Who is going to buy up all of their remaining stock of discounted insulated tools and set up an eBay store for Wiha insulated tool aficionados?
Phase 1: Buy Wiha tools
Phase 2: ?
Phase 3: Profit
https://www.arrow.com/en/products/32017/wiha-tools-usaInsulated Cushion Grip Slotted Screwdriver 4.0 x 100mm (5/32")
$1.13 ($7.82) In Stock: 9 parts
https://www.arrow.com/en/products/32024/wiha-tools-usaInsulated Cushion Grip Slotted Screwdriver 4.5 x 125mm (3/16")
$1.14 ($7.90) In Stock: 9 parts
https://www.arrow.com/en/products/35811/wiha-tools-usaInsulated Cushion Grip Square Tip Screwdriver #1 x 100mm
$1.26 ($8.76)
In Stock: 6 parts No Stock Availablehttps://www.arrow.com/en/products/32005/wiha-tools-usaInsulated Cushion Grip Slotted Screwdriver 2.0 x 60mm (5/64")
$1.73 ($6.00) In Stock: 200 parts
https://www.arrow.com/en/products/32046/wiha-tools-usaInsulated SlimLine Slotted Screwdriver With Cushion Grip 3.5 x 100mm
$1.79 ($12.42) In Stock: 10 parts
https://www.arrow.com/en/products/92112/wiha-tools-usaInsulated Slim Slotted Screwdriver 3.5 x 100mm
$1.96 (?)
In Stock: 10 parts No Stock Availablehttps://www.arrow.com/en/products/32049/wiha-tools-usaInsulated SlimLine Slotted Screwdriver With Cushion Grip 4.0 x 100mm
$2.04 ($14.18) In Stock: 5 parts
https://www.arrow.com/en/products/30746/wiha-tools-usaInsulated SlimLine Xeno Screwdriver With SoftFinish® Cushion Grip #1 x 80
$2.24 ($15.56) In Stock: 2 parts
https://www.arrow.com/en/products/30747/wiha-tools-usaInsulated SlimLine Xeno Screwdriver With SoftFinish® Cushion Grip #2 x 100
$2.75 ($19.10)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/32947/wiha-tools-usaInsulated Industrial Stripping Pliers 6.3" OAL.
Industrial brushed finish. Two component ergo cushion grips.
Strips up to AWG #8
$5.03 ($29.96)
In Stock: 2 parts No Stock Availablehttps://www.arrow.com/en/products/32836/wiha-tools-usaInsulated High Leverage Diagonal Cutters 7'' (AWG #5)
$6.70 ($38.96)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/32292/wiha-tools-usaInsulated Cushion Grip Nut Driver Inch Set Includes: 7/32" - 1/2". 5 Pieces
Nut Driver: 7/32, 1/4, 5/16, 3/8, 1/2"
$10.35 ($66.58) In Stock: 9 parts
https://www.arrow.com/en/products/32982/wiha-tools-usaInsulate Industrial 6.3" Long Nose Pliers, 6.3" Diagonal Cutters &
Voltage Detector. 3 Piece Set
$13.24 (?)
In Stock: 2 parts No Stock Availablehttps://www.arrow.com/en/products/32942/wiha-tools-usa8" BiCut Super Cut With Insulated Drivers
Screwdrivers: Slotted: 3, 4.5, 5.5, Phillips: #0, #1, #2
$13.97 ($88.10)
In Stock: 2 parts No Stock Availablehttps://www.arrow.com/en/products/28394/wiha-tools-usaInsulated Pop Ups SlimLine Driver Set
Includes Slotted 3.0, 4.0mm, Phillips #1, #2 and Square #1, #2 SlimLine Blades
$15.37 ($102.46)
In Stock: 3 parts No Stock Availablehttps://www.arrow.com/en/products/28392/wiha-tools-usaInsulated SlimLine 12 Piece Interchangeable Set
Includes Handle, Slotted 3.0, 5.5mm, Phillips #2,
Terminal Blockl #1, #2, Sq #1, #2, Torx®T8, T10, T15, T20
$20.59 ($117.84)
In Stock: 2 parts No Stock Availablehttps://www.arrow.com/en/products/32188/wiha-tools-usaInsulated Small Sizes Slotted & Phillips 7 Piece Set,
Sl: 2, 2.5, 3, 3.5, 4 & PH: #0 & #1 In Molded Case.
