As with most things, there are complaints, but I don't think he didn't like it from the video either. I've got two SPD3303X-Es hacked to Xs and they work great. Some minor annoyances with UI (display fonts, button choice), but they are workable, and I have virtually no BNC to banana adapters, so I've never even run into the plug spacing as an issue. For the cost, I think they're some of the best value for money available, though there are some other good options.
You're going to have some trouble finding 5A output per channel in a triple supply at this pricepoint, so if you really need that output, maybe consider two single supplies. For the budget, you could also get two SPD3303X-Es and run both in parallel mode (32V 6.4A per unit plus auxiliary channel), but if you don't need the extra channels, a pair of single channel units is probably a better bet.
