Author Topic: Program that can log/control many multimeters and other devices.  (Read 1564896 times)
0 Members and 380 Guests are viewing this topic.
Offline MrPete
Re: Program that can log/control many multimeters and other devices.
« Reply #6500 on: June 12, 2026, 09:24:20 pm »
It appears also, if I don't want to modify values but DO want to incorporate additional columns of data, my choices are either:
a) Use expressions that work inside Math or a live script during data collection (see https://lygte-info.dk/project/TestControllerMath%20UK.html#Including_a_control_variable_in_the_data )
b) After data collection is complete, my only option is to fully replace the entire table (eg tableAddCSVText()) or redo the table from scratch one row at a time (tableInitHeader() and tableAddRow() ).
Does that sound correct?
You can add math expression after the logging is done, math is only blocked while logging is running.
Great for others. Thanks for confirming this!
For my use case, even a custom math expression can't process multiple rows (eg calculate a trend).
So, I've rewritten my applet to be a standalone script. I've hit the following exception when writing a new table. I set the third parameter to 1, to recreate the index column. Not sure why this produces Array Index Out Of Bounds? Do I need to incorporate an "Index" header?
#calc
java.lang.ArrayIndexOutOfBoundsException: 12
        at dk.hkj.database.DataRow.load(DataRow.java:144)
        at dk.hkj.database.DataBase.loadFromList(DataBase.java:349)
        at dk.hkj.database.ScriptFunctions$30.execute(ScriptFunctions.java:988)
        at dk.hkj.script.Script.parseValue(Script.java:279)
        at dk.hkj.script.Script.parseBitOp(Script.java:326)
        at dk.hkj.script.Script.parseProduct(Script.java:398)
        at dk.hkj.script.Script.parseSum(Script.java:480)
        at dk.hkj.script.Script.parseCompare(Script.java:535)
        at dk.hkj.script.Script.parseLogical(Script.java:571)
        at dk.hkj.script.Script.parseQuestionMark(Script.java:597)
        at dk.hkj.script.Script.parseExpression(Script.java:622)
        at dk.hkj.script.Script.statement(Script.java:1109)
        at dk.hkj.script.Script.doExecute(Script.java:1260)
        at dk.hkj.script.Script.execute(Script.java:1282)
        at dk.hkj.script.Script.execute(Script.java:1288)
        at dk.hkj.main.CommandProcessor.sysCmdCalc(CommandProcessor.java:2426)
        at dk.hkj.main.CommandProcessor.processCommands(CommandProcessor.java:2986)
        at dk.hkj.main.CommandProcessor$CmdEnvironment.run(CommandProcessor.java:369)
        at dk.hkj.main.CommandProcessor$BackgroundCommands.run(CommandProcessor.java:1789)
;; #calc failed due to 12
// 6. Inject the data matrix
tableAddCSVText(masterTsvBuffer, "", 1);____<----____
Offline MrPete
« Reply #6501 on: June 13, 2026, 03:05:08 am »
@HKJ - another minor bug. And a less minor challenge...
MINOR BUG
I've loaded Table with some saved data.
If I then UNcheck the "dateTime" selector on the right side of Table...
   - The dateTime column DOES disappear
   - BUT the column header mouseover popup still reflects the original column sequence.
Result: every column from where dateTime to the end now has incorrect column header mouseover text.
NOT SO MINOR ;)
The following data chain causes dateTime data to become mangled:
a) Record data in the normal way from live devices. Shows up in Table correctly
b) Export the data to a CSV file. The CSV version of dateTime is a Unix timestamp in seconds (and fractions) since 1/1/1970
c) Load the data back into Table. It is correctly restored
d) Pull the data programmatically via table(<row>,<col#>) - in this case, the data is formatted as yyyymmddhhmmss
    (assemble the data with intervening tabs into a tab-delimited CSV buffer)
e) Reload table from the CSV buffer: tableAddCSVText(masterTsvBuffer, "", 0);
RESULT: the dateTime column now has values like 31/01-644003 06:32:02
(My guess: the import still wants Unix timestamps, not yyyymmddhhmmss like what table(<row>,<col>) produces)
Do you consider this a bug, or something that just needs documentation and some kind of timestamp conversion during scripted export/import?
Offline HKJTopic starter
    • Tests
« Reply #6502 on: June 13, 2026, 11:06:29 am »
#calc
The table and all arrays are 0 based, i.e. if they have 3 columns, they are number 0, 1, 2 and 3 is Index out of bounds.
