I found what seems to be a performance related bug. I can change the measurement types 1000 times if I'm not on the current values tab, and there's no issue. However, when I'm on the current values tab, there is a limited amount of mode updates before TC freezes, becomes unresponsive, and must be closed with the task manager.
I discovered this issue when I added a couple more measurement options. It happens faster with 10 active measurement options, still happens when I went down to 8, and also occurred when only 3 measurements were active...though it took a little longer to trip it up.
I can change the measurement types as often as I want away from the current values tab, then go to that tab and view the values. Then leave the current values tab, change it 100 times again, and switch back to see the values.
Screenshots are of frozen states. Nothing occurs in the debug log, that freezes also.
Thanks,
Josh
