Author Topic: Replacement Knobs, Feet and Fittings for Test Equipment  (Read 681846 times)
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Replacement Knobs, Feet and Fittings for Test Equipment
« Reply #325 on: July 26, 2025, 02:07:24 pm »
You don't have to find the exact color filament - you can paint the part to suit your needs. There are many colors of high quality model paint that will work very well.
I attached a button I designed for a Boonton power meter. You can see the part as it comes off the build plate (except I already added a white dot on that one). Then the original knob and the finished 3D printed and painted part side-by-side. I primed and painted this part in gloss black, but you can choose the color paint you want.
I put this part on the instrument and I would challenge anyone to tell if any of the buttons were not original.
Offline TheSteve
  • Living the Dream
« Reply #326 on: July 26, 2025, 08:04:25 pm »
The Bambu grey is a good color and will certainly work with a bunch of equipment. Painting is always an option but I'd rather avoid it if possible. I printed a new knob for an 83732A in grey and white and both look out of place. I have a white knob sitting in some tea to dye it a darker color. I see I can buy a "bone white" PLA, that might be a good option for older equipment.
VE7FM
Offline TheSteve
  • Living the Dream
« Reply #327 on: July 28, 2025, 01:58:48 am »
I'm pretty pleased with the "bone white" PLA, it has that aged yellow look.
I reworked a knob designed by DaJMasta to fit the 8373x series siggens.
VE7FM
The following users thanked this post: ZigmundRat, AVGresponding
Offline lowimpedance
  • Watts in an ohm?!
« Reply #328 on: July 31, 2025, 03:10:27 am »
 After some searching found nothing for the TDS3000 series interface module cover, I came up with a very basic 'plug cover' to ..... well cover the empty slot on my 3000.
It snaps in quite nicely using the centre catch for retention. For removal press down on the catch and use a small screwdriver etc to pick it out from the end !
« Last Edit: July 31, 2025, 03:15:31 am by lowimpedance »
The following users thanked this post: ZigmundRat, AVGresponding, TinLethax
Offline the Chris
« Reply #329 on: August 16, 2025, 10:40:22 am »
https://www.thingiverse.com/thing:6159453
There is my drawing for  HPAGKS 34970A rear bezel
Thanks for creating this. However, I also have one of the 34970A that needed a modified version of this to keep the metal braket in place. In addition, the metal cage holding the card inserts is a bit recessed and the opening for the screw in the model needs to end deeper for the screw to stick out sufficiently long enough to reach the metal cage.
I reprinted a modified version of your STL and this fits fine. Are you interested to receive the modified version to copy thr changes over to your original model to create an alternative version for those who have the metal braket in place?
Christian
Offline CatalinaWOW
« Reply #330 on: August 21, 2025, 11:17:20 pm »
Here is a parameterized model for knobs on a Iwatsu DS-8812 oscilloscope based on measurements by user Artag (See thread "Need a knob" in repair.
The posted model generates the following knob.
But by adjusting parameters a wide variety of useful knobs can be created.  Two examples are shown.  One has just 1 rib and is suitable as an indicator.  The other has two extended size ribs and is appropriate for a hard to turn multi-position switch.
The shaft attachment can be resized for various D type shafts or adapted to a friction fit on a round shaft.
The model is in FreeCAD (Version 1.0.1) format.  Number of ribs can be set from 1 to 12.  The only things that can't be changed in the Params spreadsheet are the flllets on various edges.  Changing these requires diving into the model.
Have fun.
« Last Edit: November 04, 2025, 03:29:25 am by CatalinaWOW »
The following users thanked this post: ZigmundRat, AVGresponding, Shimonu
Offline TinLethax
  • Country: th
    • TinLethax's messy blog
« Reply #331 on: November 22, 2025, 08:49:14 am »
Jog-shuttle knob for the Yokogawa oscilloscope. The DL1740E that I just repaired didn't come with the knob so I just CAD one.
Since I don't own a single 3D printer, I just used the China printing service. It was printed with resin SLS. Might also work with DL1600, DL750 and DL7100/DL7200.
