Author Topic: Precise Offset Compensation Ohm Measurements and Validation of DMMs  (Read 23930 times)
Offline quarks
Re: Precise Offset Compensation Ohm Measurements and Validation of DMMs
« Reply #25 on: February 27, 2016, 06:02:13 am »
Unfortunately I totally missed this very interesting information until today.
Great post, many thanks for sharing.
Offline dr.diesel
« Reply #26 on: February 27, 2016, 12:54:39 pm »
Yeah, I can't keep up anymore either.  Sure wish @mentions worked!   :scared:
Offline dl1640
  • Country: cn
« Reply #27 on: December 01, 2017, 01:45:07 pm »
Very informative investigations. I set up a 3458A with OCOMP DELAY5 NPLC100 4W to check a 100 ohm class .005 resistor, I'm going to see how good it can get. The resistor is obviously out of spec and I need to use it by this calibrated value. :)
Offline Dr. FrankTopic starter
  • Got a lot of time now - and very low uncertainty
« Reply #28 on: December 01, 2017, 02:35:56 pm »
This delay is necessary only for R >= 10k.
For 100Ohm, you can have a delay of a few ten msec, otherwise you waste time.
Frank
The following users thanked this post: franklin
Offline dl1640
  • Country: cn
« Reply #29 on: December 01, 2017, 03:54:36 pm »
Thanks Frank,
I will try different delay time.
Online Smokey
  • Not An Expert
« Reply #30 on: December 24, 2023, 04:32:58 am »
I just picked up a Keithley2700 with OCOMP.
https://download.tek.com/manual/2700-900-01K_Feb_2016.pdf
There is no mention of NPLC related to that OCOMP process.  In fact they only let you select "fast"=0.1NPLC, "Medium"=1NPLC, or "Slow"=5NPLC from the front panel for measurements.  Using GPIB NPLC can be set up to 50, but that's it.
Update:  Just ran a test.  24Ohm resistor, 4W-OCOMP.  Square wave type signal with about +/-18mV.
Slow = 2.1Hz
Medium = 8.6Hz
Fast = 17.7Hz
« Last Edit: December 24, 2023, 07:12:36 am by Smokey »
