Author Topic: Program that can log/control many multimeters and other devices.  (Read 1780890 times)
yaromka, Gertjan and 87 Guests are viewing this topic.
Online HKJTopic starter
    • Tests
Re: Program that can log/control many multimeters and other devices.
« Reply #6675 on: July 06, 2026, 08:29:59 am »
Something I see in a number of scripts (genericized here):
="STARTING PARAMETERS "
="Start Voltage = "+startVoltage+" Volt"
="Discharge Current = "+drainCurrentAmps+" Amps"
AFAIK in general, one way to emit a status/error message to the console/log is:
="message"
I attempted to combine that with the triple-quote long-string capability, in a script file...
This is
a long
message
But that fails with an exception. Clearly the contents of the string are being parsed. (my long string contained
     (default: 0.5Ah)
which generated an exception.
Is it possible to do a long-string message?
No, = and # are single line commands (#calc excluded when used outside the command line)
Triple quotes do not work together with # commands, the simple parser that looks for expressions cannot handle it.
SOLUTION AND DIAGNOSIS: From commands tab:
=""foo"" -> comment to log
="""foo""" --> sends to device
#calc """foo""" -> comment to log
so, """long string""" is ONLY for #calc mode?
Basically, it can also be used inside programs stored in their own files.
When doing definitions it can also be used, with a few caveat's
What it will not do is stretch single line stuff to multiple lines.
The following users thanked this post: MrPete
Offline MrPete
« Reply #6676 on: July 06, 2026, 02:07:22 pm »
@HKJ this appears to be a bug...
this simple script fails, saing #haslogged only works if logging is active -- but I just turned logging on!
#log 0
#calc
runScript("""
#log 0.1
#HasLogged
#log 0
If I insert some extra stuff before the #log 0.1, it works. these two lines fix it. does the parser require a plain "#" first?
I'm also discovering runScript() inside a #calc seems to run a separate thread, so I need to use globalvar's instead of vars...
="a message"
    • Tests
« Reply #6677 on: July 06, 2026, 02:18:07 pm »
#log 0
#calc
runScript("""
#log 0.1
#HasLogged
#log 0
Log is asynchronous, i.e. the start is posted to another thread and it can be a fraction of second before it is processed.
Because the script language can run asynchronous to everything else in TC a lot of stuff runs through a synchronization to do a specific function. Sometimes the script is paused at other times it is not.
="a message"
Both programs and scripts run in separate context and often separate threads.
Separate context will often transfer variables from the caller to the routine, but the routine can only create variables local to itself. A getVarList(2) will show these variables if they exist (Depending on calling depth, it might not be 2, but 3, 4, 5, etc.).
A context keeps track of position inside a program and a lot of other stuff, i.e. any time you run another script/program a new context is needed to keep track of the position.
    • Tests
« Reply #6678 on: July 06, 2026, 02:30:50 pm »
Let me elaborate a bit more on this:
A script instance is generally married to a programming language instance and they share variables.
The programming language do not need a script instance and can run on its own, i.e. if a programming language is launched, it will not include a script context.
If a script is launched it will include both a script and a programming language.
The programming language with a script is used for parameters, = and #calc, not for function calls to start a new programming language.
Offline MrPete
« Reply #6679 on: July 06, 2026, 04:03:42 pm »
this simple script fails, saying #haslogged only works if logging is active -- but I just turned logging on!
#log 0
#calc
runScript("""
#log 0.1
#HasLogged
#log 0
So, is there a reliable way in this situation to ensure the log is running?
I would have thought #haslogged would accomplish that.
    • Tests
« Reply #6680 on: July 06, 2026, 06:54:52 pm »
Do a short delay.
Offline MrPete
« Reply #6681 on: July 07, 2026, 01:20:25 am »
@HKJ,
With some extensive testing, I'm convinced this isn't a logging issue at all. (The log actually is NOT running! Nothing collected... :) )
Sure appears to be a bug. Here is a very simple script that fails. No matter what I have tried so far (many variants, including first command on the  runScript(""" line, a plain "#", etc etc... I get three results every time:
* a message that #calc failed, "due to Expect a )"
* the first command in the runScript string is never executed or seen
* there's an "Invalid device <>" error.
Script:
#calc
runScript("""
#echo 1234567
#echo 7654321
Result:
#calc
;; #calc failed due to Expect a )
runScript("""
____<----____
#echo 7654321
;; 7654321
;; Invalid device <>
    • Tests
« Reply #6682 on: July 07, 2026, 06:45:59 am »
@HKJ,
Script:
#calc
runScript("""
#echo 1234567
#echo 7654321
Result:
#calc
runScript("""
____<----____
#echo 7654321
;; 7654321
Any line starting with # ends #calc mode, i.e. it ends with the "#echo 1234567"
The trick is to code # as \x23, the line parser will not see that as a #, put the string parser will turn it into a # inside the string.