« Last Edit: December 01, 2025, 12:37:43 am by TinLethax »
TinLethax! Yokogawa DL1740E(L), Tek A̶F̶G̶3̶1̶0̶2̶C̶ AFG3152C, Agilent U1253B
https://tinlethax.wordpress.com
Offline rms
« Reply #332 on: November 30, 2025, 03:01:59 pm »
HP 34401A front/rear terminals push rod:
https://makerworld.com/en/models/2059927-hp-34401a-front-rear-terminals-push-rod#profileId-2224037
Looks almost the same as the original one.
The following users thanked this post: ZigmundRat, TERRA Operative, AVGresponding
Offline zike
« Reply #333 on: November 30, 2025, 03:57:08 pm »
Has anyone sourced or replicated replacements for HP p/n 370-0102 ?  I need 3.
This is a 1/2" OD barred pointer knob for 1/8" shaft (the -0102 is red but there's also a black variant, don't know the number).  Used on rotary range switches on HP 6205B power supplies and 5321A/B frequency counters.
QService has a picture (but alas, no stock...)
2707871-02707875-1
Offline Supersonic_Pigeon
« Reply #334 on: December 08, 2025, 08:31:42 pm »
Hello!
I have recently acquired my first oscilloscope; a Tek TDS3032B. The mounting brackets for the feet were both brittle and cracking, resulting in the 'scope being unstable when on its feet. Surely the feet would have eventually separated as well.
I designed a 3d-printable replacement, consisting of the foot itself and the troublesome bracket it mounts inside. Below is a link to my Printables page for it, which I might update over time if I decide that something is annoying me about my design. Or if you want me to, I can post the STLs here.
https://www.printables.com/model/1507816-tektronix-oscilloscope-feet-tds-3000
As far as I'm aware it should work for the TDS 3000, 3000B and 3000C series 'scopes, because they all appear to use the same housing. Please correct me if I'm wrong.
EDIT: I have now added an optional rubber pad to make the oscilloscope sit on a desk better with the feet folded, and reduce sliding around. I've also modified some dimensions for a better fit.
2713967-0
« Last Edit: January 11, 2026, 09:08:54 pm by Supersonic_Pigeon »
The following users thanked this post: lowimpedance, ZigmundRat, TERRA Operative, AVGresponding, TinLethax, Shimonu
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #335 on: December 30, 2025, 08:37:43 am »
I finally got too worried about dropping my Fluke 5450A when moving it around as the original handles were full of cracks and had been glued together more than once...
So I have made replacement handles (and rear feet I suppose, as they are the same part).
If you know of other Fluke equipment that uses the same chassis and handles please let me know so I can add it to the thingiverse page.
https://www.thingiverse.com/thing:7254879
« Last Edit: December 30, 2025, 08:39:20 am by TheDefpom »
Cheers Scott
The following users thanked this post: xrunner, ZigmundRat, AVGresponding
Offline ZigmundRat
« Reply #336 on: December 31, 2025, 03:29:02 am »
Nice. Thanks for sharing this, and the photos!
Offline TheDefpom
« Reply #337 on: January 04, 2026, 05:09:06 am »
Replacement lever switch caps for the 9918 and 9921 Racal Dana frequency counters (and possibly others).
https://www.thingiverse.com/thing:7260655
Cheers Scott
The following users thanked this post: xrunner, ZigmundRat, AVGresponding, Oilngas
« Reply #338 on: January 19, 2026, 05:37:02 pm »
Collating this Fluke 884xA fuseholder here, designed by forum member jacekowski: https://www.eevblog.com/forum/testgear/fluke-8840a-fuse-holder-516039/msg6164727/#msg6164727
Offline pac1085
« Reply #339 on: January 28, 2026, 01:51:43 pm »
Wavetek/Datron 1271 Multimeter
I 3d printed these thin panels to reinforce the front and rear plastics around the binding posts, as mine was cracked in several places.  I was able to glue the cracks with CA glue but figured a few more layers, glued on with CA glue would help shore things up and hopefully prevent future cracking.
https://www.printables.com/model/1574791-wavetek-1271-binding-post-reinforcement-panels
Offline powerflux
« Reply #340 on: February 06, 2026, 10:52:57 am »
I got bored last night so I came up with my own version of the rear stand-offs for HP gear.
