting, implying the lowest current. A 3.3 V zener displayed the full knee. So far, that's the only thing I would fault this device for - no higher voltages. I did see that the NI-210G has selectable voltages, but that requires a scope. I may look at getting one of those, later. Right now, it looks like I can only get one direct from China, and the pricing is a bit high. At least with Amazon, I can return things easily.
When in single channel mode, the blue jack outputs a relatively fast rising 5 V pulse (positive and negative) with an exponential decay, at regular intervals (I forgot to measure the time). In dual channel mode, you of course get a sinewave on both A & B for comparing two boards. The pot marked "ALT" only works in A/B mode to adjust the vertical position of the B trace.
It comes with two probes (red & black) and two alligator clip leads (red & black). I took a spare red probe and painted it blue, to use for the B channel. I will use the spare black probe for the second ground when using both channels.
The circuit board looks well made, with good soldering. I may have gotten a used device, as the screen is somewhat scratched. I'll see if the vendor will do anything about that.
I didn't charge it before playing with it. It read three bars. After about 15-20 minutes, it did an auto shutdown. I am charging it now, so I'll see if the battery meter is any more accurate, later. Unlike many devices, this actually charges from a USB-C to USB-C cable.
I may have more to say after I've used this in dual-channel mode. I actually have something that needs repairing now, which is why I bought this. I've never used a Huntron, but I thought I'd give this similar device a try. I don't know yet if I'll find it useful or not.
