Hello everyone,
I bought a DL3021 about two months back, but I haven't really had time to play with it until now...
When I first got the instrument I didn't notice anything obviously wrong with it (although I did not test it beyond turning it on and off a few times).
I finally got around running a few simple tests today and I noticed that the constant current mode is behaving odd.
- When entering the CC mode, the load is supposedly disabled (the
On/Off button and
Short buttons are not illuminated). I
assume there should be no (or very little) conduction between the inputs in this state.
- The display shows 0A current as expected, but the inputs are actually shorted and will draw (excessive) current when a power source is connected - the UI will stubbornly read 0A though.
- Pressing the
On/Off button to enable the load has no effect, the button illuminates, and the UI reflects the change, but the inputs remain shorted.
- The short can be removed by quickly toggling the
Short button (from initially
Off, to
On, back to
Off). Only a quick toggle (pretty much as fast as I can double tap the button) will work. Slowly toggling has no effect.
- Successfully toggling the
Short button will cause the load to start sinking it's set current, regardless of the state of the
On/Off button. Even when the button is in the
Off state, the load will still start drawing the set current after toggling
Short, the only difference being that the UI remains stuck at 0A again...
- Pressing the
On/Off button at this point brings back the short
CV mode appears to function correctly. Battery capacity measurement suffers from the same issues as CC mode (not that surprisingly, since they're probably closely related).
I figured this could be a firmware issue, it's Rigol after all
but the instrument was already running the latest version out of the box. In desperation I tried installing the latest firmware again - to no effect.
I'm running out of ideas here, except for just turning it in under warranty... Has anyone experienced similar problems with this instrument before? Maybe it's some silly menu option that I missed, or is this thing just broken?
