Judging by the circuit board, it would be easy to convert to a 3-phase system, at least from a hardware standpoint.
Theoretically that could work but without the proper firmware and calibration process it is impossible.
As both models are fairly priced it makes no sense to try it.
While I don't consider the OWH9811 to be a high precision instrument I think it is useful and quite well built in most parts.
It is built around two readily available power meter ICs, a micro controller and a front panel with a display.
The AC measurement part utilizes an Analog Devices ADE7880ACPZ polyphase multifunction energy metering IC with harmonic monitoring and one or three current transformers.
The AC+DC channel utilizes a TI ADS131M02 two-channel, 24-bit, 64-kSPS, simultaneous-sampling, delta-sigma ADC and a current shunt.
No part markings are sanded off and all parts look genuine.
Some other parts on the PCB are:
GigaDevice GD32F303CGT6 ARM Cortex-M4 microcontroller
NXP 74HC4052D Dual 4-channel analog multiplexers/demultiplexers
TI ISO6762 Six-Channel Digital Isolators
EL817C Photocouplers
At the serial port are:
TI ISO6721B dual channel digital isolator
3PEAK TPT3232E-SO3R RS232 transceiver
Dexu Electronics F0303S-1WM DC-DC converter
Two unpopulated SO-8 footprints probably are related to an optional RS485 interface.
