Author Topic: REVIEW - Owon SDS7102 - A look at the SDS series from Owon  (Read 1792200 times)
0 Members and 62 Guests are viewing this topic.
Offline masterx81
Re: REVIEW - Owon SDS7102 - A look at the SDS series from Owon
« Reply #2750 on: April 09, 2020, 07:14:58 am »
In the past for trying to understand why all that noise i've moved this diabolic thing also outside the house, with no improvement. AFAIK nothing has changed, have the same things aroud (only added some instruments, nothing removed).
No battery attached.
The only thing is that now i leave the main switch on, and i use the top on/off button to turn it on. This result to have the green light powered on all the time.
Today i check if from really cold state has the noise, but in past i've already tried to leave it on without appreciable result.
If it remain in this way, i have no need to replace the smps for something less noisy, but i hate things that fix itselves, as have the tendency to broke itselves with same rapidity. I'll teardown it into little pieces >:D
Offline tautech
« Reply #2751 on: April 09, 2020, 07:42:30 am »
You might be very surprised where noise can come from.
My customer had a similar problem with his new SDS1104X-E and after some emails and phone calls the source was found to be a cellphone charger some meters away and behind a curtain and the mystery deepened when he did not know who it belonged to or when it got there !
Turned OFF and of course the problem was gone.  :)
Avid Rabid Hobbyist
Offline masterx81
« Reply #2752 on: April 09, 2020, 08:24:53 am »
All the chargers remained the same around the scope (and in the room). I have the scope at least from 6/7 years and was always noisy. Today i do some tests.
Maybe one of my neighbours had something transmitting at high power? Strange because the noise was at a switching frequency.
Need some test..
Offline digsys
    • DIGSYS
« Reply #2753 on: April 09, 2020, 10:00:33 am »
... well, add to the fact that many users have reported a very similar issue in that scope, as have I, your job is made more difficult. Carry on Columbo :-)
Offline jemangedeslolos
« Reply #2754 on: April 09, 2020, 11:24:55 am »
Hello,
I have a dedicated lab for my work 15km from the house.
When I received my previous oscilloscope, I was surprised by the noise.
I double checked my measurements, my probes, moved my oscilloscope.....nothing change. But at home everything was normal.
My lab is near a military zone....I don't know what they are doing there but we probably add to this a lack of shielding and we have the beginning of an explanation  ;D
Offline masterx81
« Reply #2755 on: December 12, 2020, 12:02:55 pm »
While trying to reduce a bit the noise made by the smps, i've ordered some nichicon pw series capacitors (not the lowest possible esr, but i tought that maybe were better than original)  to put in psu and adapter board. To my surprise, the chmec oem capacitors used aren't that bad. The 1000uF 16v (all tests done at 1khz with deere de 5000) are 0.039mohm while the pw are 0.061, while the 470uF 16v are 0.062 vs 0.117 of the pw. Now, worth replacing them? The original are 7y old, but very light use.
« Last Edit: December 12, 2020, 12:46:08 pm by masterx81 »
Offline MF-jockey
« Reply #2756 on: February 23, 2021, 10:21:24 pm »
The third issue is that vertical position adjustment is a bit jumpy. Basically, I'd adjust it in one direction and the line would go up and down and sometimes multiple steps for one step of encoder rotation. My gut feeling is that it's most certainly a bad encoder, but I thought I'd just mention it here for completeness's sake.
No idea about the other questions, but the  jumpiness is just crappy firmware in the scope.  All mechanical switches such as the ones in the rotary encoders are noisy and need some kind of debouncing.  The firmware in the scope does a really bad job with debouncing and the position will jump.  I have that problem with all rotary encory encoders on my scope even if some of them are worse than others.
For anyone with such problems, I was able to fix this with a couple of capacitors on the encoders:
https://www.eevblog.com/forum/testgear/owon-sds7102v-problem-with-encoders/msg3479200/#msg3479200
Offline Suzook
« Reply #2757 on: June 03, 2022, 02:31:45 pm »
Has anyone found a way to flash a Chinese eds102 with sds7102 fw? Thanks
The following users thanked this post: caheo
Offline caheo
  • Country: vn
« Reply #2758 on: March 01, 2023, 03:41:44 am »
I got EDS102CV stuck at logo boot loop, did you try to flash sds7102 firmware over eds102?
Offline caheo
  • Country: vn
« Reply #2759 on: March 06, 2023, 07:48:18 am »
Is there anyone who has a NAND flash dump for Micron 29F1G08ABAEA? Or, is it the same as Samsung K9F1G08?
Also, has anyone flashed NAND-flash using J-Link v8 for example? Or using LPT wiggler is a must? Thanks!
Offline Sergey61
  • Country: ru
« Reply #2760 on: April 21, 2024, 10:03:14 am »
дамп одинаковый будет.я вообще поставил f59l1g81a,и прошил дампом с самсунг микросхемы. и вопрос,есть ли у кого дамп с sds8102?вопрос снят,китайец прислал патч,это не помогло,кнопки не заработали,попробу плис или soc микросхемы поменять,так как через плис идет сигнал с кнопок
« Last Edit: May 09, 2024, 09:58:54 pm by Sergey61 »
Offline tomatos666
« Reply #2761 on: June 14, 2024, 06:19:26 am »
Hello are you successful to bring the buttons do live?
Offline Sergey61
  • Country: ru
« Reply #2762 on: January 13, 2025, 12:40:47 pm »
soc микросхему поменял,и управление кнопками стало работать
Offline rubennss
« Reply #2763 on: February 10, 2025, 10:47:54 am »
Sergey61
I have two OWON TDS8204C TDS7104C oscilloscopes which have the same problem ( boot logo appears and nothing else). I connected with Putty program and got this message:
NAND: 512 MiB
U-Boot 2008.10 (Apr 14 2014 - 09:37:23)
OMAP35X-Family-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 SPQ board + LPDDR/NAND
readenv ERR*** Warning - bad CRC or NAND, using default environment
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  0
NAND read: device 0 offset 0x1ff80000, size 0x40000
NAND read from offset 1ff80000 failed -117
 262144 bytes read: ERROR
## Executing script at 80800000
Please write step by step:
-where did you get the memory dump
-how you programmed the memory step by step, what programmer you used
It seems that the cause of the problems may be a worn out battery holding the memory, its replacement with a new one does not change anything.
Offline tomatos666
« Reply #2764 on: December 01, 2025, 08:11:54 am »
Hi all,
my SDS7102 is bricked, JTAG + OpenOCD works fine.
All public dumps I found are either modified (different logo), for the V-model or links are dead.
Could anyone please share a clean 128 MiB raw NAND K9F1G08U0D dump (134 217 728 bytes) from an unmodified SDS7102 that still shows the original Owon logo?
Google Drive / WeTransfer / Mega / PM – whatever works for you.
Thanks a lot!
Offline lemon
  • Country: gr
« Reply #2765 on: December 06, 2025, 09:38:52 am »
The same problem here and from what I have seen, the same issue happens if someone let the oscilloscope without operation for 1+ year!
Have you seen the Christer's Rambling page?
https://blog.weinigel.se/2016/05/01/sds7102-hacking.html
If you find the solution, please give us the way!
