Author Topic: Portable Oscilloscopes List (cheap)  (Read 77066 times)
Offline awakephd
Re: Portable Oscilloscopes List (cheap)
« Reply #75 on: September 23, 2024, 09:07:53 pm »
I recently got a Zeewei DSO3D12 to replace a DSO154 - main reason for replacing the latter was that I accidentally cracked its screen. :(
If you are familiar with the DSO154, the DSO3D12 will feel very similar in terms of UI - even though it has quite a few more buttons to control its operation. The latter is a good thing, I'd say, increasing the convenience of changing time base or vertical scale in particular. The one thing that was mildly annoying in the UI is how to move up and down in the menu - annoying only because I could find absolutely nothing in the manual to tell how to do it. I had to try various buttons until I finally realized that it treats the column of buttons next to the display as "soft buttons" to select each menu section. Within the menu section, the arrow buttons and OK button work as expected / much like the DSO154.
Is it worth the extra $50? Well ... jury is still out on that. I mostly just wanted something portable and battery powered for times when those attributes are needed. Dual channels is definitely a plus for the uses I have in mind for it. An actual case feels like it might be less likely to succumb to damage than the DSO154 proved to be. All in all, I have no buyer's remorse; it's just hard to get as excited about this for $80 when I had something that felt and looked very similar for $30 - albeit only 1 channel, smaller screen, and lower specs.
Offline Fungus
« Reply #76 on: September 23, 2024, 09:23:39 pm »
Just watching the Zeeweii videos in this post:
https://www.eevblog.com/forum/testgear/another-dsodmm-zeeweii-dso3d12-claimed-120mhz250msps/msg5274556/#msg5274556
Imagine you're starting out from zero...  it gets you a lot of capability for $100 bucks (multimeter+scope+siggen).
I like the display of where to put the multimeter cables:
« Last Edit: September 23, 2024, 09:25:51 pm by Fungus »
Offline Fungus
« Reply #77 on: September 23, 2024, 09:33:38 pm »
Yep, menu looks almost identical, but much easier to navigate.
Setting timebase and vertical is much easier, too - dedicated buttons!
Single channel is a big limitation.
This one has multimeter, too. If I could leave the meter out of my case then it could be a win in terms of space. I'll have to make a cardboard model and see the real size.  :)
I'm tempted.
I'll sleep on it for a few days though...  ;D
Offline awakephd
« Reply #78 on: September 24, 2024, 06:10:20 pm »
Yes, that is one of the best features / most intuitive parts of the design.
Agreed, they did this very well. Even better would be a single set of inputs that are internally switched, but let's not get greedy ... :)
Offline BillyO
« Reply #79 on: September 24, 2024, 08:25:56 pm »
Bad idea.  Accidently making a poor a mode choice while connected to a strong voltage source or a sensitive circuit could cause myriad problems.  They don't keep inputs separate to reduce cost or make things easier for themselves, they do it for (what should be) obvious safety reasons.  You may have too much experience with cheap "Smart" meters that do not have current ranges.
Bill
The following users thanked this post: RAPo
Offline awakephd
« Reply #80 on: September 25, 2024, 02:42:39 pm »
BillyO, you are giving me far too much credit. In my case, it is a matter of far too little experience in general. Thanks for helping me to see the advantage of the separate inputs!
Offline Fungus
« Reply #81 on: September 25, 2024, 02:53:00 pm »
Current inputs are low resistance (passthrough) and have fuses*, that's why they make them separate.
You could do it with shared jacks but you'd need to add internal relays and all sorts of stuff and any bad range selection would blow your fuses.
(*) Yeah, I know the 10A range on this particular meter is "unfused".
Offline BillyO
« Reply #82 on: September 25, 2024, 03:01:03 pm »
I like to give people the benefit of the doubt.  :-+ :-+
Bill
The following users thanked this post: awakephd
Offline BillyO
« Reply #83 on: September 25, 2024, 03:12:14 pm »
Except in the case where your meter was hooked up to a small 50ma diode, or tiny transistor or.. something else that would not blow a 600ma fuse before giving it's own life to make yours is more interesting.