$26.08 ($60.44) In Stock: 6 parts
(lower discount on this one)
https://www.arrow.com/en/products/32190/wiha-tools-usaInsulated Cushion Grip Slotted 2.0 - 8.0mm Phillips #1 - 3
Inch Nut Drivers 1/4" - 1/2". 15 Piece in Carry Case
Slotted 2.0, 2.5, 3.0, 3.5, 4.5, 6.5, 8.0mm, Phillips #1, #2, #3
$30.10 ($203.94)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/28734/wiha-tools-usaInsulated Adjustable TorqueVario-S w/ Window Scale 0.6 - 2.0 Newton Meter
$30.55 ($212.92)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/28726/wiha-tools-usaInsulated Adjustable TorqueVario-S w/ Window Scale 10-50 In/lbs
$31.28 ($217.96)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/28727/wiha-tools-usaInsulated Adjustable TorqueVario-S w/ Window Scale 18-62 In/lbs
(Comes with Adjustment Tool)
$33.24 ($231.60)
In Stock: 2 parts No Stock Availablehttps://www.arrow.com/en/products/28737/wiha-tools-usaInsulated TorqueVario-S Screwdriver 2.0-8.0 NM (DISCONTINUED)
$33.24 (?)
In Stock: 2 parts NOT AVAILABLE FOR ORDER ON ARROW.COMhttps://www.arrow.com/en/products/31395/wiha-tools-usaInsulated 1/4" Metric T-Handle Socket Set
Includes Socket Sizes: 5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm and
T handle in Storage Box. 11 Pieces
$37.58 ($261.86)
In Stock: 2 parts No Stock Availablehttps://www.arrow.com/en/products/13693/wiha-tools-usaInsulated Metric Hex L-Key 10 Piece Set
1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0, 12.0mm In Canvas Pouch
$40.38 ($204.96) In Stock: 2 parts
https://www.arrow.com/en/products/31595/wiha-tools-usaInsulated 3/8" Drive Metric T-Handle & Socket Set Includes Socket
sizes 8 - 19mm and 125mm Extension Bar and T-Handle In Storage Box. 11 Pieces
$41.18 ($286.96) In Stock: 2 parts
https://www.arrow.com/en/products/31496/wiha-tools-usaInsulated 3/8" Inch T-Handle Socket Set Includes: 5/16 - 3/4" Sockets and
5" Extension Bar and T Handle in Storage Box. 11 Pieces
Sockets (3/8"): 1/4, 9/32, 5/16,11/32, 3/8, 7/16,1/2, 9/16, 5/8, 11/16, 3/4"
$41.77 ($291.06)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/21095/wiha-tools-usaInsulated Metric Deep Offset Angled 15° Ring Wrench 8 Piece Set
Includes 10.0mm - 19.0mm In Roll Up Pouch
$47.03 ($327.78) In Stock: 2 parts
https://www.arrow.com/en/products/21391/wiha-tools-usaInsulated 6 Piece Inch Ratchet Wrench Set
3/8, 7/16, 1/2, 9/16, 5/8, 3/4 in Storage Case
$48.74 ($339.70)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/32891/wiha-tools-usaInsulated Pliers, Cutters, Wire Stripper,
Slotted & Phillips Screwdrivers in zipper case. 10 Pieces
Screwdrivers: Slotted: 3/16 & 1/4", Phillips: #1, #2, #3
Pliers: 8" Long Nose Pliers, 8" Lineman's Pliers
8" BiCut High Leverage Cutter, 6.3" Stripping Pliers, Cable Cutters
$53.00 ($256.20)
In Stock: 2 parts No Stock Availablehttps://www.arrow.com/en/products/20194/wiha-tools-usaInsulated Open End Inch Wrench 13 Piece Set in Molded Storage Tray
Sizes: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1"
$67.00 ($461.20) In Stock: 2 parts
https://www.arrow.com/en/products/31390/wiha-tools-usaInsulated 1/4" Drive Socket Inch Set 3/16"- 9/16" Sockets,
50mm & 100mm Extension Bar and 1/4" Drive Ratchet in Storage Box 13 Pieces
$67.00 ($409.96)
In Stock: 1 parts No Stock Availablehttps://www.arrow.com/en/products/31391/wiha-tools-usaInsulated 1/4" Drive Socket Metric Set 5.0 - 14.0mm Sockets,
$67.00 ($409.96) In Stock: 1 parts
