Author Topic: Program that can log/control many multimeters and other devices.  (Read 1812280 times)
0 Members and 84 Guests are viewing this topic.
Online HKJTopic starter
    • Tests
« Reply #4450 on: August 30, 2025, 02:30:04 pm »
I cannot find the 1022 in the file, but there is a 1025?
This time I stand corrected :). Good thing you proof-red the definition...
I updated the definition, please re-download the ZIP file.
I have updated TC with the definition, thanks.
I do not prof-read the files, mostly I do a fast scan in them.
Offline dfgregr
« Reply #4451 on: August 31, 2025, 08:39:50 pm »
Hi HKJ,
I've tried to add some Modbus RTU devices on RS485 bus connected to the same port with different SlaveIDs but couldn't find the way to modify SlaveID, it's always 01 and the way to change "Function code" for write register operation (my device supports only 0x10 multiple refisters write).
My devices are RK8510 DC loads. How can I add them with different SlaveIDs and use 0x10 Function code for register writing?
Thanks.
    • Tests
« Reply #4452 on: September 01, 2025, 06:18:03 am »
Hi HKJ,
TC has the command address and address? for modbus devices that will change the modbus address.
I do not remember what modbus 0x10 is, but you can disable using singly byte writing (and reading) with #disableWriteSingle 1
The following users thanked this post: dfgregr
Offline dfgregr
« Reply #4453 on: September 01, 2025, 09:04:30 pm »
Thanks, everithing works as expected and #disableWriteSingle 1 turns modbus Function code to 0x10 but it's not clear from the documentation.
A couple more questions:
- Am I right that I have to connect just one device and use 'address' command in scripts in order to get gate from different devices in network? And I have to define #initCmd and #finalCmd for all connected devices?
- I have a Reverse byte order in the data fields that device returns and expect to get. How can I do bytes swap in this case. It's a compleat reverse order ABCD -> DCBA.
Thanks.
    • Tests
« Reply #4454 on: September 02, 2025, 08:06:36 am »
TC do not really support multiple devices on the same com port, but if the same devices has multiple addresses you can use the address command in the definition to switch between the different addresses (It works like all SCPI commands and can be used where they can be used).
TC did not have a general function to handle byte order, but some interfaces has it included. I have just added a function to swap bytes any way you want:
byteOrder(order,inputValue)
=hex(byteOrder("1234",0x12345678))
;; 78563412
=hex(byteOrder("+312",0x12f45678))
;; FFF47856
The order is byte positions in the input string lsb is 1 and msb is 4 (32 bit value) or 8 (64 bit value), a + can be placed at the start to force sign expansion.
A 0 in the order will add a zero byte to the output and a 9 will add a 0xff byte to the output.
Only as many bytes as specified will be transfered to the output, the rest will be ignored.
You can get the jar for the new test version here: http://lygte-info.dk/pic/Projects/TestController/TestController.jar
Offline dfgregr
« Reply #4455 on: September 02, 2025, 10:00:17 pm »
Thank you. I can serve two devices on the same port using an address hardcoding in a device configuration file. It's strange that such a powerful software doesn't support multiple devices on rs485 modbus network as it intend exactly for such purposes. I hope one day you upgrade TC with support for multiple devices.
Meanwhile here you are a config file for REK RK8510 DC Load.
Online KungFuJosh
  • TEAS is real.
« Reply #4456 on: September 03, 2025, 01:15:30 am »
I have two questions.
First:
#cmdSetup info Bandwidth Main
:read: :ACQ:BAND?
:format: si
Hz
:tip: Shows the current bandwidth setting.
Is there a way to remove the space between 350M and Hz?
Second:
For the other setting in the screenshot it says AFASt (auto fast) instead of the actual rate. Is it possible to add conditional logic so the Unit (Pts) is displayed and :format: si is applied only if the read result is a number? I'd also like to replace the AFASt with "Auto/Fast".
If I use format SI when AUTo or AFASt come up, it will replace the word with a question mark.
Thanks,
Josh
« Last Edit: September 03, 2025, 01:32:59 am by KungFuJosh »
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
    • Tests
« Reply #4457 on: September 03, 2025, 07:46:52 am »
I have though about supporting it as a GPIB driver (They allows sharing serial ports), maybe I will do it one day.
Thanks I will include it, I have added a #author statement with your handle.
    • Tests
« Reply #4458 on: September 03, 2025, 07:50:58 am »
:read: :ACQ:BAND?
:format: si
Hz
Not directly, see below.
Define the field as text and use :readmath: to do the formatting/conversion.
Online KungFuJosh
  • TEAS is real.
« Reply #4459 on: September 03, 2025, 11:38:45 pm »
Is it possible to :update: all, or set a group to :update: group so items don't have to be listed individually?
Thanks,
Josh
    • Tests
« Reply #4460 on: September 04, 2025, 11:25:45 am »
No.