Also, even if the meter was smart enough to put a 10A fuse in line (not hard to do with a big, brawny relay) when in that mode, it better well be a darn good fuse if it suddenly finds itself across the 415v mains feed in a breaker panel in the UK.  Or some other suitably contrived situation (which do occur occasionally).
Bill
Online MathWizard
« Reply #84 on: January 10, 2025, 10:27:19 pm »
I'm interested in something like the FNIRSI 2C53T, as a cheap handheld DMM+DSO (the basic AWG is a bonus too, pretty handy for basic audio repair). I gather most of these cheap devices aren't up to the safety ratings, they might advertise.
But has anyone modded these to upgrade the input protections? There's not much room in some of them, but others there is.
I have 1 of the early DSO138's, (besides my expensive gear) and w/o a case, it was always pretty annoying, and I had no reason to use it.
But for a cheap handheld, that's not as expensive as the OWON HDS2000's, how are these regarded ? I'd say for my hobby low-voltage stuff, this should be fine as a field meter.
Looking at this video, I think the UI is ok, and it seems ok for upto a 10MHz square-wave, but yeah a bit faster would be nice, for looking at MCU's/etc.
This has some FFT function, but it hasn't been worked on enough, or they ran out of room to store the program. Going by that video anyways.
I'd really like to see Mike Smith (I hope I got that right, maybe it's Joe Smith) hook this up to his high voltage machines, and see what happens. If I get 1 of these, it would be nice to upgrade the input protections, for household levels, if it's really lacking it.
« Last Edit: January 10, 2025, 10:52:56 pm by MathWizard »
Offline Fungus
« Reply #85 on: January 10, 2025, 10:41:31 pm »
If you're regularly going into life-or-death situations then get a suitable device.
If not, get a FNIRSI.
Online MathWizard
« Reply #86 on: January 10, 2025, 10:55:24 pm »
No the worst thing I might look at would be a LED/LCD TV or Stereo, maybe a dishwasher. So how bad could their DMM protections really be, has anyone done a real teardown ?
Well that's an older or lesser version I think.
But how hard would it be to put proper protections on a PCB, and fit it in there somehow. IDK the clearances required for the various voltages, or how much the parts would be, I'm guessing not much. I remember a video of Mr.Smith upgrading one of the Uni-T DMM's to a very high level, I'll have to find that again.
« Last Edit: January 10, 2025, 11:07:56 pm by MathWizard »
Offline tunk
  • Country: no
« Reply #87 on: January 10, 2025, 11:21:57 pm »
Another of the cheap ones, PDS833, 1MHz/8.3MSps.
From around US$25, but for a similar price, you can
get a much better Zeeweii DSO154PRO.
https://www.aliexpress.com/item/1005008261777874.html
Online Peabody
« Reply #88 on: January 10, 2025, 11:37:06 pm »
+1 on the DSO154Pro.  I don't know about the safety features, but it appears to be head and shoulders above the other single-channel scopes, particularly at the price.  Apparently it will do a real 18MHz, and you can even zoom in.  :-)
Offline Fungus
« Reply #89 on: January 10, 2025, 11:42:55 pm »
Zeeweii is where it's at for 'scopes.
FNIRSI is better at power supplies.
Offline birdy
« Reply #90 on: January 27, 2025, 01:34:43 pm »
I’ve paned to buy a Portable Oscilloscope. Not to big and not to expensive.
Around 100$ is ok,  but max. 150$
On my current List
  • Zeeweii DSO3D12
  • DreamSourceLab DS Touch DS4T252
Does anybody knows wat the better option is?
Offline Fungus
« Reply #91 on: January 27, 2025, 02:07:15 pm »
On my current List
  • Zeeweii DSO3D12
I'll go out on a limb and say those are the two.