Offline MrPete
« Reply #6683 on: July 07, 2026, 07:59:46 am »
Here's the result:
#calc
java.nio.file.InvalidPathException: Illegal char <
> at index 10: c:\tcdata\
#echo 1234567
#echo 7654321.txt
        at sun.nio.fs.WindowsPathParser.normalize(Unknown Source)
        at sun.nio.fs.WindowsPathParser.parse(Unknown Source)
        at sun.nio.fs.WindowsPath.parse(Unknown Source)
        at sun.nio.fs.WindowsFileSystem.getPath(Unknown Source)
        at java.nio.file.Paths.get(Unknown Source)
        at dk.hkj.main.Support.fileWithOptinalDefaults(Support.java:1645)
        at dk.hkj.main.CommandProcessor.loadScript(CommandProcessor.java:197)
        at dk.hkj.main.CommandProcessor.access$1(CommandProcessor.java:190)
        at dk.hkj.main.CommandProcessor$1.execute(CommandProcessor.java:85)
        at dk.hkj.script.Script.parseValue(Script.java:279)
        at dk.hkj.script.Script.parseBitOp(Script.java:326)
        at dk.hkj.script.Script.parseProduct(Script.java:398)
        at dk.hkj.script.Script.parseSum(Script.java:480)
        at dk.hkj.script.Script.parseCompare(Script.java:535)
        at dk.hkj.script.Script.parseLogical(Script.java:571)
        at dk.hkj.script.Script.parseQuestionMark(Script.java:597)
        at dk.hkj.script.Script.parseExpression(Script.java:622)
        at dk.hkj.script.Script.statement(Script.java:1110)
        at dk.hkj.script.Script.doExecute(Script.java:1261)
        at dk.hkj.script.Script.execute(Script.java:1283)
        at dk.hkj.script.Script.execute(Script.java:1289)
        at dk.hkj.main.CommandProcessor.sysCmdCalc(CommandProcessor.java:2451)
        at dk.hkj.main.CommandProcessor.processCommands(CommandProcessor.java:3011)
        at dk.hkj.main.CommandProcessor$CmdEnvironment.run(CommandProcessor.java:369)
        at dk.hkj.main.CommandProcessor$BackgroundCommands.run(CommandProcessor.java:1789)
;; #calc failed due to Illegal char <
#echo 1234567
#echo 7654321.txt
runScript("""
\x23echo 1234567
\x23echo 7654321""");____<----____
    • Tests
« Reply #6684 on: July 07, 2026, 08:18:44 am »
Here's the result:
This one works:
#calc
runScript("""#
\x23echo 1234567
\x23echo 7654321
The issue is that runScript do not like a empty line at the start. Because it is not at the start of the line I can directly use # and do not need \x23
# is a valid command and is basically a command and means do nothing.
Offline MrPete
« Reply #6685 on: July 07, 2026, 10:05:39 am »
This one works:
#calc
runScript("""#
\x23echo 1234567
\x23echo 7654321
OK, I can do that. That's more than a little subtle of course. We are defining a complex set of workarounds at this point.
It would be a LOT more flexible and simpler, if at an appropriate point in the stream:
1) any blanks ( [\t ] ) were trimmed out of the start of each line.
- Makes it easy to format things nicely such as with #if/#else/#endif
   #if ....
       #do this
    #endif
- Eliminates the need for \x23
2) Allow blank lines anywhere in scripts including runScript()
- Again, much nicer for formatting
- Much less picky for coding
- Avoids rather confusing error messages and exceptions
    • Tests
« Reply #6686 on: July 07, 2026, 10:25:29 am »
There is a very specific reason why it need that # at the start.
I do explain it in the documentation: https://lygte-info.dk/project/TestControllerFunctions%20UK.html#runScript_&_runScriptAsync
   #if ....
       #do this
    #endif
Trimming blank would not help, they are generally trimmed before processing.
When the script parser do is collect line from #calc until the next # in one block and then send that block to the programming language (One the command line it is done line by line).
Generally blank lines are allowed, but you hit a very special situation.
Error messages are often a problem, what the parser see as a problem, is not necessary the original program.
Offline flash2b
  • Everything I like about myself is better with you.
« Reply #6687 on: July 07, 2026, 02:07:44 pm »
Dear HKJ,
I have created a new definition for the Dual channel ComWinTop BSR-DA02B Voltage+Voltage and BSR-AA02B Current+Current source modules.
These are very simple compared to the Elecdemo YK-AO23xxx source modules, and have also no software calibration. They rely on screwdriver calibration on the unit  :-DD
Well they can be controlled with TestController now.
Please add them to the next release of TestController.
