Hi, Total Newbie here
(Quite intro for all to understand properly)
As well total newbie regarding oscilloscopes (I haven't use any). Just got back from vacation (almost a month away from electronics). I am quite new to electronics (less than a year w/o mentor, just self study stuffs. Fell in love in electronics via arduino stuffs. Not a genius or smart but willing to understand stuffs as much as I can - so not so much familiar on deeper technical stuffs).
Since some people saw my potential (been trying my best) based on the small electronic stuffs I've done. I had given a project (someone started it but unable to finish it so - its my first big project yay!) where i need to integrate a lot of SPI based ICs (energy meter chip
CS5480) so yeah, its a energy monitoring system where they want me to use this devboard
pyboard v1.1 instead of arduino. A lot of folks here told me oscilloscope could help out since i could experience some glitches, etc on data transmission so it wouldn't hurt to have one since they give budget but of course, their not technical, etc. I've done research a lot for about 4 hours and now, been brain dead (confused)
So to make it short and simple. I'll summary what I know, have and what I'm dealing via enumeration;
What I'm dealing:
1) 2MHz CLKSPD SPI device (CS5480 datasheet pg14 as per SCLK, am I right? so this device can't go +25 Mbps as this
table on this
site)
2) 12MHz CLKSPD pyboard (uses this
MCU that could reach 168 MHz clock speed right? but on datasheet, only accommodates up to 26MHz crystal oscillator? has 12MHz based on
sch - Y2)
3) There'll be a time I'll be dealing with UART via RS-485 and this
Long Distance SPI-based IC where it can operate up to 1Mbps data transmission for long distance integration.
* The above are based on my understanding on
arduino uno - tech spec specification since it I use it a lot and knew it operates on 16MHz clock speed as its crystal oscillator is 16Mhz.
What I know and have:
1) SPI speed operates at 25Mbps at short distance but still based on the SPI device
2) UART speed operates at 20Kbps at 15m distance
3) Oscilloscope canvased so far as budget could:
Gratten DSO GA1102CAL,
MicSig TO1102 and
BK 2190E DSO (which could be enough for the project else what at least minimum spec needed for me to see the said serials)
*Above are the details why I need oscilloscope and I am for a fact bombarded by complicated stuffs that confused me unable to pinpoint what I need.. else TLDR? Minimum specification (bandwidth, channels, etc) of DSO for SPI, UART, I2C, etc for reading and consideration (still better if specs would be given instead of brand for me to canvas further on other oscilloscope).
