Hi all,
I've the RIGOL 1052E, no mod, original 50Mhz.
I'm trying to repair a synthetizer board based on the mc68331 MCU.
I'm checking the CLKOUT of this IC, which with my 32.768 kHz crystal should output 8.389 MHz, it does't.
Here comes the quotion about the behaviour I've notice on my RIGOL.
If I capture (Run/Stop) CLKOUT at something less than 100.00ns I see a 25.1655Mhz output, even if I zoom out, it stays the same.
If I do the same thing with more than 100ns, the capture shows a non linear output.
Find some image as reference.
Why does this happens? Sorry for this dumb question.
I even try with my logic analyzer (
https://sigrok.org/wiki/VKTECH_saleae_clone), see attached image. But I'm not sure if this reading is wrong cause it goes up to 24Mhz max logic analyzer speed, or this read is right.
Thank you!
By the way the repair thread is here, I'm still working on it, ordering some parts
https://www.norduserforum.com/nord-lead-rack-forum-f12/nord-lead-3-problem-does-not-boot-t20997.html
