Author Topic: Program that can log/control many multimeters and other devices.  (Read 1814342 times)
0 Members and 86 Guests are viewing this topic.
Online HKJTopic starter
    • Tests
Re: Program that can log/control many multimeters and other devices.
« Reply #5550 on: January 23, 2026, 08:16:29 pm »
Why after "#Log 1" must follow the "#haslogged" or a "#delay" and not directly the rest definitions? What is the purpose of "haslogged/delay" after "#Log 1"?
Because I am not expert in programming... with "The treat will be stuck" what you mean... I don't know what is treat... maybe thread?
#Log 1
#haslogged
The #haslogged is to be sure the log system has initialized and logged a value, because TC is multi threaded things can happen at the same time. To be sure stuff is processed in the right sequence you have to use some commands to synchronize stuff. The #haslogged will stop the script until TC has logged a actual line in the table, this means doing stuff after that command that depends on that will always work correctly.
Sorry about my spelling, I am not a native English speaker and I has a tendency to not read my post before pressing the POST button, this means I frequently has spelling errors.
Online KungFuJosh
  • TEAS is real.
« Reply #5551 on: January 24, 2026, 04:48:50 am »
I suppose I'll have a definition for the Keithley 2700/2701/2750 available soon. ;)
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
Offline MrPete
« Reply #5552 on: January 24, 2026, 08:33:10 am »
Seemingly sinple question, that I have not solved...
How do I reference another Math formula value in a second Math formula?
Simple example
v1  Formula 63
v2 Formula Math.v1-5
That doesn't work. What does work?
    • Tests
« Reply #5553 on: January 24, 2026, 09:18:08 am »
Sounds good.
When you are using the same scale for all meters you can combine them. Right click on the chart and select layout.
    • Tests
« Reply #5554 on: January 24, 2026, 09:19:06 am »
You cannot.
The following users thanked this post: MrPete
Offline MrPete
« Reply #5555 on: January 24, 2026, 05:18:13 pm »
@HKJ what can I do to help diagnose a TestController memory leak?
I have two situations that lock up TC / javaw with an obvious memory overflow (using SysInternals Process Explorer to examine Private Bytes / Working Set size
Pretty simple:
* Load a CSV into Table
* Enable a predefined Math formula
* Go to current and view the value
* Repeat
Result
After about ten rounds, the javaw.exe memory footprint has grown from ~150MB to over 330MB, and TC is no longer responsive. Can't close it, etc. Have to kill the process
More complex
I have a variant of pukker's battery test script.
* Run script
* Press Reset
Repeat 4 times ok, 5th time TC is not responsive. Memory footprint again too big.
NO errors or messages in Debug window
    • Tests
« Reply #5556 on: January 24, 2026, 05:30:55 pm »
I will have to look at it.
I doubt it is a memory leak, Java do generally not leak memory, but it might be a hung thread (And the thread may hold the memory).
Using 330MB is not that bad (At least on my computer with 32GB/64GB), but TC slowing down is bad.
Online KungFuJosh
  • TEAS is real.
« Reply #5557 on: January 24, 2026, 08:42:45 pm »
I know, but I was being lazy because of the way the names get combined on the chart. All the names in the layout list need to be edited so they fit on screen. Which I did now, and saved as a layout script. ;)
Online KungFuJosh
  • TEAS is real.
« Reply #5558 on: January 24, 2026, 10:05:11 pm »
D'oh! The Layout Script doesn't save some important stuff. Can the chart Layout settings be included in that script, along with the sequence (colors) of devices?
The following users thanked this post: 2X
    • Tests
« Reply #5559 on: January 24, 2026, 10:11:10 pm »
You are welcome to combine the two scripts, but be aware not all chart settings can be applied before there is data in the table. You can look at the example I gave 2X with his curve settings.
You can add and remove as you wish with scripts, that is sort of the idea with all the configuration being in scripts.
Offline flash2b
  • Everything I like about myself is better with you.
« Reply #5560 on: January 25, 2026, 07:01:07 am »
It would be more logical that when combining curves, the Y axis is set to black as a color (instead of red).
They say attention is a shovel. It's time to dig 'em out.
    • Tests
« Reply #5561 on: January 25, 2026, 10:05:04 am »
A combined axis is not set to any specific color, but maintains the color of the controlling curve.
Offline flash2b
« Reply #5562 on: January 25, 2026, 11:48:26 am »
Why is a #cmdSetup infoAsk not properly left-aligned like comboboxHot or buttons ?
