Author Topic: Program that can log/control many multimeters and other devices.  (Read 1808683 times)
HKJ, Gertjan, mawyatt and 250 Guests are viewing this topic.
Offline bicycleguy
Re: Program that can log/control many multimeters and other devices.
« Reply #7425 on: September 05, 2026, 07:34:04 pm »
@HJK
Will there be or is there a version for Mac that doesn't include intel components?  I'm on V2.53 so maybe I just need to update?
Apple keeps claiming the next version of the OS won't include Rosetta to run the Intel stuff.  I used to get warnings on other programs including Java based and updated them but haven't used TestController in a while so haven't updated.  I was kind of surprised that it runs without Apple giving me a warning to upgrade like with other programs.
Comments?
Online HKJTopic starter
    • Tests
« Reply #7426 on: September 05, 2026, 07:39:55 pm »
@HJK
Comments?
Being in Java it do not include any OS or CPU specific stuff (Not completely true, the serial interface has native code for many OS and CPU's).
For Java the rule is that the Java runtime includes all the CPU & OS specific stuff and that is not part of TC, you have to download it from one of the Java sources.
Offline Salient666
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #7427 on: September 06, 2026, 07:15:14 am »
I have a question about a 'quirk' (or maybe I'm doing something wrong) of the math function in TestController.
I have set up a grid with a running average and that works fine, however when I start the grid, or globally reset the grid, the math function always starts with MIN at 0. This means the PP reflects the MAX value at all times, which is not correct.
When I reset the math grid individually, it seems to work as it should. Is there a command that I could insert into the script that resets the math windows I am using individually so that the MIN value is displayed correctly and therefor the PP value is actually meaningful?
The same is true for the min/max graph, which also starts at 0 after starting the grid or a global grid reset.
Buying 6-1/2 digit bench multimeters just to check if a regular nine-volt battery is still alive.
    • Tests
« Reply #7428 on: September 06, 2026, 09:10:04 am »
I am not sure what you are talking about.
I tried the Advanced readout, min/max chart and the Math page min/max functions, they all initialize correctly.
As testing source I uses a virtual generator and simply defined the output to be either positive for both limits or negative for both limits and no errors was seen.
Offline Salient666
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #7429 on: September 06, 2026, 09:19:56 am »
See images, I hope this makes it clearer.
    • Tests
« Reply #7430 on: September 06, 2026, 09:31:47 am »
I just checked the code, it is correct. The only way a zero shows up, is if a zero is read.
Offline Salient666
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #7431 on: September 06, 2026, 09:49:29 am »
For some reason a global reset makes it so that a 0 is read from all devices in that case.
Is there a line I can add in the script to reset individual readouts?
    • Tests
« Reply #7432 on: September 06, 2026, 10:35:47 am »
No, there is no individual script control of the grid panels.
Both individual reset and global reset works exactly the same for individual panels (They call a reset function).
Offline Salient666
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #7433 on: September 06, 2026, 10:42:25 am »
For some reason, at least on my computer, it seems like it doesn't work the same because it has different outcomes. For now I will just quickly reset the math panels since it's only 3 of them.
Online KungFuJosh
  • TEAS is real.
« Reply #7434 on: September 06, 2026, 03:14:41 pm »
StdDevRunning defaults to zero on reset. I assume this is because there is not enough data. However, I agree this is not accurate. The math channel is reading a DMM channel with ~10VDC on it, and at no point is the value zero.
Is it possible to have the math channel reset the minimum value only after the 1st Sample set requirement is met?
For example, Reset full grid panel, then (in our case) 180 Samples pass, and the Min value is set based on the first cycle's values.
For the PP value to be accurate, it has to reflect the data from Sample sets, not the empty reset value.
Thanks,
Josh
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
    • Tests
« Reply #7435 on: September 06, 2026, 03:18:48 pm »
Max and min are initialized to the maximum double value, negative for max and positive for min, any other value is a measurement.
Online KungFuJosh
  • TEAS is real.
