I have a Shenzhen Mastech HY3003D-2 that is acting... funny. If you measure the output with a scope, it has about a 10V peak to peak sawtooth waveform at about 8.5KHz (on top of the DC). However, if I attach a active load, specifically a BK Precision 8500 to it, the oscillation stops and it acts like a normal supply - it handles loads gracefully as well. But if I connect a resistor to it, it just oscillates. Further, the load stabilizes both channels at the same time. As in, even though the load is only connected to one channel, both channels stabilize (and they're set to be independent). I'm measuring this with a grounded scope. I've tried grounding either side of the output, and no change.
Anybody have any ideas as to what is going on here?
