Author Topic: Program that can log/control many multimeters and other devices.  (Read 1771245 times)
flash2b and 225 Guests are viewing this topic.
Offline kw1
Re: Program that can log/control many multimeters and other devices.
« Reply #7575 on: September 25, 2026, 03:56:25 pm »
Hi Eric, I tried the following again:
I create a definition file with the following values, and startet with com5 port (Tinygtc source 10Mhz):
;; COM5: Rx: <10000000.0000279750675 CHA> 31 30 30 30 30 30 30 30 2E 30 30 30 30 32 37 39 37 35 30 36 37 35 20 43 48 41
Two details:
1) Why are you polling all com ports (Remove checkmark for "Scan serial ports".
2) Is the device in some sort of streaming mode? The answer is a frequency, not the id string.
TC can work with a streaming mode, but it is very different from SCPI and do not allow control of the device.
to 1. Yeah, I forgot to turn off the scan.
to 2. i think it is streaming mode. When Teleterm starts up, measurement values with the port designation (A/B) come in immediately every second.
Data example arriving on COM 5: (Teleterm)
10000000.0000176299363 CHA
 9999999.9999688621610 CHA
 9999999.9999860227108 CHA
 9999999.9999669436365 CHA
10000000.0000091716647 CHA
Tinygtc has 3 COM ports:
https://www.tinydevices.org/wiki/pmwiki.php?n=TinyGTC.Remote
I think i am using the logging port.
Tinygtc can also SCPI:  https://www.tinydevices.org/wiki/pmwiki.php?n=TinyGTC.SCPI
Can you help me adjust the driver so that I can log the frequency readings?
klaus
Offline HKJTopic starter
    • Tests
« Reply #7576 on: September 25, 2026, 04:07:54 pm »
Try single value driver: https://lygte-info.dk/project/TestControllerConfigDevice2%20UK.html#Single_value
Example:
#idString HKJ,HKJ Test
#name HKJ Test
#handle Test
#port comfixedbaud
#baudrate 1200
#driver SingleValue
#value Frequency Hz SI
You will, of course, have to adjust the example and please add "streaming" or something like that to the name
The following users thanked this post: kw1
Offline kw1
« Reply #7577 on: September 25, 2026, 05:09:31 pm »
Example:
#name HKJ Test
#handle Test
#port comfixedbaud
#baudrate 1200
#driver SingleValue
Hi Hendric, thank you so much for your support!
...great, it works nearly perfectly!
I'm still having problems with displaying the 9 decimal places in the graph...  ::)
klaus
    • Tests
« Reply #7578 on: September 25, 2026, 05:18:49 pm »
You use the "Scales for charts" to adjust the scales on the chart including decimal digits.
Offline KungFuJosh
  • TEAS is real.
« Reply #7579 on: September 25, 2026, 05:33:01 pm »
Does it work for you? It doesn't reset the same as individual panels for me. I can send you a video if you want.
I added notifications to the reset functions and it happens exactly as I specified, there are no extra stuff done.
I see what's going on now. The buttons are not as I expected (but I actually like them this way).
If I click the Reset button normal, all gets reset and Math Min is 0.
If I right-click Reset and hit Reset all panels, all gets reset and math resets without going to zero (this is my preferred option).
If I right-click Reset and hit Reset math channels, then only the math channels reset and Math Min is 0.
I like the behavior of Reset all panels, so I'll just hit that. ;)
Thanks,
Josh
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
    • Tests
« Reply #7580 on: September 25, 2026, 05:53:34 pm »
Math do not get reset in this case, only the panels. Any Math channel that has a buffer or running value will retain it.
Math channels where you specify a sample count has a buffer.
Math channels that calculates totals, do not have a buffer, but calculate running total.
« Last Edit: September 25, 2026, 05:58:21 pm by HKJ »
Offline KungFuJosh
  • TEAS is real.
« Reply #7581 on: September 25, 2026, 06:06:14 pm »
Yes, this is exactly what I wanted.
Thanks,
Josh
    • Tests
« Reply #7582 on: September 25, 2026, 07:18:56 pm »
SingleValue is the simplest driver in TC, there are also other drivers that support streaming and can do more advanced stuff.
For this device a SCPI driver would be the best, but it requires some work.
I do still believe the streaming driver is useful and you are welcome to submit it for inclusion in TC.
Offline kw1
« Reply #7583 on: September 26, 2026, 08:12:50 am »
Hi Hendric, if you'd like, feel free to add this driver to TC.
Maybe someone else will come along who's willing to create a more complex driver for this great device.
    • Tests
« Reply #7584 on: September 26, 2026, 09:46:46 am »
I have added it, it is a simple driver, but better than no driver.
I hope somebody will make a full SCPI driver, that was the reason I asked you to call it something with stream.
Offline kw1
« Reply #7585 on: September 26, 2026, 12:34:29 pm »
Hi Hendric,
Do you know who wrote the Tinysa drive for testcontroller?
#author PL
Since the author is familiar with Zeenko devices, it would certainly be easier to adapt it for tinygtc.
klaus
    • Tests
« Reply #7586 on: September 26, 2026, 12:41:31 pm »
Hi Hendric,
#author PL
I received the definition on email a few months ago, but I do not know the person who wrote it.
Online flash2b
  • Everything I like about myself is better with you.
« Reply #7587 on: September 28, 2026, 01:58:39 pm »
In sequence in def:
#cmdSetup info Store_Time Store_Recall
:read: iccStoreEstimation?
#cmdSetup info IC_Card System
:read: iccPresent?
:update: Store_Time
The :update: does not update the Store_Time
Why? and how to fix...
They say attention is a shovel. It's time to dig 'em out.
Offline KungFuJosh
  • TEAS is real.
