Author Topic: Replacement Knobs, Feet and Fittings for Test Equipment  (Read 681460 times)
0 Members and 18 Guests are viewing this topic.
Offline BlownUpCapacitor
  • I kinda suck at the art of electronics tbh
Re: Replacement Knobs, Feet and Fittings for Test Equipment
« Reply #275 on: November 10, 2023, 08:05:03 pm »
Tektronix 22xx series Power cable wrapping holder... thingy... I don't know what they are called. Used them on my Tek 2230 and they work well. The design could maybe be improved a little bit, but not by much I think.
Tinkercad link here: https://www.tinkercad.com/things/amQ4XpQkk1r-tek-power-cable-standoff
Update: The design has been enhanced. It is more structurally sound and stronger. The screw holes have also been enlarged for an easier fit.
Download the enhanced version instead. It is in a txt format, but all you have to do is change it back to an STL and it'll work fine.
Oct 19, 2024: Newer updates made. Added fillets and made it over-all much more similar to the original. File uploaded as a txt file. Rename it to a step file and all should work fine. This was made in onshape for those of you who want to know. https://cad.onshape.com/documents/d1d59af15a5a6fd574629103/w/f595091c78b25b4bdda1f7a3/e/3fef025c5d04cdd547a2d425?renderMode=0&uiState=67145f2752a9b256796219a9
« Last Edit: October 20, 2024, 01:39:17 am by BlownUpCapacitor »
Hehe, spooked my friends with an exploding electrolytic capacitor the other day 😁.
The following users thanked this post: salvagedcircuitry, TERRA Operative, AVGresponding
Offline RikV
« Reply #276 on: November 17, 2023, 01:19:49 pm »
On my HP5335A the stem of the power button was broken off. I will surely find a suitable power switch in my spares bin but the button cap is an other history. Anyone knows of a 3D printable version? HP part# is 5040-0201, it is square, about 9mm.
Offline Kosmic
« Reply #277 on: November 17, 2023, 07:36:11 pm »
I reproduced the feet of my Solartron 7081. Should technically also fit the 7071 7061 and others.
« Last Edit: March 06, 2024, 04:07:22 am by Kosmic »
The following users thanked this post: Resonant, AVGresponding, the Chris
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #278 on: November 18, 2023, 01:22:31 am »
I'm in the same situation.
I replaced the switch too and need a new button.
I have another 5335A on the bench, so maybe I'll pull the button off that and draw up a 3D file soon.
Stay tuned....
Offline DavidKo
  • Country: cz
« Reply #279 on: November 20, 2023, 08:02:46 am »
I have created for my Yokogawa WT130 rear and bottom foot. It will probably WTxxx power meter series and devices in same box.
Rear foot
Bottom foot
  • Country: jp
« Reply #280 on: December 03, 2023, 05:11:35 pm »
I just drew up the rear foot/handle for my HP/Agilent 8648C, part number 08647-40003, and stuck it up on thingiverse too.
I guess it'll fit some other instruments too.
https://www.thingiverse.com/thing:6343540
The following users thanked this post: salvagedcircuitry, AVGresponding, RikV
  • Country: jp
« Reply #281 on: December 04, 2023, 04:21:19 pm »
And a power button for the HP 5335A Universal Counter.
I haven't checked fitment so some experimentation will be needed with the hole that fits over the plunger in the button, let me know how it goes. :)
https://www.thingiverse.com/thing:6352529
The following users thanked this post: ch_scr, AVGresponding, RikV
Offline ch_scr
« Reply #282 on: January 11, 2024, 09:21:27 am »
After getting my hands on two IET Dekapot's, I've had to make new spacer disks to get the "index support" into proper position.
The attached models are about the thickness of 2 or 3 of the spacer disks combined.
If you have no spacers disks and want to use it stand-alone (no additional front panel thickness) the 6mm one should be just right.
I've used the 4.2mm one with one spacer disk to the same effect.
Your slicer should be able to scale each model in just the Z direction to an individual thickness.
The following users thanked this post: HighVoltage, AVGresponding
Offline Kosmic
« Reply #283 on: March 05, 2024, 11:44:32 pm »
Prema 5017 foot.
Use M3x6 screw.
« Last Edit: March 05, 2024, 11:50:01 pm by Kosmic »
The following users thanked this post: xrunner, AVGresponding, bastl_r
Offline scopeman
« Reply #284 on: March 10, 2024, 03:00:19 am »
Looking at the bad photo I am actually wondering if they were made from the same soft plastic on the 5300's I made new feet for rather than a rubber. What was left of mine basically crumbled into pieces and the rear shot of Daves looks like that same sort of issue?
Edit Adding the 35mm Foot here due to the 1Mb file size limit   |O I will add it to the link index on the front page and leave both available.
Modded Fusion file and both STL'in the Zip for 6mm Long Screw and the Genuine HP screw options.
Hello Bean,
Any chance you could export the file in STEP also? I want to play with it in Alibre but it will not import Fusion360 files directly.
Thanks,
Sam
W3OHM
W3OHM
Offline Kosmic
« Reply #285 on: March 12, 2024, 12:17:58 am »
TPI 440 Tilt Stand.
Printed at 0.2mm, 25% infill with PETG
« Last Edit: March 12, 2024, 01:49:12 am by Kosmic »
The following users thanked this post: xrunner, ch_scr, AVGresponding
Offline Finnaaah
« Reply #286 on: March 26, 2024, 12:32:34 pm »
Knobs for the Array 3720A or any e-loads with the same posts.