From script you can do #SYNCPOPUPS and it will reinit all open popups.
Online KungFuJosh
  • TEAS is real.
« Reply #4461 on: September 04, 2025, 03:09:01 pm »
No.
Okay, let's call it a feature request then. ;)
For example:
waveform_freq
waveform_shape
waveform_rtime
etc. etc. then we can add:
:updategroup: waveform_
or something like that.
Thanks,
Josh
Online KungFuJosh
  • TEAS is real.
« Reply #4462 on: September 04, 2025, 04:14:03 pm »
I have a small issue with the following:
#cmdSetup number H_Resolution Main
Bits 12 16
:read: :ACQ:HRES?
:write: :ACQ:HRES #
:update: H_Resolution,Resolution
:tip: Valid numbers include 12, 12.5, 13, 13.5, 14, 14.5, 15, 15.5, 16
The :tip: shows the only valid entries. However, if I input 12 in the number box, it sends 12.0 which is not valid. How can I correct this without switching it to a text field? Is it also possible to only allow the exact values listed in the tip?
Ironically, even if I use numberInt (which I don't want), it still writes 12.0.
Thanks,
Josh
« Last Edit: September 04, 2025, 04:37:30 pm by KungFuJosh »
    • Tests
« Reply #4463 on: September 04, 2025, 04:36:45 pm »
Bits 12 16
:read: :ACQ:HRES?
:write: :ACQ:HRES #
You are basically using the wrong control, use a combobox or radio control (Due to the amount of values radio is probably out) for it.
Online KungFuJosh
  • TEAS is real.
« Reply #4464 on: September 04, 2025, 11:34:22 pm »
Is there a button type that toggles states ?
What I am wanting is a button for On/Off without having to use two buttons, much like the ButtonsOn version that has the indicator but a single button that can toggle between two states, change its button text, and change its activated output to toggle commands, so you can send a 0 or 1 just like a checkbox etc.
I wanted to use a button like this for the SDL1030X definition I am making, to have features such as Load On/Off, Short On/Off, Remote Sensing On/Off etc.
No, but you can use checkbox (Not recommended for on/off, but fine for the other settings).
+1 feature request for a toggle button that functions the same as a checkbox, but is a button with on and off states. For example, normal color when off, but can choose :color: green or whatever when it's active.
That's in addition to my :updategroup: feature request above. ;)
Thank you!
Josh
    • Tests
« Reply #4465 on: September 05, 2025, 10:37:11 am »
I do not get the why. A buttonson does exactly that, it is 3 controls in one line, but a single button would also use a line.
I am thinking about it.
Online KungFuJosh
  • TEAS is real.
« Reply #4466 on: September 05, 2025, 01:51:19 pm »
It would be functionally exactly the same as a checkbox, but visually more appealing and easier to layout. In the first mockup, I used 4 channels. What if there's more? They could all fit on a row more easily (especially if the label can be omitted), and they're easier to click than a checkbox.
Thanks,
Josh
« Last Edit: September 05, 2025, 02:25:24 pm by KungFuJosh »
    • Tests
« Reply #4467 on: September 05, 2025, 03:17:17 pm »
I see you idea now, but it is a lot of work to make it like checkbox, they do some trickery (Adds a hidden control) to combine on a single line.
It basically comes down to: All buttons uses the same command, I can do it as one control. Each control need their own command, I need trickery.
Online KungFuJosh
  • TEAS is real.
« Reply #4468 on: September 05, 2025, 04:56:03 pm »
Your programming skills are lightyears beyond mine, but here's what I think:
Don't think of it like the other buttons. Think of it like putting a fancy dress on a checkbox. ;)
Checkboxes have two states, and function a specific way. :checkbuttons: could be the same thing, but the states look like a button (with two color states) rather than a checkbox.
Thanks,
Josh
Online KungFuJosh
  • TEAS is real.
« Reply #4469 on: September 05, 2025, 05:34:26 pm »
Unrelated curiosity. Is this the expected use for readmath in these cases?:
#cmdSetup info CH1_Filter CH1
:read: :CHAN1:FILT?
:readmath: replace(replace(replace(replace(replace(replace(value,"NONe","None"),"AMPLitude","Amplitude"),"200000000","200M"),"100000000","100M"),"50000000","50M"),"20000000","20M"));
:tip: Channel filter status.
#cmdSetup combobox CH1_Filter CH1
:write: :CHAN1:FILT
:read: :CHAN1:FILT?
:readmath: getElement("200000000,100000000,50000000,50000000",listIndex(value,"200M,100M,50M,20M"));
:readmath: replace(replace(value,"NONe","None"),"AMPLitude","Amplitude"));
:update: CH1_Filter
:updatedelayed: 0.1
None NONe
Amplitude AMPLitude
200M 200000000
100M 100000000
50M 50000000
20M 20000000
:tip: set Channel filter.