Offline 2X
  • Country: gr
« Reply #5563 on: January 25, 2026, 11:56:56 am »
My complete code about waveforms colors:
; ========================== Other Menu Steup ================================
; Create "Other" menu button
#otherList
menuItem[0]="RTB20004 Display Voltmeters.txt";
menuItem[1]="RTB20004 Chart Colours.txt";
#otherText
if (name=="RTB20004 Display Voltmeters.txt")
runScriptAsync("""#CLOSEALL
\x23ShowPopupSystem GridPanel 77 20 1092 321
\x23GridPanel 1 4
\x23GridPanel Readout RTB2004.DVM1_Voltage dh CH1_COLOR DVMS_BACKROUND_COLOR
\x23GridPanel Readout RTB2004.DVM2_Voltage dh CH2_COLOR DVMS_BACKROUND_COLOR
\x23GridPanel Readout RTB2004.DVM3_Voltage dh CH3_COLOR DVMS_BACKROUND_COLOR
\x23GridPanel Readout RTB2004.DVM4_Voltage dh CH4_COLOR DVMS_BACKROUND_COLOR
elseif(name=="RTB20004 Chart Colours.txt")
if !isLogging( )
runScriptAsync("""#delay 0
\x23Log 1
\x23haslogged
\x23ChartCurves RTB2004.DVM1_Voltage RTB2004.DVM2_Voltage RTB2004.DVM3_Voltage RTB2004.DVM4_Voltage
\x23ChartBackground black black - white -
\x23ChartColors CH1_COLOR CH2_COLOR CH3_COLOR CH4_COLOR (0,156,0) (230,230,30) cyan (0,80,156) lime (0,0,156)
endif;
endif;
    • Tests
« Reply #5564 on: January 25, 2026, 11:59:01 am »
It has a text field to the left.
I could have put a minimum length on the text field to make it more obvious.
    • Tests
« Reply #5565 on: January 25, 2026, 12:06:23 pm »
if !isLogging( )
\x23Log 1
\x23haslogged
endif;
endif;
I would have made it this way;
                        \x23if !isLogging( )
\x23Log 1
\x23haslogged
                        \x23endif
endif;
It works slightly different from your example.
The following users thanked this post: 2X, KungFuJosh
Offline flash2b
« Reply #5566 on: January 25, 2026, 12:07:30 pm »
I will look better if the text field is still empty, the button is properly left-aligned. The "Get" button will be resized anyway when it is pressed.
(but I think you mean the opposite, so make it more obvious that a text will appear after pressing the button ?)
« Last Edit: January 25, 2026, 12:14:27 pm by flash2b »
Offline 2X
  • Country: gr
« Reply #5567 on: January 25, 2026, 12:08:32 pm »
Here is my final definition file for my RTB24 (RTB2004) oscilloscope. HKJ take a look if you beleive I can make something better and I hope to included in a newer version of Test Controller.
I tested for two days and works fine for me at least.
I don't know if it possible or easy to be done but it would be nice if in a future version of a TC there was a way when the TC finds a device under the name and serial number of the device to display na text like a mini manual/instructions (something like the "#notes" at Load divices) and also a way to define what color will have each wave by the name of the waveform and not by the sequence.
Many thanks again to HKJ for the help and for his amazing job to make the Test Controller to be so versatile.
Offline 2X
  • Country: gr
« Reply #5568 on: January 25, 2026, 12:10:32 pm »
if !isLogging( )
\x23Log 1
\x23haslogged
endif;
endif;
\x23Log 1
\x23haslogged
                        \x23endif
endif;
what is the different to include the "if !isLogging( )" inside the "runScriptAsync"?
    • Tests
« Reply #5569 on: January 25, 2026, 12:15:36 pm »
A empty text field is not zero width and I don't want to edit the layout "on the fly".
    • Tests
« Reply #5570 on: January 25, 2026, 12:18:54 pm »
The one inside do not cover setting the actual colors and options, i.e. they will always be performed.
A even better if statement is:
#if (!isLogging() && tableRows()==0)
Then it would not start logging if there tableRows are data in table.
    • Tests
« Reply #5571 on: January 25, 2026, 12:31:11 pm »
I have added it to TC and will update it if you post a update.
I do not want a lot of notes popping up when loading devices. It is possible to include a weblink in the definition.
TC is designed to work with many devices at a time, having a single device taking over TC is not really smart. As long as it is an option like your definition it is acceptable.
Offline 2X
  • Country: gr
« Reply #5572 on: January 25, 2026, 12:36:14 pm »
I beleive now is bettter:
#otherList
#otherText
\x23GridPanel 1 4
\x23Log 1
\x23haslogged
endif;
endif;
Tell me if it is OK and I will upload this definition file in my previous post.
    • Tests
« Reply #5573 on: January 25, 2026, 12:42:02 pm »
Again, placing the if outside meas it only works before you start logging.
You post the updated version when you have tested.
I would test 3 conditions:
1) Device just loaded
2) After logging has been started manually
3) When logging is finished and the table contains data.
Can it set the colors in all 3 cases.
Offline 2X
  • Country: gr
« Reply #5574 on: January 25, 2026, 08:48:39 pm »
Please take a look at the below video:
https://jumpshare.com/share/VTOq46O8beZw2sMRML9t
