Author Topic: Oscilloscope noob  (Read 2487 times)
Offline Charlie86Topic starter
  • Country: io
Oscilloscope noob
« on: January 05, 2018, 08:39:18 pm »
Like I mention I am total noob in using Oscilloscope. Just bought Rigol DS1054Z to start learning. When I attache probe to point for probe calibration and press auto button I get nice square signal. But if i press auto button without probe attached to test point I get some noise signal. Is this normal?
https://imgur.com/a/lMYNK
Offline Paul Moir
Re: Oscilloscope noob
« Reply #1 on: January 05, 2018, 08:45:45 pm »
Yes.  When you press the Auto button the 'scope tries to detect what signal is present on the probe and adjust it's parameters to show you a display of it.  If it's only detecting noise, that's what it will display for you.
If you look closely at your two pictures, you'll see the top one has the horizontal timebase at 100us (micro seconds) per division while the second one is at 5.00ms per division.  That's a clue that they're completely different signals.  ;)
  • Country: io
« Reply #2 on: January 05, 2018, 08:57:43 pm »
Thank you very much for yours information.
Offline David Hess
  • DavidH
« Reply #3 on: January 06, 2018, 02:36:41 am »
The second signal looks like interference from a 50 Hz TRIAC phase control dimmer.
  • Country: io
« Reply #4 on: January 06, 2018, 08:58:08 pm »
Not shure about Triac interference, like I said I am beginner.
Have to more questions. What is default pass and user for web interface and what is best programs to communicate with oscilloscope.
Thank you
BR
Offline David Hess
  • DavidH
« Reply #5 on: January 07, 2018, 02:26:35 am »
Do you have a light dimmer somewhere nearby?  If so, try adjusting it while watching that waveform on the oscilloscope.
  • Country: io
« Reply #6 on: January 07, 2018, 01:24:30 pm »
I have 3 led bars under it, but even if I unplug them, noise is still on display.