The info box worked fine, but the combobox required separating readmath as shown. Is that how it should be done, or is there a better method?
Thanks,
Josh
    • Tests
« Reply #4470 on: September 05, 2025, 06:30:48 pm »
:read: :CHAN1:FILT?
:write: :CHAN1:FILT
:read: :CHAN1:FILT?
:update: CH1_Filter
:updatedelayed: 0.1
None NONe
Amplitude AMPLitude
200M 200000000
100M 100000000
50M 50000000
20M 20000000
Originally the idea was that everything fit in one :readmath:, but I did not block multiple and I am not going to change that.
But I wonder about your filter code, the first :readmath: is not supposed to allow anything but the listed values to get past it.
:readmath: has allows some fairly advanced statement, because it uses the programming language in TC and it has a lot of functions. Generally you can test any expression on the command line (Stick a = before it) or in the calculate, in both cases you have to define value for yourself or just use a fixed value.
Online KungFuJosh
  • TEAS is real.
« Reply #4471 on: September 05, 2025, 08:35:39 pm »
:read: :CHAN1:FILT?
:write: :CHAN1:FILT
:read: :CHAN1:FILT?
:update: CH1_Filter
:updatedelayed: 0.1
None NONe
Amplitude AMPLitude
200M 200000000
100M 100000000
50M 50000000
20M 20000000
I tried both versions of the readmath functions to include all options, but they only worked on the combobox as shown above. Even though the info box was fine with it, the combobox didn't like when I mixed the numbers and words in the same readmath. It didn't help to use :string: either. It works as it is, and that's fine with me. I was just curious.
Thanks,
Josh
    • Tests
« Reply #4472 on: September 05, 2025, 08:56:25 pm »
:string: disables the forced conversion to numbers on the received values, not all controls do that, but most do.
The expressions have a automatic type conversion, that will convert to string or number (or other types) depending on the expression and if the value can be converted (The conversion do not support as many formats as the advanced input parser). You can force conversion https://lygte-info.dk/project/TestControllerFunctions%20UK.html#Typecast and this can be used on the command line to see what the result is. I.e. type =double("10M") or =double("10e6"), the first will fail, the second works.
TC has a couple of numeric parsers and which one is used depends on function, in some cases you can override the parser (:readformat:) or disable it (with :string:).
    • Tests
« Reply #4473 on: September 08, 2025, 12:38:16 pm »
Ok, I took the time and did it, but I have not tested very much:
The toggleButton supports up to 4 states, I do not adjust the color of the button, there is issues with that, instead I use a colored line as indicator. It do not take up much space and is easy to see.
Each command line has a button label and a command, in some cases you may want to use the same label for all states.
Without :string: it will compare to 0,1,2,3 for the states, with :string: to the names or arguments.
Default colors are: red, green, yellow, blue
Without the :read: command it will automatic move between the states, but there is no guarantee that it matches the device.
Here is my test code (I tested it with setting voltage a multichannel power supply, that is not something your would want to do in real life)
#cmdSetup toggleButton tt
:write: INST OUT1;VOLT (value)
:read: INST OUT1;VOLT?
:readmath: value-1;
C1 1
C1 2
C1 3
C1 4
:write: INST OUT2;VOLT (value)
:read: INST OUT2;VOLT?
;Use read value to string match on argument, but it must be an integer to match, not the 1.2000E+01 form the PSU
:readmath: int(double(value));
:string:
:color: blue cyan magenta green
C2 1
C2 2
C2 3
C2 4
:write: INST OUT3;VOLT (value)
:read: INST OUT3;VOLT?
;When readmath is executed the value is still a string, use int() to force integer comparison
:readmath: int(double(value))>9?1:0
C3 8
C3 12
« Last Edit: September 08, 2025, 01:35:46 pm by HKJ »
Online KungFuJosh
  • TEAS is real.
« Reply #4474 on: September 08, 2025, 02:13:57 pm »
Thank you! That looks great.
I implemented it like this and it works as expected:
#cmdSetup toggleButton Channels Main
:read: :CHAN1:STAT?
:write: :CHAN1:STAT
:string:
:color: gray yellow
:update: Channels,Channel_1,Channel_2,Channel_3,Channel_4
CH1 OFF
CH1 ON
:read: :CHAN2:STAT?
:write: :CHAN2:STAT
:string:
:color: gray red
CH2 OFF
CH2 ON
:read: :CHAN3:STAT?
:write: :CHAN3:STAT
:string:
:color: gray blue
CH3 OFF
CH3 ON
:read: :CHAN4:STAT?
:write: :CHAN4:STAT
:string:
:color: gray green
CH4 OFF
CH4 ON
I have one general question: Is it possible that items can take up equal space when they divide a row? This isn't limited to these buttons, you can see CH1 and CH3 are wider for the checkboxes also.
Thanks,
Josh
