V3.04 is up
It got a new automatic test function, more bench meters and a lot of modules
Added: Keithley 2001, 2002, 2010 Bench DMM's (Thanks KungFuJosh)
Added: PS and DC/DC converter automatic test, it controls a load, a source, thermometers and DMM's
Updated: Minor modifications to battery test
Added: Elecdemo YK-LED23004M, YK-LED23006M 4 & 6 digit 7 segment display module (Thanks Flash2b)
Added: Elecdemo YK-LED3604M, YK-LED3605M, YK-LED3606M, YK-LED5604M, YK-LED5605M, YK-LED4006M, YK-TMLED3904M, YK-MILED3906M 7 segment display module (Thanks Flash2b)
Added: Ebyte AXCX4020, XACX0420, AACX2220, AXCX4040, XACX0440, AACX2240 and XXCX0080 Isolation AI-DI-DO module (Thanks Flash2b)
Added: UNI-T UT8805 DMM (Thanks squirrax)
Updated: HSPY-400-1 and Kunkin KP184 to support modbus sharing interface (Thanks Flash2b)
Updated: Flash2b has updated all Eletechsup and a few other to support the modbus sharing
Updated: GWInstek GPP-4323 Power supply, names adjusted (Thanks flash2b)
It works in a way very similar to the battery test.
The new automatic test function can test power supplies and DC/DC converters, it will do 3 type of test:
Point: Test a specific working point and record all data in a table.
Load sweep: Sweep load from 0 to maximum while recording data
Load test: Run for some time with a specific load (Useful for logging working temperature).
All tests can automatic be performed at a couple of different voltage and currents.
Charts and CSV files are saved of all tests.
Help page for function:
https://lygte-info.dk/project/TestControllerPopupPSTest%20UK.htmlPower supply test example:
https://lygte-info.dk/project/TestControllerPopupPSTestExampleAC%20UK.htmlDC/DC converter example:
https://lygte-info.dk/project/TestControllerPopupPSTestExample%20UK.htmlThe popup may still have issues, it support a wide variety of configuration and I have not tested all of them.
Also not default parameters are for testing the popup, the test time must be much longer to do real tests.
