Author Topic: Rigol 'unlock" source code archive?  (Read 7479 times)
Offline marksailTopic starter
« on: December 06, 2016, 07:46:10 pm »
I'm trying to run the Win app from the 'source code archive' at http://gotroot.ca/rigol/riglol/ on either a Win 10 or Win 7 machine.
When I open the app, I see a momentary flicker of what looks like a Command Prompt window, then nothing.
How do I get this app to run properly?
Reason.....
My understanding is that this archived app is another way to generate an unlock code....correct?
The unlock code I keep getting from the web page link repeatedly returns 'invalid license' on a new 1054z.
I'm wanting to see if the archive app perhaps gives a different code.
Thank you,  mark
Online PA0PBZ
Re: Rigol 'unlock" source code archive?
« Reply #1 on: December 06, 2016, 08:33:55 pm »
It needs parameters behind the riglol.exe file, you can see the output when you run it from a dos prompt/command window:
C:\Users\Me\Desktop>riglol.exe
Riglol 1.03d
Usage: riglol.exe <sn> <opts> <privkey>
  <sn>       serial number of device (D............)
  <opts>     device options, 4 characters, see below
  <privkey>  private key (optional)
DP832 starting from v1.09 device options:
  first character:  F = official, B = trial
  F3PT - Accuracy
  F6PT - Analyzer and Monitor
  F6LT - LAN
  FALT - RS232
  FLLT - Trigger
DP832 up to v1.06 device options:
  first character:  M = official, 5 = trial
  MWSS - Trigger
  MWTB - Accuracy
  MWTC - LAN and RS232
  MWTE - Analyzer and Monitor
DS1000z device options:
  DSAB - Advanced Triggers
  DSAC - Decoders
  DSAE - 24M Memory
  DSAJ - Recorder
  DSBA - 500uV Vertical
DS2000 device options:
  first character:  D = official, V = trial
  DSAC - Decoders
  DSAE - 56M Memory
  DSAJ - 100MHz
  DSAS - 200MHz
  DSAZ - all options
DS4000 device options:
  DSHB - RS232 Decoder
  DSHC - SPI Decoder
  DSHE - I2C Decoder
  DSHJ - CAN Decode
  DSHS - FlexRay Decoder
  DSH9 - all options
DSA815 device options:
  first character:  A = official, S = trial
  AAAB - Tracking Generator
  AAAC - Advnced Measurement Kit
  AAAD - 10Hz RBW
  AAAE - EMI/Quasi Peak
  AAAF - VSWR
MAKE SURE YOUR FIRMWARE IS UP TO DATE BEFORE APPLYING ANY KEYS
Offline metrologist
« Reply #2 on: December 06, 2016, 08:46:22 pm »
careful that you don't lock your scope. I read it will lock up for something like 12 hours run time if the code fails too often.
Offline alsetalokin4017
« Reply #3 on: December 06, 2016, 09:05:22 pm »
Reason.....
Thank you,  mark
Try opening the Command Prompt window and running the .exe from there rather than clicking on its icon on the desktop.
Also, in the riglol archive there should be a html version of the keygen that will open in your default browser (enable Javascript) and will run from there. You do not need to fill the "private key" box.
Note that DSER is the code for the keygen to unlock 100 MHz bw and all options _except_ the 500 uV vertical. DSER is not listed in the instruction but it is the one to use.
Yes, if you enter an invalid key three times you get put in the "penalty box" for 12 hours of actual scope runtime.
« Last Edit: December 06, 2016, 09:10:13 pm by alsetalokin4017 »
« Reply #4 on: December 06, 2016, 09:20:35 pm »
Thank You All !!
The app did generate a new code, different from the one provided by http://gotroot.ca/rigol/riglol/, and the new code worked. UNLOCKED dser !
I had tried running .exe straight from the command prompt as well as from the icon, but my dumbass was spelling rigol
It wasn't until I was meticulously copying PAOPBZ's instructions I saw what I was doing...
Been a long time since working under command prompt...nah, that ain't it...back to the dumbass !
Thanks again
Online PA0PBZ
« Reply #5 on: December 06, 2016, 09:39:43 pm »
Offline hobbywork
« Reply #6 on: December 20, 2016, 08:45:16 pm »
I saw via a youtube video that there is a firmware update of 00.04.04.01.01 but when I go to the www.rigolna.com website and check for a firmware download it gives me 00.04.03.02.03??
Could this be based on my hardware (serial number)??
Offline Fungus
« Reply #7 on: December 20, 2016, 08:51:51 pm »
No.
00.04.04.01.01 has been temporarily withdrawn.
The following users thanked this post: hobbywork
Offline hobbywork
« Reply #8 on: December 20, 2016, 08:57:38 pm »
So should I hold off on updating my scope?  I wanted to up and unlock the features.
Offline Heszu
  • Country: vu
« Reply #9 on: December 21, 2016, 12:29:31 pm »
Thank you,  mark
Instead of going to win folder , navigate to web folder instead.
And from there  double click on riglol.html , and You will smile :)
No need to fiddle with command prompt, if you don't want to  |O
WBR
H