Not much is known about the DreamSourceLab one though, or what the final price will be after it arrives.
The Zeeweii can be had for about $75 right now.
https://www.aliexpress.com/item/1005007010308820.html
(but there's rumors of some old hardware version out there that doesn't support the latest firmwares. Ask the seller what firmware version they run before buying... if in doubt, spend $20 more at the official store  :-// )
nb. The Zeeweii also has a respectable multimeter built-in.
The following users thanked this post: birdy
Offline tunk
  • Country: no
« Reply #92 on: January 27, 2025, 02:09:46 pm »
Unless you think it's too large, Owon HDS200 series:
https://www.owon.com.hk/products_owon_hds200_series_digital_oscilloscope
Offline birdy
« Reply #93 on: January 30, 2025, 09:55:59 pm »
The oscilloscopes from Owon are more expensive than Zeeweii. Do you get more for the extra money from Owon? I don't need DMM functionality, I already have a few DMMs.
Offline csuhi17
  • Country: hu
« Reply #94 on: February 22, 2025, 09:38:21 am »
After I managed to get rid of the two Fnrisi, I got a Hantek TO1112 for basic work.
Unfortunately, it didn't live up to expectations.
important for those who want to buy it.
1. Its internal storage became inaccessible, I already updating the firmware, it didn't help.
2. It's almost unusable in slower time bases.
After setting it, you have to wait a very long time until the wave appears on the display.
In scRoll mode, it sets a 4k memory depth.
At 1s/Div, 16 seconds, at 100s/Div, 1600 seconds.
If I set the memory to 8M, then.
At 1s/Div, 32 seconds, at 100s/Div, 3200 seconds :wtf:
I wrote to the seller, he forwarded it to Hantek, but I don't think they'll do anything about it. It's been like this for years :palm:
Fnirsi oscilloscope = waste&regret
or maybe I was wrong
Offline tigrou
« Reply #95 on: April 08, 2025, 09:17:01 pm »
Here is cheap one that you can (probably) add to the list :
ETEPON EM001 (the top screen reminds me the DSO2512G, but the comparison stops there).
Edit : seems to be a FNIRSI DSO-150 knock off
« Last Edit: April 08, 2025, 09:27:22 pm by tigrou »
Offline tunk
  • Country: no
« Reply #96 on: April 09, 2025, 10:25:43 am »
I think it originally was developed and made by Jyetech (not Fnirsi).
And it's not good value at US$25-35.
More info, including manual and schematics:
https://jyetech.com/dso-150-shell-oscilloscope/
Offline tigrou
« Reply #97 on: April 22, 2025, 11:37:15 am »
After the pocket oscilloscope, here is the palm hand scope :
2552978-0
It's probably as cheap and simple as it can be (should be <$20 for the OLED screen + MCU). Probably cheaper than a DSO13  ;D
This is more a hobby project than a real usable thing. It's based on Arduino oscilloscope project from here.
« Last Edit: April 24, 2025, 07:52:58 pm by tigrou »
The following users thanked this post: Fungus
Offline Fungus
« Reply #98 on: April 22, 2025, 04:31:18 pm »
The Arduino ADC only works up to ~12.5kHz so usable bandwidth can't be more than about 5kHz.  :)
Offline enjoi4283
    • Lambda Photometrics
« Reply #99 on: April 29, 2025, 11:52:58 am »
Have you considered the Rigol DHO804? It may be slightly out of budget, but as it's PD compatible you can use any decent power bank and then have a "proper" portable oscilloscope. They often go on sale for less than the usual price
https://www.lambdaphoto.co.uk/rigol-dho804-70mhz-bw-12-bit-4-channel-high-definition-oscilloscope.html#specifications
https://www.lambdaphoto.co.uk/pdfs/Rigol/LAMBDA_DHO8000_Datasheet.pdf
Lambda Photometrics Ltd - Rigol, Harogic, Tabor, SRS, Beehive, Y.I.C EMC