    • Tests
« Reply #6503 on: June 13, 2026, 11:13:54 am »
MINOR BUG
I have fixed it, it will be included in next update, test or release.
It did also affect search in table and format changes.
NOT SO MINOR ;)
It is not really a bug, but is related to how variable works, especial a dateTime data type. It has the unix value and a format specification that is used when you request the values as a string. Try typecast it to double(), then I expect you will get the number.
The following users thanked this post: MrPete
Offline MrPete
« Reply #6504 on: June 13, 2026, 12:49:50 pm »
#calc
I get that. What I am saying is, the function tableAddCSVText(csv,columnNames,addIndex) is documented with "if the last parameter is non-zero a index column is added before the data."
What I described above is: if I set the third addIndex parameter to 1, then I get the above Index out of bounds exception. If I set it to zero, tableAddCSVText works, but no index column is created of course.
Offline MrPete
« Reply #6505 on: June 13, 2026, 01:11:01 pm »
MINOR BUG
NOT SO MINOR ;)
Here's the real answer:
=table(5,"dateTime")
;; 20260607203921
=double(table(5,"dateTime"))
;; 20612.11066127315
=long(table(5,"dateTime"))
;; 1780886361134
Typecast to long appears to be what the CSV importer is expecting. Nice: that is a value in Unix milliseconds, and DOES incluide the fractional seconds portion :) We should document that for future users.
(I would also suggest that perhaps the table() reader should offer a mode or option that directly provides data that can be re-injected across the board w/o typecasting. This will avoid a lot of niggly code on the user side. The system knows all about each column. Being able to programmatically save/load table data without undue pain seems a valuable goal.
Which leads to an obvious (?) question:
When performing programmatic loading of the table, how should extracted tableColumnUnit() data be injected into the new table?
    • Tests
« Reply #6506 on: June 13, 2026, 02:04:15 pm »
Ok, the name of the index column is supposed to be the first item in columnName, but I have changed the code so a empty columnName will add "index".
    • Tests
« Reply #6507 on: June 13, 2026, 02:06:46 pm »
;; 20260607203921
;; 1780886361134
Documentation adjusted.
It is not really supported at the current time, maybe it would be a good idea to add it.
Uusally TC will check the device database for handles that matches the first part of the column name.
Offline MrPete
« Reply #6508 on: June 13, 2026, 06:23:53 pm »
Are you saying I should leave an empty first column to be filled by TC? That's not what I would have guessed. My assumption was, TC would insert an additional column before my columns, containing an index.  That's how I read "index column is added before the data."
    • Tests
« Reply #6509 on: June 13, 2026, 06:35:57 pm »
Sort of, when you specify the columns:
Data: value1, value2, value3
You specification when doing automatic index addition: index, value1, value2, value3
The behavior when reading the header line from the file was not useable, that is the reason I changed it.
Offline MrPete
« Reply #6510 on: June 13, 2026, 07:00:43 pm »
To be precise, is this the new way you've coded it?
Assume I have a CSV memory buffer with N columns of CSV data.
If Auto-Index is enabled, any of these will work:
  a) call with same data in 1st parameter, and columnNames param with "index," pre-pended
OR
  b) call with same data in 1st parameter, and empty columnName param. TC will note that there's no "index" column, and will insert it.
OR
  c) insert a blank column before data columns in 1st parameter, with header name "index". Empty columname param. TC will see "index" and fill that column.
Offline MrPete
« Reply #6511 on: June 13, 2026, 07:05:03 pm »
@HKJ I am encountering additional CSV import challenges.
To solve this, I want to write my data buffer to a file. I see ways to LOG to a file, but don't see a simple file write function in the programming language.
Is there a way to do this? I have a BigStringVariable and want to write its content to a file.
Never mind - found it. fileAppendText() and fileAppendClose();
« Last Edit: June 13, 2026, 07:13:54 pm by MrPete »
    • Tests
« Reply #6512 on: June 13, 2026, 07:18:01 pm »
OR
OR
The two formats supported is:
"index";"time";"minutes";"dateTime";"VSG.Sine"
0;0,016;0,00026666666667;1781377870,893;0
1;0,026;0,00043333333333;1781377870,902;0,06283
2;0,038;0,00063333333333;1781377870,914;0,13823
3;0,046;0,00076666666667;1781377870,922;0,18848
or
With a columnNames param: "\"index\";\"time\";\"minutes\";\"dateTime\";\"VSG.Sine\""
Note the \" is required because the parser will use a single "
If you want to add index to the two above:
With the current version it is not possible with the first example, but the updated version will add a "index" column at the start, i.e. there will be two index columns.
