Thank you all for the input.
Thank you for the recommendations. I will check them out.
As far as budget - yes the $2300 retail hurt but there was the academic discount etc. so that helped. I was considering the MSO1074z but the extra functionality of the DS4014 seemed to be worth it even with more than double the price and the sacrifice of the Logic Analyzer. Plus the MSO is
100MHz 70MHz while the DS4014 is
500MHz 100Mhz. True, there is the DS4014E - a $400 cheaper, slightly crippled version - however it comes with cheaper probes. I watched a video (or was it an online article) where they showed how the high bandwidth was really important for accurate measurement even for much lower Hz signal than the oscilloscope max. The probes, they explained, are significant piece in that equation.
If you don't read your oscilloscope manual from front to back you might as well hold out on buying it. Because you will be reading a manual written very similar to your oscilloscope manual from front to back.
In order to get familiar with a lot of functions on the scope it might be useful to get a cheap low voltage isolated or battery powered signal/function generator, if you have an isolated bench supply to power it that works. They are dirt cheap on Ebay, worth it in crappy parts alone they start at $2!
As hinted above the most important thing to a new scope owner is ensuring you're not grounding a voltage/signal already above or below mains earth ground with the ground clip, or exceed any input specifications.
Here is the video Dave did on it.
I am planning on getting an AWG really soon - I know that paired with the oscilloscope it would be great learning tool. For now I am considering Siglent SDG2042X unless someone advises me otherwise.
(Rigol DP832 power supply is already on the way.)
Thanks for the link. I have watched this video before and was aware of the issue. Will watch it again before connecting anything.