[ Attachment Invalid Or Does Not Exist ]
Part of TestController V3.34
« Last Edit: July 12, 2026, 06:25:17 pm by flash2b »
They say attention is a shovel. It's time to dig 'em out.
    • Tests
« Reply #6688 on: July 07, 2026, 03:41:59 pm »
I have added them, thanks.
Offline MrPete
« Reply #6689 on: July 07, 2026, 08:38:26 pm »
I do explain it in the documentation: https://lygte-info.dk/project/TestControllerFunctions%20UK.html#runScript_&_runScriptAsyncal
Tweaked spec could be:
The name is trimmed for any blanks before/after. Then, if the name starts with # it is assumed to be the script.
When the script parser do is collect line from #calc until the next # in one block and then send that block to the programming language (One the c command line it is done line by line).
If I understand correctly, in this case we have a script file, in #calc, so:
* the script parser is collecting lines after the #calc, searching for a "#" at the beginning of a line
* it will then send all of those lines as a block to the programming language.
That's both understandable and unfortunate ;)
* Understandable: easy for the parser, since obviously a #xxx command must be for a script, not programming.
* Unfortunate: because a program can itself call a script using runScript(), and that script by definition can contain #xxx commands
* Clearly this wasn't a necessary design decision. Almost anything could have been chosen as the termination marker for #calc.
I have yet another suggestion worth about as much as you paid for it LOL. Obviously, this is your design; I'm just a user, and only for a year or so on this system ;)...  Suggestion: for more comprehensive  programs, a more stable start/end marker pair would be much simpler to code for, such as
#calcblock
(program)
#endcalcblock
YES they are :)
I have now (mostly?) debugged my 600+ line analyzer program. It's been quite the adventure decoding the error messages. I can say I am now far more familiar with the interesting error messages associated with various typos etc. Rarely do they have much to say directly about the problem. LOL.
In general, any typo or error in a program (vs script) produces a message saying #calc terminated, usually due to "Value". And that's the only hint. (For others attempting to program: adding LOTS of debug messages can help quite a bit; even so, the actual error may be several lines away from where you believe it is. :) )
Offline MrPete
« Reply #6690 on: July 07, 2026, 08:41:47 pm »
Silly (?) question: how do I set the display units for #popupnumber?
When showing/entering a normally decimal number such as 0.25 Ah, it eventually is wearying to see 250m instead of 0.25 ;)
    • Tests
« Reply #6691 on: July 08, 2026, 07:39:57 am »
runScript() do not only direct script, but was designed to run external files or named scripts loaded by TC (I.e. like a library)
You can also do runScript("#echo 1234567\n#echo 7654321");
Only in the case where you use a multiline staring with # command, will there be issues and it is possible to get around them.
#calcblock
(program)
#endcalcblock
I like you suggestion, from next version of TC there will be:
#calcStart
#calcEnd
In addition to the regular #calc
Making this valid:
#calcStart
runScript("""#
#echo 1234567
#echo 7654321
#calcEnd
I have modified the error output from the script parser slightly, now it will also say the name of the exception, this can in a few instances make it easier to guess what went wrong.
    • Tests
« Reply #6692 on: July 08, 2026, 08:05:49 am »
You can't, it is fixed
Offline flash2b
« Reply #6693 on: July 08, 2026, 10:06:29 am »
The #cmdSetup numberDual suffers from the same bug you fixed that was with #cmdSetup infoAsk.
You cannot use :enable: on #cmdSetup numberDual it will always be on.
Could you fix this ?
    • Tests
« Reply #6694 on: July 08, 2026, 10:43:13 am »
It is fixed.
I did never add it to the control, there are probably a few other controls with the same issue.
Offline flash2b
« Reply #6695 on: July 08, 2026, 11:03:41 am »
You fixed it! Thanks !
Offline flash2b
« Reply #6696 on: July 08, 2026, 12:17:17 pm »
Still a minor problem. The editable fields do not have a white background. Re-enabling on/of fill make them white but not after the first render of the menu,
The two controls are numberDual the other are advNumber and they work just fine.
« Last Edit: July 08, 2026, 02:57:04 pm by flash2b »
    • Tests
« Reply #6697 on: July 08, 2026, 01:12:51 pm »
The two controls are numberDual the other are number and they work just fine.
I have fixed it, but you do not get a new version just yet.
Offline flash2b
« Reply #6698 on: July 08, 2026, 01:29:02 pm »
fine... it is not a big problem.
Offline MrPete
« Reply #6699 on: July 08, 2026, 02:31:19 pm »
#calcStart
#calcEnd
Making this valid:
#calcStart
runScript("""#
#echo 1234567
#echo 7654321
#calcEnd
AWESOME!!! That will GREATLY help! I suspect it will help resolve/avoid other issues. I've got another one blocking me right now. Will separately post.
