Author Topic: Program that can log/control many multimeters and other devices.  (Read 1485019 times)
Tjuurko and 211 Guests are viewing this topic.
Offline HKJTopic starter
    • Tests
Re: Program that can log/control many multimeters and other devices.
« Reply #4975 on: October 18, 2025, 07:42:25 pm »
Is there a way to get that from a SCPI command? If I could use stuff like :CHAN1:STATe == ON that would work.
You can do that, but I will not recommend it due to performance reasons.
Either that or if you made it work with defined variables (:setvar: CH1 ON etc).
I have been thinking about that and may make it.
Online KungFuJosh
  • TEAS is real.
« Reply #4976 on: October 18, 2025, 07:44:09 pm »
So, in your opinion, it seems the latter option is the best option for me. I think I agree. ;)
Thanks,
Josh
Best Continuity Tester Ever
Online KungFuJosh
  • TEAS is real.
« Reply #4977 on: October 19, 2025, 01:31:59 am »
My definition is ready for when the advCombobox supports set variables. I set it up so a variable called CHsOn has the 4 channels in sequence with Y or N values.
Activating or deactivating channels updates the variable.
Then I can set (for example) the maximum memory depth:
327.2M is CHsOn==YNNN
164M is CHsOn==NYNN || CHsOn==NNYN || CHsOn==NNNY
82M is CHsOn==NNYY || CHsOn==YYYN || CHsOn==YYNY || CHsOn==YNYY || CHsOn==NYYY
Thanks,
Josh
Offline flash2b
  • Everything I like about myself is better with you.
« Reply #4978 on: October 19, 2025, 06:50:01 am »
Another update to TC, now v2.84
Params is: label foregroundcolor backgroundcolor expression icon command
Use attached device with these settings in the dummy driver to test it:
This new 2.84 version does not log (I can setup logging, but TC hangs) when I have a setup menu open or a setup menu opened and was closed. Version 2.77 does not have this problem.
They say attention is a shovel. It's time to dig 'em out.
    • Tests
« Reply #4979 on: October 19, 2025, 08:09:09 am »
I do not see this problem and I have not been in that part of the code either.
« Last Edit: October 19, 2025, 08:19:37 am by HKJ »
Offline flash2b
« Reply #4980 on: October 19, 2025, 08:23:29 am »
But I am not kidding, it just hangs.... nothing on the debug log. The log button also does not get red. I see that TC does the internal askMode but then it hangs.
Java 8u461 64 bit on Windows 10.
What can I do to identify the problem since everything is ok on v2.77 for me. Same definition. Please help....
« Last Edit: October 19, 2025, 08:36:21 am by flash2b »
    • Tests
« Reply #4981 on: October 19, 2025, 08:39:19 am »
I do not like that kind of bug, they are mostly impossible to find.
I am testing with the Dummy I published before, but I have extended it a bit and I am also testing with R&S HMC8043 and do not see any issues.
Offline flash2b
« Reply #4982 on: October 19, 2025, 08:40:38 am »
Tested with my Hameg and Yokogawa defintions, same problem.
When I start logging right away, no problem. But when I have invoked the setup menu (open or open and then close) logging does not work.
I noticed that starting logging right away, the button gets RED color immediately, while when a setup menu is open it takes a few seconds (on 2.77).
« Last Edit: October 19, 2025, 08:46:52 am by flash2b »
    • Tests
« Reply #4983 on: October 19, 2025, 08:45:09 am »
I can upload the current TC and Dummy definition and you can test with them also.
Offline flash2b
« Reply #4984 on: October 19, 2025, 08:47:26 am »
Yes please
    • Tests
« Reply #4985 on: October 19, 2025, 09:19:19 am »
Yes please
This version of Dummy can return a value using the read command, i.e. logging is a horizontal line.
The TC download is updated.
Offline flash2b
« Reply #4986 on: October 19, 2025, 09:21:23 am »
Driver does not load: ;; Dummy Device "Dummy,Dummy" do not match answer: "null"
Starting
;; jSerialComm version: 2.11.2
Could not find advcomboboxhot
;; Start thread for: Dummy - TCTest
Tx input: *IDN?