Someone might find it useful maybe..
https://www.thingiverse.com/thing:3606417
BTW, does anyone know what the thread size is for the screws for these things? I'm having trouble matching it up to anything..
I've printed a few of these and they are a perfect fit. Excellent work!
However, would you be willing to share the original files (hopefully SolidWorks) because I want to make a special version for the HP 3585A/B where the feet needs at least 5.5cm of height to clear the nuts for the fan filter..
It appears HP never made feet that tall.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #341 on: February 06, 2026, 11:38:50 am »
The original files are in that link.
3DM for Rhinoceros 3D, and STEP for cross compatibility to other software.
I have no other files, and Rhino3D is not a parametric modelling software.
Offline powerflux
« Reply #342 on: February 06, 2026, 12:44:20 pm »
Thanks! I've seen there's a 'Try' button on the Rhinoceros 3D website so that makes a nice side adventure :)
Offline powerflux
« Reply #343 on: February 07, 2026, 07:43:42 am »
In the end I hacked it together by merging the bottom part of the HP Rear Stand-Off Feet 5041-8821 5040-7221 step file by TERRA Operative with a new, taller, top section.
Now the HP 3585A (or 3585B) can also be stored vertically :)
« Last Edit: February 07, 2026, 07:51:52 am by powerflux »
The following users thanked this post: TERRA Operative, AVGresponding
Offline android927
« Reply #344 on: February 10, 2026, 03:16:01 pm »
I found these knobs on Amazon that fit perfectly on my LeCroy WaveSurfer 434. Importantly, they don't interfere with the ability to press the encoder knobs and actuate the click buttons underneath.
(Image shows new knob on Analog Persist encoder. All other knobs are original.)
« Last Edit: February 11, 2026, 04:33:54 am by android927 »
The following users thanked this post: TinLethax
Offline scopeman
« Reply #345 on: February 11, 2026, 02:29:54 am »
I wish they would put 14 or 16mm diameter version of those knobs on Amazon,
Sam
W3OHM
W3OHM
Offline 44kgk1lkf6u
« Reply #346 on: February 15, 2026, 09:19:15 pm »
Another adapter for the Lecroy ProLink.  It uses a single 2466280-1 adapter.  I used an SLA 3D printer.  The part was oriented so that none of the faces were horizontal.  The pattern left behind by the support can be seen in the second picture.  I had to clean the hex recess carefully to make sure it ended up flat when cured.
The first one.  https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/msg2828762/#msg2828762
Offline jl02
« Reply #347 on: February 19, 2026, 04:01:30 pm »
Spent a couple hours last night modeling (cloning) replacement bumpers for Keithley graphical series (2450, 2460, 2461, 2470, 2280S, 2281S, DMM6500, DMM7510, DAQ6510) and figured people would want these. I know I would have spent a little too much on Keithley units from ebay if I could have printed bumpers for them  ;D
Files are up on thingiverse:
https://www.thingiverse.com/thing:7298320
The following users thanked this post: AVGresponding, Peter_O
Offline scopeman
TDS3000 Series Interface Module Bracket
« Reply #348 on: February 28, 2026, 05:06:49 pm »
Hello,
I have worked up a PCB design for the Tek TDS3000 series RS-232 interface based on the one by "Dooser". However I do not have access to a real Tek interface module in order to
obtain the real dimensions for the tray that the PCB fits into. Does anyone have one of these so that I can create a dimensionally correct 3D model for one? If so, I would be more than happy to
gen this up in Alibre Design and post a 3D step model of it.
Thank you very much,
Sam
W3OHM
Offline MarkF
« Reply #349 on: March 01, 2026, 01:21:07 am »
I wanted to share cases I've made for the Arduino Uno R3 and the Raspberry PI B3+
FreeCAD files available upon request
  2772929-0
  2772155-1
Update:  Uno case top fixed.
« Last Edit: March 02, 2026, 10:09:37 am by MarkF »
