Author Topic: Program that can log/control many multimeters and other devices.  (Read 1818752 times)
Pippo77 and 74 Guests are viewing this topic.
Offline flash2b
  • Everything I like about myself is better with you.
Re: Program that can log/control many multimeters and other devices.
« Reply #7225 on: August 16, 2026, 09:16:37 am »
I'm facing another problem.
My device's temperature values live in input registers (function code 0x04). TC has the full holding-register set - holding?, holdingS?, holdingF? - but for input registers only the unsigned input? exists; there is no inputS? or inputF?.
The floating-point temperature block (0x01C2) would need an input-register float read (inputF?), which does not exist, so I fall back to the integer block (0x0190) with /10. But those integers are signed, and without an inputS? I cannot read
negative temperatures - and this device is specified from -200 degC (XEXX:-200~1350 degC @ 2%, XDXX: -200~850 degC @ 1%), so negatives are well within range, not an edge case.
I can add a per-channel readmath (((value+32768)%65536)-32768)/10 to fix the sign manually, but that forces one read per channel, so I lose polling all 6 values in a single transaction.
Could you add inputS? (and ideally inputF?) to mirror the existing holding commands? Either one solves it: inputF? lets me use the float block directly (signed by nature, no scaling), or inputS? lets the integer block handle negatives.
« Last Edit: August 16, 2026, 09:21:22 am by flash2b »
They say attention is a shovel. It's time to dig 'em out.
Offline flash2b
« Reply #7226 on: August 16, 2026, 09:53:56 am »
Major problem in the TC test version v3.50
#verifyDevice does not work anymore for all my definitions that use identification like #verifyDevice DM36B06 model?
TC release version 3.48 still works.  (but does not work on Mobus TCP)
Offline HKJTopic starter
    • Tests
« Reply #7227 on: August 16, 2026, 10:28:33 am »
That do not make sense.
I connected my two DM36B06 and they work perfectly.
I did also compare the current modbus driver to the 3.48, there are two changes: #unitid and separate read/write for network folded into a combined read/write.
    • Tests
« Reply #7228 on: August 16, 2026, 10:34:00 am »
Looks like I can fairly easy give you these commands, note F is a 32 bit value.
Offline flash2b
« Reply #7229 on: August 16, 2026, 10:34:51 am »
I emailed you the log, mine does not work in 3.50
    • Tests
« Reply #7230 on: August 16, 2026, 10:39:36 am »
Are you using the exact same definition file in the two version?
When using #meta stuff, the files in documents\... do not take precedent.
Offline flash2b
« Reply #7231 on: August 16, 2026, 10:43:42 am »
Yes.
v3.50:
Start thread for: Modbus Port1:1 - Eletechsup DM36B06
Modbus Port1:1: Tx <holding? 0xFE>
COM5: Tx: 01 03 00 FE 00 01 E5 FA
COM5: Rx: 01 03 02 00 03 F8 45
Modbus Port1:1: **Device do not match** <DM36B06>
Modbus Port1:1 Device "Eletechsup,DM36B06," do not match answer: "**Device do not match** <DM36B06>"
COM5: Close
Stopping thread for: Modbus Port1:1 - Eletechsup DM36B06
COM5: Close
v3.48 Connects fine:
Found Eletechsup DM36B06 on Modbus Port1:1
« Last Edit: August 16, 2026, 10:46:53 am by flash2b »
    • Tests
« Reply #7232 on: August 16, 2026, 10:52:21 am »
Yes.
v3.50:
COM5: Close
COM5: Close
I have put up a new test version 3.51, I have not done anything to fix your problem, because I do not have it. I use the last update you submitted of the definition, the same that is included in the release version.
But now input? exists in the same versions as holding? It is, of course, untested, but holding and input share code, only difference is a flag.
