V2.95 is up
It contains a few new devices and some updated devices, but it is mostly some minor changes/addition to TC by me.
Update: UNI-T UTL8511+, UNI-T UTL8512+ and UNI-T UTL8513+ Electronic load (Thanks homico)
Added: A HiRes (i.e. ms) time option for the time column in table view.
Added: Configuration to adjust dateTime format.
Added: Keithley 2700, Keithley 2701, Keithley 2750 DMM (Thanks KungFuJosh)
Updated: Keithley DMM6500, Keithley DAQ6510 and Keithley DMM7510 DMM (Thanks KungFuJosh)
Added: R&S RTB2004 Oscilliscope (Thanks 2X)
Added: Build in function to view/edit AutoRun/AutoInit files (Edit uses a OS supplied editor).
Added: AutoInit file, this is a script file that will be executed each time devices are loaded.
Added: getHandle("deviceName") function to return actual handle for a loaded device, based on its name.
Added: isLoaded("handle/deviceName") function to check if a specific device is loaded.
I believe the autoRun facility of TC is mostly ignored, I have made it more easy accessible and also added a AutoInit that is much more useful.
The documentation is here:
https://lygte-info.dk/project/TestControllerAuto%20UK.html it is accessible when pressing F1 in the view window and from the website.
It can be used to make TC automatic do stuff like opening a window when loading devices:
I do not really agree with the HiRes time option, but now it is possible to force more decimal in the tables time column (Right click and select Time or TimeHiRes).
Anybody that dislike my date format (Probably all Americans, they want month first) can now make their own, the full range of Javas time format is available, to get back to my format simply clear the field.
If somebody makes some useful scripts for the Auto files, please post them, I may add a example page at a later date if there are many good ideas.