For the second example you must modify the header line to: "\"myIndex\",\"index\";\"time\";\"minutes\";\"dateTime\";\"VSG.Sine\""
    • Tests
« Reply #6513 on: June 13, 2026, 07:20:59 pm »
The tableAddCSVText() uses the same code as loading a file, but gives you the flexibility to add a header in code.
Offline MrPete
« Reply #6514 on: June 13, 2026, 08:02:15 pm »
or
A few notes and updates on this, based on testing:
1) I'm not sure what format you're describing above. My guess: your example is semicolon-separated (";") -- perhaps because that is needed in parts of the world where fractional numbers are "123,45" instead of "123.45"???
2) I've got examples with no quotes around the column header names. Of course they ARE needed if certain characters are embedded. One of the simplest formats is tab-separated. That's compatible with all number formats, and requires no quoting. :)
MOST important: What we determined above about dateTime conversion is wrong. It is NOT enough to typecast table(n,"dateTime") to long!
What the importer expects is seconds with fractions. While some unixes auto-recognize both formats, right now the TC importer does not :(
If I convert the data as follows, it works, both using the CSV table loader and if I load into table from a file:  ...long(table(n, "dateTime"))/1000.0;
    • Tests
« Reply #6515 on: June 13, 2026, 08:11:19 pm »
That is the csv format that is used around here, but as you already know TC support both common csv formats.
My example was just copied from a csv file.
The importer can also handle windows data-time format, if the field is not fully numeric it will try the current windows data-time format.
Offline MrPete
« Reply #6516 on: June 13, 2026, 09:01:07 pm »
Unfortunately, table() doesn't produce that either. At least typecast to long and divide by 1000 is a data conversion path that works :)
    • Tests
« Reply #6517 on: June 13, 2026, 09:08:41 pm »
I will consider adding a function to do it in one operation.
Offline MrPete
« Reply #6518 on: June 14, 2026, 02:33:22 am »
@HJK, is there a programming limitation on nested while loops?
I have the following code. It dies (no exception - just 'stuck' waiting for me to click the Abort button) on the inner break statement.
The logical nesting is:
while
   if
      while
           if
               break
           endif;
       endwhile;
    // I expect the break to continue here. But nothing happens...
(not shown: later endif and endwhile
loopIdx = 1;
while loopIdx < (totalSamples-10) do
return0(printLog("loop "+loopIdx));
if test1 && test2
var loopIdxR = loopIdx;
while loopIdxR < (totalSamples-10) do
return0(printLog("loopR "+loopIdxR));
if abs(cDSlopeArray[loopIdxR]) < 0.0001
return0(printLog("found stable, about to break at "+loopIdxR));
break;
endif;
loopIdxR = loopIdxR + 1;
endwhile;
return0(printLog("found stable at "+loopIdxR));
    • Tests
« Reply #6519 on: June 14, 2026, 07:08:06 am »
Not to my knowledge.
What you found was a bug and I hope it is fixed now.
You can download a new test version.
Offline flash2b
  • Everything I like about myself is better with you.
« Reply #6520 on: June 14, 2026, 09:40:03 am »
I have a GPIB device, not SCPI compliant so Ascii driver.
I need to send [CLR] to the device and wait for a bit and then I need to send a command to it to get the device id.
I use #initCmd
Will this be executed before model? and what do I need to do?
#initCmd [CLR];[5000] does not show any clear statement in the debug log and also the meter does not init.
They say attention is a shovel. It's time to dig 'em out.
    • Tests
« Reply #6521 on: June 14, 2026, 09:58:12 am »
I use #initCmd
#initCmd is execute right after *idn?
There is no way to get around that.
Offline flash2b
« Reply #6522 on: June 14, 2026, 10:00:04 am »
Yes I found that out, I need to send CLR before identification. So there is no way around that?
also is it [CLR] or tx [CLR] ?
I can sent ++clr from the AR488, but I need to wait a while. can I delay #verifydevice ?
« Last Edit: June 14, 2026, 10:02:21 am by flash2b »
    • Tests
« Reply #6523 on: June 14, 2026, 10:19:07 am »
In SCPIx either way works.
Offline flash2b
« Reply #6524 on: June 14, 2026, 10:23:24 am »
But I use ascii.. so tx [CLR] ?
Is there a way to delay the #verifydevice after the AR488 does its initialisation ?
