Author Topic: Program that can log/control many multimeters and other devices.  (Read 1789273 times)
n109 and 148 Guests are viewing this topic.
Offline flash2b
  • Everything I like about myself is better with you.
Re: Program that can log/control many multimeters and other devices.
« Reply #7375 on: August 28, 2026, 01:57:19 pm »
Can #ChartCurves reference a math column? I create math entries from an Other menu with #Math and they show up correctly in the Math window with data, but listing the name in #ChartCurves does not select them. Clicking the same curve by hand in the chart works.
Example:
#Math AVG_CH1_30 °C Average 30 XEXX0600.TempCH1 then #ChartCurves AVG_CH1_30
If math columns need a different name form there, what is it? If they are not supported, could they be?
They say attention is a shovel. It's time to dig 'em out.
Offline HKJTopic starter
    • Tests
« Reply #7376 on: August 28, 2026, 02:04:56 pm »
Example:
They are supported, battery test uses them (It do some stuff by running a script).
But there can be timing involved, they can first be selected when they exist in the table. Do you have a #waitui after changing the math columns?
Offline flash2b
« Reply #7377 on: August 28, 2026, 02:25:45 pm »
I had a \x23delay 5
but that doesn't work as planned. I see the curves disable but the AVG curve not enable
Offline flash2b
« Reply #7378 on: August 28, 2026, 02:30:25 pm »
No luck. What I have tried in the Other menu of a definition:
  \x23Math AVG_CH1_30 °C Average 30 XEXX0600.TempCH1     (x6, one per channel)
  \x23waitui
  \x23ChartCurves AVG_CH1_30 AVG_CH2_30 ... AVG_CH6_30
The math entries are created, they show in the Math window with the checkbox on and they have data. #ChartCurves does not select them. Raw device columns in the same #ChartCurves line do get selected, so the command itself is working.
Also tried: #delay 5 instead of #waitui, both together, and runScript instead of runScriptAsync. Same result each time. Clicking the same curve by hand in the chart works immediately.
Does the battery test run its script from the ScriptLibrary rather than from an Other menu, and would that make a difference? Or is there something else that has to happen between creating a math entry and selecting it as a curve?
    • Tests
« Reply #7379 on: August 28, 2026, 02:32:46 pm »
I had a \x23delay 5
You know you can first select curve when first entry is logged?
#log 1
#haslogged
Will start logging and wait for first entry.
I checked my code:
sb.append("#chartcurves " + getVoltmeterScale(charge) + " " + getCurrentScale(charge)+ " Math.Capacity Math.Energy\n");
CommandProcessor.runScript(sb.toString());
Nothing special in that, but I do first run it about 2 second after starting logging.
« Last Edit: August 28, 2026, 03:47:39 pm by HKJ »
Offline flash2b
« Reply #7380 on: August 28, 2026, 05:31:33 pm »
My reference need to start with: Math.
Two findings I got: math columns are named bare in #Math but addressed as Math.<name> everywhere else, and #waitui after creating them.
This is not in the documentation.
I got it working after trying numerous times.
    • Tests
« Reply #7381 on: August 28, 2026, 05:36:30 pm »
In TC Math. is used everywhere a math channel is referenced, but I may need to update the documentation for the Math page to make it clear. It would probably also be a good idea to mention #waitui in the #math commands.
Online Cyclotron
  • *POOF*
« Reply #7382 on: August 29, 2026, 12:57:02 am »
Another PSU family to the list:
This driver covers the E3640A, E3641A, E3642A, E3643A, E3644A, and the E3645A.
This was created and validated against an E3641A
https://github.com/Cyclotronic/TC-Drivers/tree/main/drivers/HP_Agilent_E364xA
    • Tests
« Reply #7383 on: August 29, 2026, 07:40:43 am »
I have added them, thanks.
Offline PushUp
« Reply #7384 on: August 29, 2026, 02:45:47 pm »
We have a forum member "Maria", who bought the new "Rohde & Schwarz UDS600".
As this is the successor of the "Rohde & Schwarz HMC8012", maybe HKJ is able to give a hint to him or her?
Is it better to add the new ID to the old script or is it better to make a new one for the UDS500 and UDS600 series, as there are probably some new features like:
UDS 500-G/UDS 500:    200.000 counts, 5½ digits
UDS 600-G/UDS 600: 2.000.000 counts, 6½ digits
Unfortunately, I am not that good at doing new definitions, so that it would be nice to help him or her more or better than I could:
https://www.eevblog.com/forum/chat/what-did-you-buy-today-post-your-latest-purchase!/msg6346238/
« Last Edit: August 29, 2026, 03:01:28 pm by PushUp »
Online KungFuJosh
  • TEAS is real.
« Reply #7385 on: August 29, 2026, 02:49:04 pm »
https://www.eevblog.com/forum/chat/what-did-you-buy-today-post-your-latest-purchase!/msg6346238/#msg6346238
Resolution doesn't matter. That can be adjusted for each meta variant. Assuming they use all the same language/features, then adding it should be simple.
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
    • Tests
« Reply #7386 on: August 29, 2026, 02:55:05 pm »
To decide if a new definition file is needed, compare the SCPI commands and how they work, if that is basically the same, add it to the old definition.