« Reply #7436 on: September 06, 2026, 03:28:15 pm »
That doesn't make sense on math channel. Min and Max should reflect the measured values on a Math channel. Zero is not accurate in this case.
    • Tests
« Reply #7437 on: September 06, 2026, 03:31:14 pm »
It does, because first value will initialize both of them to that value. That is standard programming praxis to do it that way.
Online KungFuJosh
  • TEAS is real.
« Reply #7438 on: September 06, 2026, 03:41:12 pm »
Then I guess we need to ignore min/max/PP for Math channels? Except for one thing: it's not consistent behavior.
If we reset the whole grid panel, Min is 0.
If we right-click the math box and hit Reset, then it shows everything correctly. I assume this happens because the math channel already has data at that point.
Thanks,
Josh
    • Tests
« Reply #7439 on: September 06, 2026, 03:50:06 pm »
Difference between resetting a single panel and a full grid panel reset is that the full reset will also reset the local Math. channels (Each window gets its own local Math. channels).
Grid panel has one instance of Math. channels, each single panel gets its own instance.
« Last Edit: September 06, 2026, 03:52:38 pm by HKJ »
Online KungFuJosh
  • TEAS is real.
« Reply #7440 on: September 06, 2026, 04:23:57 pm »
That's what I figured.
Is there a way to add a 3rd option, where the full grid panel reset let's the math run a full cycle first? Then everything could be displayed accurately.
    • Tests
« Reply #7441 on: September 06, 2026, 04:58:39 pm »
Maybe a right-click option on the reset button to reset them individually.
Online Cyclotron
  • *POOF*
« Reply #7442 on: September 06, 2026, 05:07:49 pm »
Usability suggestion. Maybe I'm the only one but it took me a while (long time ago) to figure out you can right click on the instrument name in the main window to select the instrument to give commands to or make settings on.  It's not obvious to me that the label of the instrument beside the command box is right clickable.
Maybe this would be better as a pull down or a button?
    • Tests
« Reply #7443 on: September 06, 2026, 05:14:22 pm »
Right-clicking the label is one way and it is in the documentation.
Right-clicking on the command line is another way.
Adding a tool tip to it would probably be a good idea.
« Last Edit: September 06, 2026, 05:16:58 pm by HKJ »
Online KungFuJosh
  • TEAS is real.
« Reply #7444 on: September 06, 2026, 05:16:39 pm »
Or is there a way to reset the math displays without resetting the math itself (like leaving a buffer)?
Reset Visual vs. Reset All
Reset Visual only empties the values in the display panels (but keeps the running math), and Reset All functions like the current option for resetting the grid panel where everything is cleared.
    • Tests
« Reply #7445 on: September 06, 2026, 05:18:20 pm »
That would be possible with my suggestion.
Online KungFuJosh
  • TEAS is real.
« Reply #7446 on: September 06, 2026, 05:29:56 pm »
Oh, so you mean right-click reset and that will reset all individually?
That's cool. Can it do them individually all at once so the sample count is still in sync?
The following users thanked this post: Salient666
    • Tests
« Reply #7447 on: September 06, 2026, 05:36:23 pm »
Yes.
Right-click on the reset button and select between "Reset all panels" and "Reset Math channels", if you left-click the reset button it will work as it has always done.
The following users thanked this post: KungFuJosh, Salient666
Online KungFuJosh
  • TEAS is real.
« Reply #7448 on: September 06, 2026, 06:23:24 pm »
Sounds good to me.
Thanks,
Josh
Offline gby
« Reply #7449 on: September 07, 2026, 06:51:01 pm »
I recently needed an ac powered meter to do some logging with and thought the Owon XDM1041 would be the cheapest option.  However, on Amazon I saw the same meter with the generic Digcreat name on it for $20 cheaper.  As it turns out it is just a rebrand and otherwise identical to the Owon original.
I edited the existing OwonXDM1041.txt device file with #metadef to add this rebrand since it returns Digcreat,XDM1041 instead of Owon,XDB1041 in response to *IDN?  Attached is the updated device file for others that might run across this rebranded version.
