Nothing happens, when I right click while editing the address field. The Electronic Load Test Software by Atorch also doesn't see the DL24. Do I need a driver for the DL24? Under which entry is the DL24 usually listed in Device Manager?
Edit: A post by @1RandomUser led me to the BW150 software from Atorch (http://en.atorch.cn/NewsDetail.aspx?ID=84). It runs smoothly on the BW150 even without a firmware update. Is this because the BW150 – and presumably the newer DL24 as well – cannot be accessed via a UART interface? Can the BW150 be supported by TC?
It sound like there is no com port to use, that makes it impossible for TC to connect to the load.
That’s what I was afraid of. Bad news for anyone planning to buy a DL24, as they’ll likely end up with the newer model too. However, the DL24 does have a Bluetooth module. Is it possible to connect to the device via Bluetooth? If I’ve understood correctly,
@1RandomUser managed to upgrade the DL24 to a DW150 with a WiFi module. Would a connection to TC be possible via that? But the DW150 firmware would need to be flashed for that, and then it would no longer be a DL24.
Unfortunately, nothing has changed.
If it worked before you changed name, it will also work after you change the #name string, or you did damage the file.
Sorry, I was wrong. I didn't read the full message. With the original KeysightDMMs.txt-File the message in the Commands-Tab says:
;; USB-Serial Controller (COM9) Did not find any match for: Agilent Technologies,U1253A,MY511xxxxx,V1.20
After changing only the #name string the following message is shown in the Commands-Tab:
;; USB-Serial Controller (COM9) Device "Keysight Technologies,U1253A," do not match answer: "Agilent Technologies,U1253A,MY511xxxxx,V1.20"
When exchanging Keysight with Agilent in both #name and #idString there was no message at all in the Commands-Tab.
But: I’ve also changed the #idString to Agilent again, and now it reports
‘;; Found Agilent U1253A on USB-Serial Controller (COM9) sn: MY511xxxxx’
I’ve no idea what I did wrong the first time. But in the Current values tab, I can only see data in resistance, diode and capacity modes.
I tried creating a new file using ‘Create new SCPI device definition’ and that actually worked straight away. However, I couldn’t find the file named ‘Agilent U1253.txt’ by TC in the Device folder. Reason: TC had saved the file in the newly created folder ‘Users\xx\Documents\TestController\Devices’. But I now had two entries with this name in the device list. As I couldn’t tell which was the new entry, I deleted both devices from the list and restarted TC. The device list was empty, but I still received the message: ‘;; Found Agilent U1253A on USB-Serial Controller (COM9) sn: MY511xxxxx’. I moved the newly created file ‘Agilent U1253.txt’ to a different directory, but still received the message. Renaming the edited ‘KeysightDMMs.txt’ file didn’t change anything either. It was only when I moved this file to a different folder that the message disappeared. Nevertheless, the other Agilent and Keysight devices were still in the selection list. This was because I had merely renamed the unedited ‘KeysightDMMs.txt’ file. Is the content of all files in the Devices folder loaded into TC regardless of their names?
That might also have been the reason why I couldn’t successfully create a new SCPI device definition a second time. Once the files were gone, it worked. A bit confusing.
Data isn’t displayed at all with the newly created file. Configuration is needed. I’ll have to work through your corresponding page for that.