« Reply #7588 on: September 28, 2026, 02:07:09 pm »
Aren't updates performed as part of an action (pressing a button)? How would an info update another info with no action involved?
    • Tests
« Reply #7589 on: September 28, 2026, 02:08:14 pm »
In sequence in def:
:read: iccPresent?
:update: Store_Time
:update: triggers on writes, not reads. Generally a read is not a reason for update other controls.
I do not remember if I support info for updates.
Online flash2b
« Reply #7590 on: September 28, 2026, 03:06:19 pm »
#cmdSetup info Syntax_Check Program
:read: syntaxError?
#cmdSetup text Line_1 Program
:read: progLine1?
:write: progLine1
:update: Syntax_Check
This works ok.
So I will be never be able to trigger an :update: from a #cmdSetup info.  :'(
And it just ignores it silently...
Offline 7tronics
« Reply #7591 on: September 28, 2026, 07:40:03 pm »
Fantastic tool, working to get this as a standard for our college labs instead of LabView with just a tad of bloatware.
The Owon SPM6103 is supported and in the "Owon SPMXXXX.txt" file, so created another metadef for the Owon SPM8205 we acquired since some of our battery packs require >60V for testing with the Owon OEL1515 series of programmable loads.
I created this added definition for the "Owon SPMXXXX.txt" file:
#metadef
#idString OWON,SPM8205,
#name Owon SPM8205
#handle SPM8205
#replaceText MaxVoltageSet 81
#replaceText MaxVoltageLimit 82
#replaceText MaxCurrentSet 20.1
#replaceText MaxCurrentLimit 20.2
but when I connect with TestController, the only response to #VALUES? is the DC voltmeter:
;; Found Owon SPM8205 on USB Serial (COM3) sn: 26170021
*IDN?
;; OWON,SPM8205,26170021,FV:V1.0.0
#VALUES?
;; SPM8205.VoltageDC=0 V
The popup for Setup does allow changing values on the front panel and turning the PS on and off and setting every parameter that I tried correctly.
The DC Multimeter app from Owon also works and track, plot, and save device-under-test voltage, current, and Ah capacity.
What am I missing to get the current, voltage, and Ah information for charting lab tests?
Multiple East Tester ET5410A+ programmable loads work fine in this setup of a charging function with battery discharge testing using TestController. It would be great to get the programmable power supply voltage and current data acquisition accessible from TestController as well.
[Later same day...]2938179-0
To add to the confusion, the MEAS command does return data, but TC is not seeing it. Any suggestions on where to start with making changes to
"Owon SPMxxxx.txt" markup file? See the attached screenshot.
Thanks, Mark
« Last Edit: September 28, 2026, 08:49:03 pm by 7tronics »
Offline pivous
  • Country: cz
Overlaying multiple script runs (different input voltages) in one chart
« Reply #7592 on: September 28, 2026, 10:33:43 pm »
I'm measuring a DC/DC converter's characteristic across several different input voltages, and I'd like to compare the resulting curves in a single chart — ideally with each run starting from a common t=0 rather than its real, absolute timestamp.
As I understand it, #LOG records on the real/absolute time axis, so running the same test script repeatedly (once per input voltage) makes each run's data simply continue after the previous one in time, rather than each starting fresh at t=0 for overlay.
Is there a supported way to log/plot each run relative to its own start time, or otherwise combine several separate runs into one chart for this kind of comparison — without exporting the data and aligning/overlaying it in an external tool?
If there's an existing example or chart feature for this, a pointer would be appreciated.
Offline KungFuJosh
  • TEAS is real.
« Reply #7593 on: September 28, 2026, 11:24:46 pm »
Try out the Param sweeper. It should do exactly what you want. I've used it to compare the same test across 6 devices.
    • Tests
« Reply #7594 on: September 29, 2026, 07:45:00 am »
Correct.
    • Tests
« Reply #7595 on: September 29, 2026, 07:51:03 am »
A nice detail with using a free tool is that students can put it on their own computers and take it home.
#metadef
#name Owon SPM8205
#handle SPM8205
*IDN?
#VALUES?
TC uses the #askValues line to read data
In this case it uses "CONFigure?" to read the data, maybe there is a need to define what the command returns.
This can be done on the #prepareSample line.
The following users thanked this post: 7tronics
    • Tests
Re: Overlaying multiple script runs (different input voltages) in one chart
« Reply #7596 on: September 29, 2026, 07:56:21 am »
Two things:
1) You can use the import function to overlay curves, you simply specify what column to synchronize/align and TC will do it, even if the sample rates do not match.
There is an example here: https://lygte-info.dk/project/TestControllerPopupBatteryTestExample%20UK.html#Summary where it overlays a couple of different tests on 3 different parameters, in 3 different charts.
2) TC has a special test function for DC/DC converters where it will run a bunch of test automatic. It is called power supply test, because it can be used for both DC and AC sourced converters. It do require the equipment used are fully defined.
https://lygte-info.dk/project/TestControllerPopupPSTest%20UK.html
« Last Edit: September 29, 2026, 08:03:25 am by HKJ »
Online flash2b
« Reply #7597 on: September 29, 2026, 09:20:42 am »
What is the difference between printLog() and print() ?
Offline pivous
  • Country: cz
New definition file for Power supply Gossen Metrawatt Konstanter SSP 320
« Reply #7598 on: September 29, 2026, 09:31:27 am »
Fully functional definition file for this PS except sequention featature, which is fully covered by Testcontroller. May be in the future :-)
    • Tests
« Reply #7599 on: September 29, 2026, 09:54:32 am »
Print() outputs to the internal return buffer, printLog() outputs to the log window.
Commands run on the command line or in the log window will output the internal return buffer to the log window when finished.