The following users thanked this post: flash2b
Offline flash2b
« Reply #7233 on: August 16, 2026, 11:10:16 am »
3.51 tested:
- #subDriver TCP in #metadef now works
- inputS? works
- inputL? works
- inputSL? works
- inputF? works
- DM36B06 also works for me now... (forced to release version) will investigate why
So all works, and the first ever definition that uses Modbus TCP now also works !!
Thank you
« Last Edit: August 16, 2026, 02:56:18 pm by flash2b »
    • Tests
« Reply #7234 on: August 16, 2026, 04:43:56 pm »
I have been working on a article that explain some of what TC can do, it is fairly shortform, but with links to relevant help pages:
https://lygte-info.dk/project/TestControllerHowToDo%20UK.html
Comments are welcome.
The following users thanked this post: KungFuJosh, Cyclotron
Offline Cyclotron
  • *POOF*
« Reply #7235 on: August 16, 2026, 08:19:49 pm »
Very nice, I have been over it briefly and think this is great. I will spend more time reviewing it to see if there's anything I can offer that might help.
Online KungFuJosh
  • TEAS is real.
« Reply #7236 on: August 16, 2026, 09:11:05 pm »
That looks like a good start.
The thing I don't like about your website is that it doesn't have a functional menu system on every page. For example, for anything I might need to review separately, I have to bookmark separate pages.
A good menu structure would help people navigate the site, and find things faster for working in TC and adding devices. Something like (Bold = Parent; Indent = submenu items):
Home
Getting Started
   Install Guide
   How To Do (the new page)
   Docs for Main Pages
   Docs for Popups
Adding Devices
   New Device
   Configuration of SCPI Devices (and SCPIx)
   Configuration of Non-SCPI Devices
Scripting
   Script Commands
   Scripts for Device Configuration
Examples
   Scripting example
   Battery test with resistor
   Script for charging a USB charged battery and labeling the chart
   Using a Arduino with Test Controller
   User Scripts
   User Projects
I would use a simple horizontal menu bar at the top of the page.
Thanks,
Josh
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
Offline Cyclotron
  • *POOF*
« Reply #7237 on: August 16, 2026, 10:37:03 pm »
Bug or user error.
I've got a driver I'm about to pos that I've been working through. I was trying to use selectors/layout and found an issue where corruption would appear in the menus. The attached is a way to simply reproduce the issue
; TO RUN
;   1. Move the stock VirtualSinusGenerator.txt out of your Devices folder.
;      This file claims the same #idString, and only one can win the match.
;   2. Drop this file in Devices and restart TestController.
;   3. Add the VirtualSinusGenerator device and open its Setup dialog. It keeps
;      the stock name on purpose.
Now just let TC connect to to the virtual device and go to the "setup" menu. See Setup-Startup. Things look "ok".  When you select "1s" the menu changes dynamically and the first aberration appears in the bold of Sub-B, then go to the "3S" selection and you see the item corrupted.
The test driver has more doco in its header.  Let me now if you want more details.  I've worked around this by using another method to do the menu.
Offline Cyclotron
  • *POOF*
« Reply #7238 on: August 16, 2026, 10:54:40 pm »
New Driver, Chroma 63000 series electronic loads.  There are two in this series and I have tested the 63004-150-60.
Note that I developed this driver on TC connected to VMSG as my Chroma only has the USB interface and is on my VISA management system.  These Chroma models can have a GPIB interface, I just don't currently have one. I very much believe this driver will work directly with GPIB. I emulated the Prologix Ethernet Adapter on the TC side.
Driver attached and committed to this Github repo with further documentation and screenshots.
https://github.com/Cyclotronic/TC-Drivers/tree/main/drivers/Chroma_63000_Series
Offline flash2b
« Reply #7239 on: August 17, 2026, 08:28:46 am »
Your UI, looked at the Github, look great. Nicely done.
You might consider changing #cmdSetup buttonsOn into #cmdSetup toggleButton, so more KungFuJosh style.
I use both in my defs, depending on it's use.
The following users thanked this post: Cyclotron
    • Tests
« Reply #7240 on: August 17, 2026, 09:43:22 am »
Added, thanks.
