V2.91 is up
TC could lock up, this version fixes that, it also add a couple of new devices and updates some. There is improvements to the dummy interface.
V2.91
Updated: Analogic DP100 & R&S UDL45 Multimeters (Thanks Flash2b)
Added: Rigol DHO914s Oscilloscope (Thanks Z Electronica UY)
Added: Prema 6000, Prema 4001 DMM (Thanks Flash2b)
Added: Dummy definitions can be integrated in device definitions.
Added: Load/save of dummy interface definitions.
Fixed: TC locked up sometimes when using setup menu and logging.
Added: Prema 5001, Prema 6001 DMM (Thanks Flash2b)
Updated: Hameg HM8112-1, Hameg HM8112-2, Prema 4000, Prema 5000 DMM (Thanks Flash2b)
Update: UNI-T UTL8511+, UNI-T UTL8512+ and UNI-T UTL8513+ Electronic load (Thanks homico)
Fixed: AdvComboBox now supports preview, even if the expressions fail.
Added: GW Instek PSB-2400H, GW Instek PSB-2400L, GW Instek PSB-2800H and GW Instek PSB-2800L Power supplies (Thanks gpy)
In addition to the above I have worked on a AdvNumber control, it is not finished, but people are welcome to test it. Only difference to the current number is that it supports expressions for min/max value. Note: Avoid circular updates, for power supplies use it on either current or voltage, not both!