Rx after processing: null
;; Stopping thread for: Dummy - TCTest
    • Tests
« Reply #4987 on: October 19, 2025, 09:23:45 am »
Try once more, I do have a issue with initially creating the definition file.
Offline flash2b
« Reply #4988 on: October 19, 2025, 09:26:31 am »
Same, and I am using v2.85 which also hangs the logging when a setup menu has been invoked.
    • Tests
« Reply #4989 on: October 19, 2025, 09:33:00 am »
It creates attached file in ...\Documents\Testcontroller\Settings
I suspect something may be wrong with your Java
Offline flash2b
« Reply #4990 on: October 19, 2025, 09:37:28 am »
It did not create that file. If I copy the file in that directory, the same problem exists.
I just reinstalled Java 1h ago...
    • Tests
« Reply #4991 on: October 19, 2025, 09:42:17 am »
I do not know what to say or do, I have not had any problems, neither running the .jar file standalone or in my development system.
Offline flash2b
« Reply #4992 on: October 19, 2025, 09:54:45 am »
Well I guess I am stuck on v2.77 for now  :(
v2.84 and v2.85 do not work for me. Is there a location where I can download 2.78 true 2.83 so I can determine where the problem occurred the first ?
    • Tests
« Reply #4993 on: October 19, 2025, 09:58:22 am »
I do not keep the different .jar versions, I only keep the source for all full releases.
Offline flash2b
« Reply #4994 on: October 19, 2025, 10:23:59 am »
I have retested it with the SDG2000x definition, and there is no problem there. So it may be related to the ascii driver only.
If i use my Hameg HM8112 definition, which is very simple. And if I type askMode? , range? and intTime? on the TC command line directly, logging is not affected. Well the setup menu uses only these 3 scpiCmd's so I am puzzled.
If i invoke the Log button on TC, it will become Stop Log in red straight away. This is different when a setup menu from an ascii definition is opened/was opened. It always takes 1-2 seconds, it was always that way. It does not happen with the SDG2000x definition which is not ascii.
« Last Edit: October 19, 2025, 10:38:05 am by flash2b »
    • Tests
« Reply #4995 on: October 19, 2025, 10:46:48 am »
You can try moving the dummy definition to the ascii base, if it locks there is something I can look for.
    • Tests
« Reply #4996 on: October 19, 2025, 10:50:57 am »
The current test version includes #scpiCmd vars and advComboBoxHot, use return0(printLog(getVarList(2))) to list them (0=Global, 1=local, 2=parent). I put the other script parser in as parent that prevent any issues if they are used concurrent.
You must use: CHsOn=="YNNN"
But why not: inList(CHsOn,"NNYY YYYN YYNY YNYY NYYY")
« Last Edit: October 19, 2025, 12:17:23 pm by HKJ »
Offline flash2b
« Reply #4997 on: October 19, 2025, 10:53:50 am »
Change SCPIx to ascii in your dummy driver
;; Dummy: Tx <pgm>
;; Dummy: Script start
;; Dummy: Script end <>
;; Found TCTest on Dummy
Loaded the driver !! It did not create the settings file.
The dummy setup menu also works, and does not influence the logging.
I hope others will also retest their definitions or will shed some light on what needs to be changed.
« Last Edit: October 19, 2025, 11:03:50 am by flash2b »
    • Tests
« Reply #4998 on: October 19, 2025, 11:02:20 am »
;; Dummy: Tx <pgm>
This means I do not know where to look, the ascii driver works.
You may even be able to redefine the dummy so it matches your device, starting usually only requires a few commands.
Note: You can change the configuration file for dummy, by specifying a name in the address field on the load page.
Offline flash2b
« Reply #4999 on: October 19, 2025, 11:22:31 am »
Well... that is very disappointing. Since it worked in v2.77 and now I feel it is my fault that is doesn't anymore.......