    • Tests
« Reply #7241 on: August 17, 2026, 09:44:10 am »
Bug or user error.
Nested selectors is a issue.
    • Tests
« Reply #7242 on: August 17, 2026, 09:50:25 am »
A menu requires a use a tool to generate the webpages or program in java script, I do not really like either option.
You menu structure is here, but in links:
https://lygte-info.dk/project/TestControllerIntro%20UK.html
You can also open relevant devlop pages from the filter menu on the load devices page.
And if you need help to a TC page, you just press F1.
I use the above and do not really see any issue with it (A menu would be nicer, but it is not really a obstacle).
Online KungFuJosh
  • TEAS is real.
« Reply #7243 on: August 17, 2026, 03:18:29 pm »
I'll PM you about it.
Offline Salient666
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #7244 on: August 17, 2026, 06:12:17 pm »
I am playing with TestController lately and I ran into an 'issue'.
Whenever I closed the program, all my meters would reset to their default state (which is good) except the Siglent SDM4065A.
I looked at the FinalCmd line and I copied the same line that is in the Keysight file there to see if that would help.
That line is:
#finalCmd ABOR;*CLS;*RST;INIT;SYST:LOC
And indeed, the meter now resets as it should (and turns off autoZero, which can't be activated by SCPI at the moment because... siglent....)
@KungFuJosh: I think this should be made default?
Buying 6-1/2 digit bench multimeters just to check if a regular nine-volt battery is still alive.
Online KungFuJosh
  • TEAS is real.
« Reply #7245 on: August 17, 2026, 06:16:28 pm »
That line is:
Maybe... I don't like the way it behaves with that full line right now. ABORT;*CLS is currently the finalCmd, but I can at least add the SYST:LOC if it works. I don't want to update the definition until after a firmware update. Siglent needs to fix the SCPI issues.
You can, of course, add that to your local file if that's what you prefer.
Thanks,
Josh
The following users thanked this post: Salient666
Offline Cyclotron
  • *POOF*
« Reply #7246 on: August 17, 2026, 08:14:05 pm »
Bug or user error.
Thanks! I didn't know if it was a known issue.  The modified driver for the internal virtual device helped me determine it was in TC, not in my driver. So I shared it in case you wanted to see it or test.
Offline Cyclotron
  • *POOF*
« Reply #7247 on: August 18, 2026, 02:15:03 am »
I've tweaked the Chroma driver since I found a slight issue. I think the menus look nicer.
Screen shots and write up in the repo.
The other driver here is a duplicate and I had worked on it significantly before I realized it was a duplicate. The current HPe363xA bench power supply driver only seems to support serial which is why I didn't notice it before.  The one attached was developed on a HP E3633A attached to GPIB.
I don't know if you will want it since its a duplicate.  I'll take your advice on that.
    • Tests
« Reply #7248 on: August 18, 2026, 06:49:15 am »
I have updated the chroma driver.
I do not know what HP driver I want. I want the one that support most functions on the power supply, but your explanations do not say if your driver support more, the same or less. Obvious it supports GPIB, but that update may be as simple as add the word gpib to the already existing driver.
A screenshot of both configuration menus may also help.
Offline flash2b
« Reply #7249 on: August 18, 2026, 06:59:04 am »
A suggestion on range for controls that support this.
#cmdSetup number CH1 Offset_CH1-6
:read: offsetShapeCH1?
:write: offsetShapeCH1
:tip: Temperature offset in °C (0.1 resolution; 0 = Default; positive value raises the reading, negative value lowers it)
°C -100.0 100.0
The range is °C -100.0 100.0 which is rendered like the screen shot.
What I do not like is that TC uses - sign to connect lower and upper side of the range. Normally this is ok, but if the range is negative to positive it does not look clear.
Can the control be modified that when it occurs a + sign is added to the upper side, or a :-command to add a + in the definition itself. The example is Temperature, many be not the most common use, but it is also for Voltage and Current.
