That statement should provoke the immune response
The standard statement seen all too often on this forum is that an entry-level Rigol scope is better than an old analogue scope. But is that really true for a common basic use-case: a beginner looking at bit-bashed outputs from a microprocessor?
Test setup:
- a low-end DevKit for a modern microprocessor[1], cost £12 from Digikey or Farnell
- a 1.5GHz Z0 probe connected across one processor I/O pin; that is sufficiently good that it won't affect the measurements
- bit-bashed single bit output in software
- Rigol DS1052E: borrowed, cost £275
- Tektronix 2465 scope: cost £84 and working, but I prophylactically replaced the mains X and Y filter capacitors
The first point to note is that the 80:20 transition times of the output is 1ns (90:10 is 1.8ns). Using the BW=0.35/tr rule-of-thumb, that implies a 350MHz scope is required to measure the risetime. Hence a 50MHz scope is completely inadequate when checking signal integrity of a modern microprocessor's outputs. There is absolutely no doubt about that, and no surprises either.
But if you (falsely) regard that as “esoteric”, what about bit-bashed outputs
using only the hardware inside the processor? It will be seen that low-end digitising scopes can be inadequate and/or misleading compared with cheaper old analogue scopes.
Before replying, please note my repeated statements elsewhere in the forum:
choose the right tool for the job. Occasionally a digitising scope is necessary, occasionally an old analogue scope is necessary,
frequently either are sufficient.
And yes, I
do know the reasons for the displays shown, and (where possible) which sequence of 5 buttons to press to get the expected traces. But would a beginner know? If not, what would their reaction be?
[1] for the curious, that low end XMOS microprocessor and DevKit can drive at least 4 I/O ports as shown in the tests, with
guaranteed timings down to 4ns resolution, while
simultaneously communicating with a host PC over a USB link. Not bad, and IMNSHO makes Arduino-class machines look anaemic.