  • Country: jp
« Reply #287 on: March 26, 2024, 04:40:34 pm »
Whaaat whaaat.
A complete reproduction front panel for a HP 8648 series function generator?
Ok, here it is. :)
https://www.thingiverse.com/thing:6518453
« Last Edit: March 26, 2024, 04:43:32 pm by TERRA Operative »
The following users thanked this post: Kean, AVGresponding
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #288 on: May 14, 2024, 08:36:30 am »
Replacement BNC Lever for HP/Agilent/Keysight fixtures, will likely fit other brands of fixtures also, this one was specifically to repair a 16143B fixture for a 4338B milliohm meter.
2202409-0
2202397-1
https://www.thingiverse.com/thing:6621348
« Last Edit: May 14, 2024, 08:40:29 am by TheDefpom »
Cheers Scott
The following users thanked this post: xrunner, TERRA Operative, AVGresponding
Offline TheDefpom
« Reply #289 on: May 14, 2024, 11:18:23 am »
Replacement BNC Insulators / spacers from test fixtures such as the 16143B and others used by HP/Agilent/Keysight, this one was specifically to repair a 16143B fixture for a 4338B milliohm meter.
2203318-0
https://www.thingiverse.com/thing:6621477
Cheers Scott
Offline pac1085
« Reply #290 on: June 02, 2024, 12:55:36 am »
I made a replacement plastic piece for the Tektronix 576/577 curve tracer standard test fixture.
2275561-0
https://www.printables.com/model/899528-tektronix-576-standard-test-fixture-plate/files
It does not have the provisions for the HV interlock cover but they shouldn't be too hard to add if you want (the scad file is on the site)
If you downloaded it before 6pm EST on 6/2/24, go back and get the V4 file, it has a bunch of issues fixed.
I also made a replacement plastic ring for the offset mult pot:
https://www.printables.com/model/907974-tektronix-576-offset-multiplier-mounting-ring
« Last Edit: June 10, 2024, 01:32:51 am by pac1085 »
The following users thanked this post: xrunner, ch_scr, TERRA Operative, AVGresponding
« Reply #291 on: August 14, 2024, 01:10:24 am »
Handle hinge cap for Tektronix 300 series instruments. It won't fit the non-solid-state instruments though.
* 300 series hinge cap.zip (17.54 kB - downloaded 95 times.)
« Last Edit: September 29, 2024, 06:53:56 pm by BlownUpCapacitor »
The following users thanked this post: abeyer, AVGresponding
« Reply #292 on: August 17, 2024, 03:15:57 am »
Another Tek part:
It is the mating adapter/fixture for the Tektronix 7000 series plug-ins. It does not have the sides trimmed, nor the PCB mater and the weird 4-hole thing on the top of the plug-in; does anyone know what that's for?
It seemed to work well when I tested it.
Edit: Here's the tinkercad link if you want to make a copy and edit it https://www.tinkercad.com/things/bED8Zr7AeYU-frantic-tekwork?sharecode=IwA8WfK7XQOEQItICEfu-1z1qo_RXW72k1FFY1q844E
Update: Please see https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/msg5740165/#msg5740165 for a better design and with the rest of the 7000 plug-in chassis.
« Last Edit: December 19, 2024, 08:54:16 am by BlownUpCapacitor »
Offline jal1234
« Reply #293 on: September 05, 2024, 12:30:48 pm »
Providing a link to a post in another thread for the THS710, 720, 730, 720a, 730a, 720P battery compartment cap. Not done by me. Post #411.
https://www.eevblog.com/forum/testgear/tek-ths720a-portable-scope-teardowndiscussion/400/
Jon
Offline sneily
« Reply #294 on: September 10, 2024, 09:40:13 pm »
Looking for a set of feet of the HP 3455A Voltmeter.
So far my search is unsuccessful.
Cheers!
  • Country: jp
« Reply #295 on: September 11, 2024, 01:05:52 am »
Cheers!
It looks like you can use the standard HP clip-in feet like part number 5041-8801 etc.
There may be a few part numbers for this style foot, they all should 'just fit'.
Offline sneily
« Reply #296 on: September 11, 2024, 03:35:34 am »
Indeed,,thanks.
I found other comments on this forum indicating there are numerous different part numbers for feet that will fit. This expands my search net considerably and I am now seeing some options available.
Cheers!
Offline DavidKo
  • Country: cz
« Reply #297 on: September 11, 2024, 03:57:58 am »
It make sense. The older feet were darker "brown" with rubber on rear feet. Then the same feet was used for the front and back (without rubber). Last iteration is grey. But the mounting pattern is the same across HP equipment including computers.
Offline sneily
« Reply #298 on: September 13, 2024, 06:38:49 pm »
I found a set of 4 on ebay of the proper color for my unit (brown or green). And this set includes two of the wire tilt-stands. So happy ending for me.
By the way, for anyone interested, Keysight still manufactures these feet and tilt-stands and you can order new, directly from Keysight. Though I think they only supply gray ones (a dark gray and a light gray).
Cheers
Offline ch_scr
« Reply #299 on: September 16, 2024, 08:04:45 am »
I've recently got a beat-up Yokogawa 7651 from Japan, hence the need for replacement rear bumper and rear feet.
Since the forum doesn't like step files, I've put them in a zip. Please find them attached  ^-^
The following users thanked this post: DavidKo, AVGresponding, sneily
