It will be interesting to see peoples results for the higher amplitude settings.
1 Vpp is max amplitude between 120 - 160 MHz for DG4162.
Yes, but a comparison could be made between 1Vpp up to 120MHz and 2Vpp up to 120MHz.
Amplitude makes quite a difference I think. I've also been looking at the TTi TG5011 which has separate specs for <1V and > 1V. Also at the Tabor WW5061 which in early specs used the level of 5V (it has been around a while and older spec sheets are available on the web) and then reduced it to 3Vpp and improved the high frequency distortion figures as a result.
For example, the original Tabor WW5061 spec for Harmonic Distortion up to 25MHz was given at 5Vpp and the figure was -28dBc. The latest figure, for the same hardware, is -40dBc but this is given for 3Vpp. Then you are supposed to compare this with the Rigol which is -50dBc all the way up to 100MHz but it is given at 0dBm which is only 0.31Vpp or one tenth of the amplitude.
I've found myself going round in circles trying to do a fair comparison between the Rigol DG4062, the TTi TG5011 and the Tabor WW5061 all of which I can get for about the same price (the Rigol new and the other two as ex-demo or old stock as their new list prices are much higher).
