Author Topic: Owon SDS200 series entry level bench scope (September 2024)  (Read 7725 times)
Online tunkTopic starter
  • Country: no
« on: September 13, 2024, 02:06:20 pm »
- SDS210(S) 100 MHz, SDS215(S) 150 MHz, SDS220(S) 200 MHz
- 1 GS/s
- 2ns/div - 1000s/div
- 2mV/div - 10V/div
- max record length 20M
- "S" models have waveform generator:
  sine 25Mhz, ramp 1MHz, square/pulse/arbitrary 5MHz
- 7" screen, 480X800 pixels
https://eleshop.de/owon-sds210-oscilloscope.html
https://files.owon.com.cn/probook/SDS200_series_DSO_user_manual.pdf
Offline ataradov
    • Personal site
Re: Owon SDS200 series entry level bench scope (September 2024)
« Reply #1 on: September 13, 2024, 02:27:47 pm »
Looks like a barely updated SDS1102. But apart from the memory depth, it does not looks like much of an update. If they just want a newer SDS1102, then it is fine, I guess, but otherwise I don't see why bother.
It even uses the same plastic mold for the back cover as SDS1102. They just rearranged the front panel a bit, and made it worse, IMO.
I use SDS1102 as a main basic scope and it is quite good for what it is. It is silent (no fan at all) and boots instantly. The only thing that is really bad about it is the single trigger. Once it is triggered, re-triggering it is a lot of effort instead of a single button press. Realistically, if they fix just that I would really consider getting that. But I really doubt they did, the software looks pretty much the same.
« Last Edit: September 13, 2024, 02:38:45 pm by ataradov »
Alex
Offline viktor63
  • Country: ua
« Reply #2 on: November 22, 2024, 09:17:31 am »
There is a big advantage, it gives 1GSa/s on 2 channels simultaneously
Offline modoran
« Reply #3 on: November 22, 2024, 06:01:20 pm »
Only on 1kpoint memory ? It has 2Gsps ADC in it or it is just a trick ?
Offline viktor63
  • Country: ua
« Reply #4 on: November 23, 2024, 12:09:31 pm »
No information yet. I want to buy and see inside.
Offline Aldo22
« Reply #5 on: November 23, 2024, 01:59:38 pm »
The trigger options are somewhat poor, according to the manual.
Only types: Edge and Video. No external trigger. Holdoff only works from 100 ns.
The competition from Hantek has many more types: “Edge,Pulse,Video,Slope,Overtime,Window,Pattern,Interval,Delay,UART,LIN,CAN,SPI,IIC”.
That seems a bit old-fashioned with the Owon.
Offline jasonRF
« Reply #6 on: November 24, 2024, 02:20:35 pm »
The manual says a 2K FFT, so a little underwhelming. The signal generator option look interesting, and the sds210s (100 MHz w/ siggen) is only $190ish on aliexpress.
I usually use a usb scope because it is quiet and I get a large screen, but if I bought a bench scope it would probably be something like the sds1102 or this newer model as long as it is fanless.
Offline Doctorandus_P
« Reply #7 on: June 03, 2025, 10:28:25 pm »
I found this thread via a generic search for:
https://html.duckduckgo.com/html?q=SDS210+fan
For the complainers:
This SDS210 is an EUR210 scope. So don't complain that it's not the most powerful scope. At least it does not lie as the fnirsi garbage does.
I already have an Siglent SDS1104X-E, and I simply don't want to turn it on because it makes too much noise. I was thinking of buying one of the small Owon handhelds, or maybe the Hantek DSO2D15 (EUR280) simply because it does not have a fan. That new Batronix Magnova thing would also be nice, It's also a budget scope, but only if you have a budget of around EUR4800 in mind.
https://www.batronix.com/shop/oscilloscopes/Batronix-Magnova-BMO350.html
Offline kmoonwalker
« Reply #8 on: June 04, 2025, 12:12:27 am »
if you want things quiet - friend has XDS3104AE - fanless, it gets warm but can run all day long no problem (also cheaper models are usually fanless but not 100% certain if all of them)
Offline Aldo22
« Reply #9 on: June 04, 2025, 05:53:28 am »
The Hantek DSO2000 is available at a much lower price in the DSO2C10 version.
https://nl.aliexpress.com/item/1005003770453508.html
It has the same hardware.
Offline andrewpr
  • Country: cl
« Reply #10 on: August 17, 2025, 06:52:48 pm »
Hi, I'm thinking about buying this oscilloscope, I'm between this and the hantek (dso2d10), the thing is the hantek seems to be prone to bugs, and seems slow in video reviews, also, the sds210s is cheaper. Has anyone bought it?, and if so, it is slow/fast?, it really supports 100MHz? it has bugs?; if someone can make a small review I'll really appreciate it.
Offline mlero
« Reply #11 on: December 06, 2025, 05:21:25 pm »
After two hours of testing model SDS215S, I reported the return of the goods to the seller because this is not the quality of the OWON product. A loudly humming fan tires the user, and on top of that, a malfunctioning MULTIPURPOSE knob, which switches randomly during slow spinning - once it changes one position at a time, sometimes it jumps several positions, and sometimes it jumps to the end of the range right away. Setting the choice of frequency, voltage or menu item is very difficult because you never know how the knob encoder will jump. I reported the problem to the OWON factory, they wrote that they will send me new software ;-)) They are making some jokes about the customer ! ! I will never buy anything from OWON again!!
original Polish
Oscyloskop Owon SDS215S otrzymałem po 16 dniach od zakupu - a miało być 7-10 dni. Po dwóch godzinach testów zgłosiłem zwrot towaru do sprzedawcy bo nie takiej jakości produktu OWON się spodziewałem. Głośno szumiący wentylator męczy użytkownika, a do tego niesprawne pokrętło MULTIPURPOSE, które podczas powolnego kręcenia przełącza losowo - raz zmienia po jednej pozycji, czasami przeskakuje kilka pozycji, a czasami od razu przeskakuje na koniec zakresu. Ustawienie wyboru częstotliwości, napięcia lub pozycji menu jest bardzo trudne bo nigdy nie wiesz jak przeskoczy enkoder pokrętła. Zgłosiłem problem do fabryki OWON, to napisali, że przyślą mi nowe oprogramowanie ;-)) Jakieś żarty z klienta sobie robią ! ! Nigdy więcej nie kupię niczego marki OWON !!
« Last Edit: December 06, 2025, 05:23:42 pm by mlero »