If not, make a new definition, maybe copy the old one as a starting point.
For TC a new file is not a big deal, many definitions in a file is to make it easier to make and maintain a couple of very similar devices.
The following users thanked this post: PushUp
Online KungFuJosh
  • TEAS is real.
« Reply #7387 on: August 29, 2026, 02:58:12 pm »
A new file shouldn't be necessary. R&S claims compatibility between the models, and the definition uses si without a digit count. All they need to add to the HMC8012 is:
#metadef
#idString Rohde&Schwarz,UDS600,
#name     R&S UDS600
#handle   UDS600
...and it should work.
Online Cyclotron
  • *POOF*
« Reply #7388 on: August 29, 2026, 04:52:40 pm »
HP Electronic Load 6060B created and validated.
More info and screen shots here:
https://github.com/Cyclotronic/TC-Drivers/tree/main/drivers/HP_Agilent_6060B
    • Tests
« Reply #7389 on: August 29, 2026, 05:05:03 pm »
Added, thanks.
Online KungFuJosh
  • TEAS is real.
« Reply #7390 on: August 31, 2026, 01:57:37 am »
Here's a maintenance release for the Batronix Magnova.
I'm debating adding FFT or Bode plot. Would anybody use those remotely?
Thanks,
Josh
    • Tests
« Reply #7391 on: September 01, 2026, 11:07:23 am »
Added, thanks.
Offline flash2b
« Reply #7392 on: September 02, 2026, 09:56:50 am »
I have added support for the Yokogawa 7555 (both versions) in  Type 0 : 7552 compatibility mode
Furthermore I have done some extending functions of the meter and bug fixing of my Yokogawa 755x and 756x definition, so changelog is long:
Added: Math tab with dB Reference (dBV, dBµV, dBmV, 600, 75 and 50 Ohm), dB Multiplier for KC, Logic Family (TTL/HCT, LVTTL 3V3, CMOS, RS232) with CMOS Vdd, and Scaling Mode (Nominal, Deviation, Shunt) with Nominal Value;
Added: Computation tab holding the constants, Math status and function, split off the Math tab;
Added: IC Card status, Definition version and IC Card support level on the System tab;
Added: Support for the Yokogawa 7555 (RS232/GPIB) in Type 0 : 7552 compatibility mode
Fixed: Reset all Constant values did not reset KA, the scpiCmd was missing none so the first :setvar: was consumed as the action;
Fixed: dataHeadVal decoding read only 3 positions;
Fixed: daOutputVal not assigned the decoded value;
Fixed: IC Card and Front/Rear detection now ignore status bit 4, which is CARD BUSY on the 7563;
Fixed: OSLINESVAL set to 12 for 7563 and addional temperature constants are skipped/ignored, Decibel functions gated due to Not Supported
Modified: renamed to Yokogawa 755x 756x.txt to cover the whole series;
Modified: unit suffix for Ohm_2W, Ohm_4W, freqACV and freqACA on radio range buttons;
Modified: IC Card status now reads Inserted / Not Inserted;
Modified: constMax renamed CONSTMAXVAL and the OS line count moved to OSLINESVAL;
Modified: Constant KD no longer forced into the meter's native format, which the dBµV and dBmV references need;
The new math screen has functions that the meter does not offer, but can be supported in a user friendly manner. TestController can be use to extend functionality of a meter and I use this method often not stopping of just making functions available 1:1.
The 7563 should now also work better since I got the details from a Japanese manual
HKJ
- please delete Yokogawa 7551-7552.txt from your release
- please add Yokogawa 755x 756x.txt to the next release
[ Specified attachment is not available ]
Part of TC
« Last Edit: October 11, 2026, 03:09:28 pm by flash2b »
Offline flash2b
« Reply #7393 on: September 02, 2026, 11:18:48 am »
Notepad++ syntax highlighting for TestController definition files - v1.04
Bugfix (folding) and some missing commands added.
* TestController-Notepad++ UDL pack.zip (8.61 kB - downloaded 19 times.)
« Last Edit: September 02, 2026, 11:24:51 am by flash2b »
    • Tests
« Reply #7394 on: September 03, 2026, 09:59:51 am »
Updated and old file deleted, thanks.
Online Cyclotron
  • *POOF*
« Reply #7395 on: September 03, 2026, 07:42:13 pm »
A driver for the Guildline 6560 resistance standard/calibrator.
  https://github.com/Cyclotronic/TC-Drivers/tree/main/drivers/Guildline_6560
Online KungFuJosh
  • TEAS is real.
« Reply #7396 on: September 03, 2026, 08:04:42 pm »
Here's an updated driver for the Siglent SDM4000A series. Autozero stuff works now.
Thanks,
Josh
    • Tests
« Reply #7397 on: September 03, 2026, 08:05:36 pm »
Added, thanks.
Interesting device and a advanced box for only 19 high precision resistors.
    • Tests
« Reply #7398 on: September 03, 2026, 08:07:52 pm »
Updated, thanks.
Offline flash2b
« Reply #7399 on: September 04, 2026, 08:18:36 am »
Other menu — write a variable to a file and read it back
Is there a way from the Other menu to write the content of a script variable to a text file, and to read that file back into a variable?
